    include npm module like firebase module into our own MM module
    9 Posts 2 Posters 2.2k Views 2 Watching
      A Former User @kevung
      @kevung
      cd ~/MagicMirror/modules/MMM-hellotsuhan
      npm install --save-dev electron-rebuild
      ./node_modules/.bin/electron-rebuild
      This could be the solution. or not. :D
      • K Offline
        kevung
        Thanks bro!:smiling_face_with_open_mouth_smiling_eyes: this work for me!! after did below code then success to run the code already.
        Now my node_helper.js is :
        const firebase = require ('firebase')
        var NodeHelper = require("node_helper")
        let countdown;
        var ref;
        var config = {
            apiKey: "AIzaSyAxi_kFKM3lxMZ9gnBMhwoPa7pxKX_e1BI",
            authDomain: "customerservice-ee487.firebaseapp.com",
            databaseURL: "https://customerservice-ee487.firebaseio.com",
            projectId: "customerservice-ee487",
            storageBucket: "customerservice-ee487.appspot.com",
            messagingSenderId: "466622230094"
        if (!firebase.apps.length) {
            firebase.initializeApp(config);
            start: function() {
               ref = firebase.app().database().ref().child('countdown');
               r ef.once('value').then(function (snap) {
                 console.log('snap.val()', snap.val());
                 countdown=snap.val();
              switch(notification) {
                 case "DO_YOUR_JOB":
                   ref.once('value').then(function (snap) {
                  this.sendSocketNotification("I_DID", countdown - payload);
        	  break
        My MMM-hellotsuhan.js
        Module.register("MMM-hellotsuhan",{
            start: function (){
                this.count = 0
            getDom: function() {
                var element = document.createElement("div")
        	element.className = "myContent"
        	element.innerHTML = "Hello, World! " + this.config.foo
                var subElement = document.createElement("p")
        	subElement.id = "COUNT"
        	element.appendChild(subElement)
        	return element
        	    case "DOM_OBJECTS_CREATED":
        	        var timer = setInterval(()=>{
        	            this.sendSocketNotification("DO_YOUR_JOB", this.count)
        	            this.count++
        	        }, 1000)
        	        break
        	    case "I_DID":
        	        var elem = document.getElementById("COUNT")
        	        elem.innerHTML = "Count:" + payload
        	        break
        • K Offline
          kevung @kevung
          btw Thanks for the great tutorial for developing module from @Sean !!
          Head first developing MM module for extreme beginners
            @kevung
            I think you’d better define config in module js instead node_helper.js to be able to be redefined by user in config.js. You can move config values with sendSocketNotification.
            • K Offline
              kevung @Guest
              @sean ok will try it out later =)
