    Flick Large gesture control
    Scheduled Pinned Locked Moved Solved Hardware
    18 Posts 7 Posters 12.2k Views 10 Watching
      Radu_Stancu
      Hello all,
      I have tried to use the flick Large sensor together with my Raspberry Pi 2 to control the interface of the MagicMirror, as I have made some pages and wanted to scroll through them.
      What I have managed to do is to control MMM-pages, MMM-page-indicator and the default news module via my MMM-flick module.
      The controls are as follows:
      Swipe Left - Decrement Page
      Swipe Right - Increment Page
      Swipe Up - Show news description
      Swipe Up again - Open News page
      Swipe Up as the news page is opened - Scroll down the news page
      Swipe Down - Close News Page
      Swipe Down again - Close News Description
      I`m currently working on implementing the touch functionality. I want to also have mouse control.
      The code is not perfect, I`m working it.
      Here is the code (note that I have changed some libraries for it to work with the ASUS Tinker Board, as far as I know I`m the only one who has working flicklibs on the TinkerBoard. If someone is interested in getting the flick sensor to work with the TinkerBoard pm me ):
      MMM-flick.py - used to read sensor data
       #!/usr/bin/env python
       import sys
       import json
       import time
       import signal
       import flicklib
       import RPi.GPIO as GPIO
       #import autopy
       GPIO.setmode(GPIO.BOARD)
       GPIO.setup(15, GPIO.OUT)
       GPIO.setup(7, GPIO.OUT)
       #Turn on both LEDs for orange color in Stand By
       #GPIO.output(7, True) # Turn on RED LED
       #GPIO.output(15, True)# Turn on GREEN LED
       #Airwheel data
       some_value = 5000
       last_airwheel = 0
       delay = 5000
       #Get display size
       #width, height = autopy.screen.get_size()
       def to_node(type, message):
       	# convert to json and print (node helper will read from stdout)
       	try:
       		print(json.dumps({type: message}))
       	except Exception:
       		pass
       	# stdout has to be flushed manually to prevent delays in the node helper communication
       	sys.stdout.flush()
       to_node("status", 'Flick has started...')
       @flicklib.flick()
       def flick(start,finish):
       	#Slide down the newsfeed (DOWN GESTURE)
       	if(start == "north" and finish == "south"):
       		to_node("gesture", "ARTICLE_LESS_DETAILS")
       		time.sleep(0.5)
       		GPIO.output(7, False)
       	#Slide up the newsfeed (UP GESTURE)
       	elif(start == "south" and finish == "north"):
       		to_node("gesture", "ARTICLE_MORE_DETAILS")
       		time.sleep(0.5)
       		GPIO.output(15, False)
       	#Next page (RIGHT GESTURE)
       	elif(start == "west" and finish == "east"):
       		to_node("gesture", "PAGE_DECREMENT")
       		time.sleep(0.5)
       	#Previous page (LEFT GESTURE)
       	elif(start == "east" and finish == "west"):
       		to_node("gesture", "PAGE_INCREMENT")
       		time.sleep(0.5)
       @flicklib.airwheel()
       def spinny(delta):
       	global some_value
       	global last_airwheel
       	global delay
       	some_value += delta
       	if some_value < 0:
       		some_value = 0
       	if some_value > 10000:
       		some_value = 10000
       	now = int(round(time.time() * 1000))
       	if(now - last_airwheel > delay):
       		#to_node()
       		last_airwheel = now
       #Mouse control via flick board
       #@flicklib.move()
       #def move(x,y,z):
       #	x = (x) * width
       #	y = (y) * height
       #	x = int(x)
       #	y = height - int (y)
       #	if( y > 799 ):
       #		y = 799
       	#autopy.mouse.move(x, y)
       #Double tap gesture
       #@flicklib.double_tap()
       #def doubletap(position):
       #Tap gesture
       @flicklib.tap()
       def tap(position):
       	if position == 'center':
       		time.sleep(0.5)
       		GPIO.output(15, False)# Turn off GREEN LED
       #Touch gesture
       #@flicklib.touch()
       #def touch(position):
       signal.pause()
      node_helper.js
       'use strict';
       const NodeHelper = require('node_helper');
       const {PythonShell} = require('python-shell');
       var pythonStarted = false
       	python_start: function () {
       		const self = this;
       		const pyshell = new PythonShell('modules/' + this.name + '/MMM-flick.py', { mode: 'json', args: [JSON.stringify(this.config)]});
       		pyshell.on('message', function (message) {
       			if (message.hasOwnProperty('status')){
       			console.log("node_helper_[" + self.name + "]" + message.status);
       			if (message.hasOwnProperty('gesture')){
       			console.log("node_helper_[" + self.name + "] " + message.gesture);
       			self.sendSocketNotification("gesture_observed", message.gesture);
       		 pyshell.end(function (err) {
       			if (err) throw err;
       			console.log("node_helper_[" + self.name + "] " + 'finished running...');
       	// Subclass socketNotificationReceived received.
       		if(notification === 'CONFIG') {
       		  this.config = payload
       		  if(!pythonStarted) {
       			pythonStarted = true;
       			this.python_start();
      MMM-flick.js
      Module.register("MMM-flick",{
      		gesture_up: 0,
      		gesture_right: 0,
      	// Override socket notification handler.
