    ,Change Fonts
    fontraspberry pi 3csscustom
    10 Posts 5 Posters 9.1k Views 5 Watching
    • Lorenzo_ZappaL Offline
      Lorenzo_Zappa
      @philreis unfortunately nothing changes…
      Still not working
        PhilReis
        Try to put your fonts directory in the Magic Mirror directory.
        • lavolp3L Offline
          lavolp3 Module Developer
          Better use an absolute path (as you did oiginally) instead of the relative one philreis suggested
          @font-face {
            font-family: "MyFont";
            font-style: normal;
            font-weight: 100;
            src:
              local("SF-Pro-Display-Light"),
              url("/home/pi/.fonts/SF-Pro-Display-Light.otf") format("truetype");
          The path philreis suggested cannot work as it is.
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            Lorenzo_Zappa
            Ok, I have found a way to make it work, but I don’t like it very much…
            Basically I have to add my lines of code in this file:
            /home/pi/MagicMirror/fonts/roboto.css
            Like this:
            @font-face {
              font-family: SF;
              font-style: normal;
              font-weight: 100;
              src:
                local("SF"),
                url("SF/SFProDisplay-LightItalic.ttf") format("truetype");
            @font-face {
              font-family: Roboto;
              font-style: normal;
              font-weight: 100;
              src:
                local("Roboto Thin"),
                local("Roboto-Thin"),
                url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.woff2") format("woff2"),
                url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.woff") format("woff"),
                url("node_modules/roboto-fontface/fonts/roboto/Roboto-Thin.ttf") format("truetype");
            And then everything works.
            Any solution without using this work around? I don’t like it very much, and it is not so clean.
            Thank you
              Lorenzo_Zappa
              I finally did it :)
              I don’t know why but if I want to declare my font-face in my custom.css file the fonts folder containing all my fonts must be in the same directory or in a sub-directory.
              Now everything works
              Thank you all guys
                PhilReis @lavolp3
                @lavolp3 my solution works.
                For the web server is the Magic Mirror directory the “root” directory. So you have to create the fonts directory in the Magic Mirror directory.
                • TazDevT Offline
                  TazDev
                  what I inserted in my custom.css
                  :root {
                          --font-primary: "SF-Compact";
                          --font-secondary: "SF-Pro";
                  @font-face {
                    font-family: "SF-Compact";
                    font-style: normal;
                    src:
                      local("SF-Compact"),
                      url("/fonts/SF-Compact.ttf") format("truetype");
                  @font-face {
                    font-family: "SF-Pro";
                    font-style: normal;
                    src:
                      local("SF-Pro"),
                      url("/fonts/SF-Pro.ttf") format("truetype");
                  both files I extracted from my Mac and copied it to ~/MagicMirror/fonts
                    davidgagne @TazDev
                    @TazDev Thanks! This is exactly what I needed to change my MagicMirror so it displays Aurabesh for some of the data.
