    MMM-AssistantMk2
    421 Posts 61 Posters 779.4k Views 57 Watching
    • T
      teitlebot @Guest
      @sean @JRCelis Im having the same issue with the buzz and im also using the HAT. Did you fix the issue? Is there a way to just not use the HAT I have a usb mic but Im new at the whole raspberry thing.
      Looks like a great module but im having small hickups along the way.
        MarkV
        I’ve installed MMM-AssistantMk2 with MMM-Hotword and MMM-NotificationTrigger.
        Everything works fine except for the return audio.
        It stutters and i’m getting the idea that it isn’t procest quick eneough.
        Am i the only one with this problem and if not does somebody have the solution?
          A Former User @MarkV
          @markv @teitlebot
          There could be many reasons for that case.
          Maybe too many modules or too many front-end refreshing or animating, too many background process or anything else, even including internet speed.
          I cannot point specific reason at this moment.
          Anyway in my device, I use BT speaker and I have no problem about that. Sorry.
          M T 2 Replies Last reply Reply Quote 0
            MarkV @Guest
            @sean
            Thanks for the reply.
            I was scared of something like that. After a clean raspbian image i just installed MagicMirror and after that MMM-AssistantMK2, MMM-Hotword and MMM-TriggerNotification (with all the nmp rebuild errors). I’ve uninstalled the compleet LibreOffice and game packets wich come by default with raspbian.
            I allready made a .asoundrc file like you can find around the internet.
            aplay && arecord work fine without glitches.
            Result .asoundrc
            pcm.!default {
              type asym
              capture.pcm "mic"
              playback.pcm "speaker"
            ctl.!default {
                    type hw
                    card 0
            pcm.mic {
              type plug
              slave {
                pcm "hw:1,0"
            pcm.speaker {
              type plug
              slave {
                pcm "hw:0,0"
                rate 18000
            Results aplay -l && arecord -l
            pi@MagicMirror2:~ $ aplay -l
            **** List of PLAYBACK Hardware Devices ****
            card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
              Subdevices: 7/7
              Subdevice #0: subdevice #0
              Subdevice #1: subdevice #1
              Subdevice #2: subdevice #2
              Subdevice #3: subdevice #3
              Subdevice #4: subdevice #4
              Subdevice #5: subdevice #5
              Subdevice #6: subdevice #6
            card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
              Subdevices: 1/1
            pi@MagicMirror2:~ $ arecord -l
            **** List of CAPTURE Hardware Devices ****
            card 1: Device [USB PnP Sound Device], device 0: USB Audio [USB Audio]
              Subdevices: 1/1
            Result lsmod
            pi@MagicMirror2:~/MagicMirror $ lsmod
            Module                  Size  Used by
            fuse                  106496  3
            cfg80211              573440  0
            rfkill                 28672  2 cfg80211
            joydev                 20480  0
            ads7846                20480  0
            hwmon                  16384  1 ads7846
            snd_bcm2835            32768  1
            spi_bcm2835            16384  0
            i2c_bcm2835            16384  0
            fixed                  16384  0
            uio_pdrv_genirq        16384  0
            uio                    20480  1 uio_pdrv_genirq
            evdev                  24576  8
            snd_usb_audio         172032  0
            snd_hwdep              16384  1 snd_usb_audio
            snd_usbmidi_lib        32768  1 snd_usb_audio
            snd_rawmidi            32768  1 snd_usbmidi_lib
            snd_seq_device         16384  1 snd_rawmidi
            snd_pcm                98304  2 snd_usb_audio,snd_bcm2835
            snd_timer              32768  1 snd_pcm
            snd                    69632  10 snd_hwdep,snd_usb_audio,snd_timer,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_bcm2835,snd_pcm
            i2c_dev                16384  0
            ip_tables              24576  0
            x_tables               32768  1 ip_tables
            ipv6                  434176  22
            What would you suggest doing now? I’m a little stuck now, due to my lack of knowledge of Linux.
            • T
              teitlebot @Guest
              @sean What are you using for a mic?
                A Former User @teitlebot
                @teitlebot
                I’m using logitech usb cam currently. Before that, Ps3eye, cheap chinese usb mic were tested.
                  MarkV @Guest
                  @sean @teitlebot
                  i’m using a cheap chinese usb mic :grinning_face_with_smiling_eyes:
                  • T
                    teitlebot
                    just to update and help. I reinstalled everything without the AIY Google HAT and just using a usb mic and the issue of the audio choppiness went away. Still working on other issues like no kiosk mode and learning this complicated google home interface stuff but its really cool.
                    • T
                      teitlebot @MarkV
                      @markv have a look at this if your mic isnt working
                      https://github.com/eouia/MMM-AssistantMk2/issues/16
                      • T
                        teitlebot
                        @jomwells @Module-Developers
                        Did anyone figure out how to add led or sound, like a beep to show when google is listening and speaking. I dont think I’m good enough with linux to do this without a tutorial. Is it something that needs to be implemented in the module or can i learn how to do it from a simple aiy kit?
                          @teitlebot
                          https://github.com/eouia/MMM-AssistantMk2#outgoing-notifications-as-assistant-response
                          Basic notifications will be emitted by its status.
                          And you can modify module for catching the status to do your specific job.
                          See https://github.com/eouia/MMM-AssistantMk2/blob/93d7eca6a3995987554d8deb4f4cd76b44e3f096/MMM-AssistantMk2.js#L264
                          In .socketNotificationReceived(), you can catch each Assistant status.
                          Anyway, I’m considering to add simple ding-dong waves for convenience in next patch.
                          • T
                            teitlebot
                            @sean I had to leave the assistant action part of the code out because it was causing errors in my config file.
                              cola0927
                              Hi, I just tried installing MMM-AssistantMk2 by following the instruction. After saving the config.js (use default configuration) nothing shows up and all I can see is a black screen but a movable mouse pointer. I can’t even quit the mirror. I have no idea what do to now, do I have to start over from the very beginning? :loudly_crying_face:
                              T ? 2 Replies Last reply Reply Quote 0
                              • T
                                teitlebot @cola0927
                                @cola0927 many of us had this issue and thats why we run it in servomode
                                • T
                                  teitlebot
                                  @Module-Developers Why do you set this up as a smart TV. Why cant it be set up as a google assistant with video like the new displays they sell now?
                                    cola0927 @teitlebot
                                    @teitlebot oh, ok, thanks. It’s my first mirror, no relative experience before. I’ll be more careful next time.
                                      mirror.master
                                      Dying to use this module, but im stuck on node auth_and_test.js i keep getting the GLIBBCXX_3.4.21 not found error. tried the solutions found on the module page and a few others spots. but to no avail. any suggestions?
                                        A Former User @cola0927
                                        @cola0927 said in MMM-AssistantMk2 & MMM-GAction:
                                        Show me your error logs. there could be many reasons about that symptom.
                                          @teitlebot said in MMM-AssistantMk2 & MMM-GAction:
                                          Is there a google assistant with video at the setup moment? Wasn’t it on my development. If it exists, go ahead sure.
                                            mirror.master
                                            dude try a: pm2 stop mm while ssh and then check your config. you are never stranded lol
                                            • 21
                                            • 22
                                            • 4 / 22