      		if (notification === "gesture_observed"){
      			const self = this;
      			self.sendNotification(payload);
      			if (payload === "up"){
      					MM.getModules().withClass(this.config.defaultClass).exceptWithClass(this.config.everyoneClass).enumerate(function(module) {
      						module.hide(1000, function() {
      							Log.log(module.name + ' is hidden.');
      					MM.getModules().withClass("class_up_1_show").enumerate(function(module) {
      						module.show(1000, function() {
      							Log.log(module.name + ' is shown.');
      			else if (payload === "down") {
      							Log.log(module.name + ' is hidden by gesture.');
      	start: function() {
      		this.current_user = null;
      		this.sendSocketNotification('CONFIG', this.config);
      		Log.info('Starting module: ' + this.name);
        Radu_Stancu
        Nvm, I got it working perfectly! xD
          macnice
          Hello, is it possible to place it behind the mirror? Could you show us a picture of your integration into MagicMirror?
          Thank you in advance.
            Radu_Stancu
            That is exactly what I’m planning to do. In theory it works behind the mirror, but you will lose the touch gestures more than likely. Unfortunately I do not have the mirror yet (it has not been delivered yet), but I’ll post a picture/results when I get it.
            So far I wrote the code this way:
            Left/right swipes go through MMM-pages & MMM-pages_indicator
            Up/down swipes open/close newsfeed details
            Each gesture also triggers the LED on the sensor board.
            I’m still thinking what other things I can do with the remaining gestures.
            I’ll update the correct code after I clean it up a bit.
              macnice
                macnice @Radu_Stancu
                @radu_stancu Thank you for your answer I look forward to your feedback, because I would also like to use this solution. 🙂
                  SteffenSchmidt
                  Could you describe, if you were successfull with the implementation of the board? Best Regards.
                    Radu_Stancu @SteffenSchmidt
                    @steffenschmidt, I was successful to some extent. I have managed to use the gestures from the board to control the interface. Up, down, left and right are working and more will follow when I know what I want them to do. The only problem is that the flick sensor is NOT WORKING behind the mirror, probably because of the aluminum/silver layer that makes a mirror a mirror.
                    I will work on the project in the winter holidays and post some more details.
                      Radu_Stancu
                      Updated the code, and also support for the Asus Tinker Board.
                      • F Offline
                        Frek
                        This is exactly what Im looking for. Im trying to get your module to run but Im first of all not a programmer (can do simple things in python an such)
                        I altered your python script to work with my skywriter board, easy enough. But i wonder how i set up the config file? Just load the module? If I do that I get a error that says "cannot find module “python-shell”
                        I was hoping the sensor would work behind the mirror to but it wont. I will put it on the inside of the frame insted…
                        • F Offline
                          Frek @Frek
                          I sorted it out. Didn’t have python-shell installed :)
                            Radu_Stancu
                            So you did you get it to work? I have an updated version if you are interested.
                              bolish
                              @Radu_Stancu
                              Did you considered using (and maybe tweaking a bit) the MMM-GroveGestures module and “only” replace the Grove Gesture Sensor (PAJ7620u2) by the Flick one?
                              It’s maybe a bit “basic thinking” from me but the MMM-GroveGestures plugin is really working great and both sensor seems to be based on the same working method / supplier / …
                              So maybe worth to consider it, don’t you think?
                              (would eb great for me at least, as I’m using MMM-GroveGestures and I’m interested into switching to the flick one).
                              Regards
                                Radu_Stancu
                                Sorry for my really late reply, I have been working on the module for a while, getting the mouse control to work.
                                As for your request, I did not know of the MMM-GroveGestures module. I had a look at it and the basic commands are basically the same although the code is written a bit differently. The gestures sequence though is a nice feature and I will look into that and try to do it the following days, but I am not really sure what actions should I bind to those new gestures.
                                Best regards,
                                Radu
                                • X Offline
                                  xne0n
                                  @Radu_Stancu
                                  Did you make some progress in your work, and so can you share it, I’d be glad to help with the module
                                    Radu_Stancu @xne0n
                                    @xne0n, I have made some progress, it runs perfectly smooth on the Asus Tinker board, I have managed to get mouse input working decently. It works by putting your finger close to the flick, the orange led turns on, and then the mouse follows your finger. It is not mouse pad like precision, but it gets the job done. I will update the source code, or maybe add it as a module on github after I finish writing my thesis.
                                    X kayakbabeK 2 Replies Last reply Reply Quote 1
                                    • X Offline
                                      xne0n @Radu_Stancu
                                      @Radu_Stancu very interesting ! ok thank you
                                      • kayakbabeK Offline
                                        kayakbabe @Radu_Stancu
                                        @Radu_Stancu I would really like to have a copy of your module. I’ve been working with the code you posted at the beginning of this topic thread and I’ve gotten tap added. But the wheel just crashes my flick. I’m building a mirror for my Dad and I’d like to surprise him with one he can control with the flick. It would really impress him.
                                        I hope you are still checking in on this magicmirror builders forum.
