    MMM-AssistantMk2
    421 Posts 61 Posters 757.5k Views 57 Watching
    • T Offline
      teitlebot @Guest
      @sean What are you using for a mic?
        [[global:former-user]] @teitlebot
        @teitlebot
        I’m using logitech usb cam currently. Before that, Ps3eye, cheap chinese usb mic were tested.
          MarkV @Guest
          @sean @teitlebot
          i’m using a cheap chinese usb mic :grinning_face_with_smiling_eyes:
          • T Offline
            teitlebot
            just to update and help. I reinstalled everything without the AIY Google HAT and just using a usb mic and the issue of the audio choppiness went away. Still working on other issues like no kiosk mode and learning this complicated google home interface stuff but its really cool.
            • T Offline
              teitlebot @MarkV
              @markv have a look at this if your mic isnt working
              https://github.com/eouia/MMM-AssistantMk2/issues/16
              • T Offline
                teitlebot
                @jomwells @Module-Developers
                Did anyone figure out how to add led or sound, like a beep to show when google is listening and speaking. I dont think I’m good enough with linux to do this without a tutorial. Is it something that needs to be implemented in the module or can i learn how to do it from a simple aiy kit?
                  @teitlebot
                  https://github.com/eouia/MMM-AssistantMk2#outgoing-notifications-as-assistant-response
                  Basic notifications will be emitted by its status.
                  And you can modify module for catching the status to do your specific job.
                  See https://github.com/eouia/MMM-AssistantMk2/blob/93d7eca6a3995987554d8deb4f4cd76b44e3f096/MMM-AssistantMk2.js#L264
                  In .socketNotificationReceived(), you can catch each Assistant status.
                  Anyway, I’m considering to add simple ding-dong waves for convenience in next patch.
                  • T Offline
                    teitlebot
                    @sean I had to leave the assistant action part of the code out because it was causing errors in my config file.
                      cola0927
                      Hi, I just tried installing MMM-AssistantMk2 by following the instruction. After saving the config.js (use default configuration) nothing shows up and all I can see is a black screen but a movable mouse pointer. I can’t even quit the mirror. I have no idea what do to now, do I have to start over from the very beginning? :loudly_crying_face:
                      T ? 2 Replies Last reply Reply Quote 0
                      • T Offline
                        teitlebot @cola0927
                        @cola0927 many of us had this issue and thats why we run it in servomode
                        • T Offline
                          teitlebot
                          @Module-Developers Why do you set this up as a smart TV. Why cant it be set up as a google assistant with video like the new displays they sell now?
                            cola0927 @teitlebot
                            @teitlebot oh, ok, thanks. It’s my first mirror, no relative experience before. I’ll be more careful next time.
                              mirror.master
                              Dying to use this module, but im stuck on node auth_and_test.js i keep getting the GLIBBCXX_3.4.21 not found error. tried the solutions found on the module page and a few others spots. but to no avail. any suggestions?
                                [[global:former-user]] @cola0927
                                @cola0927 said in MMM-AssistantMk2 & MMM-GAction:
                                Show me your error logs. there could be many reasons about that symptom.
                                  @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
                                  Is there a google assistant with video at the setup moment? Wasn’t it on my development. If it exists, go ahead sure.
                                    mirror.master
                                    dude try a: pm2 stop mm while ssh and then check your config. you are never stranded lol
                                      [[global:former-user]] @mirror.master
                                      @mirror-master said in MMM-AssistantMk2 & MMM-GAction:
                                      GLIBCXX problem shows your RPI doesn’t be running on Raspbian Stretch or proper dev-modules are not installed. My suggestion is… to use Stretch
                                        mirror.master
                                        upgrading now in hopes. thanks my friend. i have several pi’s with diff versions . when i was paranoid and less exp’d i was cloning my pie config, but forgot that one was jessie , one is stretch and another is whatever the hell i installed. Im pretty sure this is the older OS. Thanks again
                                          cola0927
                                          @sean Keyboard input or mouse clicking had no effect, maybe because I missed the “rebuild binaries” step.
                                          So I started over again today and this time the microphone icon appeared after MMM-AssistantMk2 was installed, but couldn’t detect the voice, even after installed MMM-Hotword and MMM-NotificationTrigger.
                                          Here is my config.js, basically used default values.
        module: "MMM-AssistantMk2",
        position: "lower_third",
        module: "MMM-Hotword",
        module: "MMM-NotificationTrigger",
        triggers:[
        trigger: "ASSISTANT_ACTION",
        triggerSenderFilter: (sender) => {
        console.log(sender)
        if (sender.name == 'MMM-AssistantMk2') {
        return true
        } else {
        return false
        triggerPayloadFilter: (payload) => {
        console.log(payload)
        return true
        fires: [
        fire:"SHOW_ALERT",
        payload: (payload) => {
        return {
        type: "notification",
        title: payload.type,
        message: payload.command
                                          Could you please let me know which part(s) I should modify? Thank you!
                                            @cola0927
                                            Your MMM-NotificationTrigger configuration is wrong.
                                                    triggers:[
                                                        trigger: "HOTWORD_DETECTED",
                                                        fires: [
                                                            fire:"HOTWORD_PAUSE",
                                                            fire:"ASSISTANT_ACTIVATE",
                                            		delay: 200,
                                                            payload: function(payload) {
                                                              return {
        "profile": payload.hotword
                                                        trigger: "ASSISTANT_DEACTIVATED",
                                                        fires: [
                                                            fire:"HOTWORD_RESUME"
                                            Try this.
                                            • 21
                                            • 22
                                            • 4 / 22
