    include npm module like firebase module into our own MM module
    9 Posts 2 Posters 2.4k Views 2 Watching
    • K Offline
      kevung
      How to include npm module like firebase module into our own MM module?
      i tried include module using const firebase = require(‘firebase’). But keep getting error
        [[global:former-user]] @kevung
        @kevung
        You need node_helper.js to include node modules to your MM module. MM module itself is front-end javascript thus it cannot access your system resources. node_helper.js can help your job for handling system (e.g. File I/O, using node_modules, execution another process, etc.)
        • K Offline
          kevung
          @sean said in include npm module like firebase module into our own MM module:
          i tried node helper. below code is working. But once i added const firebase = require (‘firebase’) on top then error appeared.
          var NodeHelper = require("node_helper")
            start: function() {
              this.countDown = 10000000
              switch(notification) {
                case "DO_YOUR_JOB":
                  this.sendSocketNotification("I_DID", (this.countDown - payload))
                  break
          The error is
          WARNING! Could not load config file. Starting with default configuration. Error found: Error: Failed to load gRPC binary module because it was not installed for the current system
          Expected directory: electron-v2.0-linux-arm-glibc
          Found: [node-v59-linux-arm-glibc]
          This problem can often be fixed by running "npm rebuild" on the current system
          Original error: Cannot find module '/home/pi/MagicMirror/modules/MMM-hellotsuhan/node_modules/grpc/src/node/extension_binary/electron-v2.0-linux-arm-glibc/grpc_node.node'
          I tried npm rebuild. but still not working
            @kevung
            I know what it is.
            MagicMirror standalone(kiosk) mode is running on Electron - frontend GUI framework. Unfortunately, it has its own node.js and chrome engine. Your current node module might not be compatible with Electron version. So you should re-build node modules for matching proper Electron.
            Normally electron-rebuild will be a help.
            In SERVERONLY mode, with Chrome browser as frontend, you might not get this error.
              @kevung
              cd ~/MagicMirror/modules/MMM-hellotsuhan
              npm install --save-dev electron-rebuild
              ./node_modules/.bin/electron-rebuild
              This could be the solution. or not. :D
              • K Offline
                kevung
                Thanks bro!:smiling_face_with_open_mouth_smiling_eyes: this work for me!! after did below code then success to run the code already.
                Now my node_helper.js is :
                const firebase = require ('firebase')
                let countdown;
                var ref;
                var config = {
                    apiKey: "AIzaSyAxi_kFKM3lxMZ9gnBMhwoPa7pxKX_e1BI",
                    authDomain: "customerservice-ee487.firebaseapp.com",
                    databaseURL: "https://customerservice-ee487.firebaseio.com",
                    projectId: "customerservice-ee487",
                    storageBucket: "customerservice-ee487.appspot.com",
                    messagingSenderId: "466622230094"
                if (!firebase.apps.length) {
                    firebase.initializeApp(config);
                    start: function() {
                       ref = firebase.app().database().ref().child('countdown');
                       r ef.once('value').then(function (snap) {
                         console.log('snap.val()', snap.val());
                         countdown=snap.val();
                         case "DO_YOUR_JOB":
                           ref.once('value').then(function (snap) {
                          this.sendSocketNotification("I_DID", countdown - payload);
                	  break
                My MMM-hellotsuhan.js
                Module.register("MMM-hellotsuhan",{
                    start: function (){
                        this.count = 0
                    getDom: function() {
                        var element = document.createElement("div")
                	element.className = "myContent"
                	element.innerHTML = "Hello, World! " + this.config.foo
                        var subElement = document.createElement("p")
                	subElement.id = "COUNT"
                	element.appendChild(subElement)
                	return element
                	    case "DOM_OBJECTS_CREATED":
                	        var timer = setInterval(()=>{
                	            this.sendSocketNotification("DO_YOUR_JOB", this.count)
                	            this.count++
                	        }, 1000)
                	        break
                	    case "I_DID":
                	        var elem = document.getElementById("COUNT")
                	        elem.innerHTML = "Count:" + payload
                	        break
                • K Offline
                  kevung @kevung
                  btw Thanks for the great tutorial for developing module from @Sean !!
                  Head first developing MM module for extreme beginners
                    @kevung
                    I think you’d better define config in module js instead node_helper.js to be able to be redefined by user in config.js. You can move config values with sendSocketNotification.
                    • K Offline
                      kevung @Guest
                      @sean ok will try it out later =)
