    how to pull new element added to an array?
    57 Posts 4 Posters 24.4k Views 4 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @sdetweil
       start: function () {
              // Set locale.
              moment.locale(config.language);
              this.newsItems = [];
              this.loaded = false;
              this.activeItem = 0;
              this.scrollPosition = 0;
              this.registerFeeds();
      		"use strict";
              this.isShowingDescription = this.config.showDescription;
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        this is the default MM newsfeed, I am trying to modify it to show different things.
        Jim Hallock - 1995
          My last modification was this…
          https://forum.magicmirror.builders/assets/uploads/files/1539306174825-screenshot-140.png
          https://forum.magicmirror.builders/assets/uploads/files/1539306174825-screenshot-141.png
          https://forum.magicmirror.builders/assets/uploads/files/1539306174825-screenshot-142.png
          Jim Hallock - 1995
            sdetweil @justjim1220
            @justjim1220 the problem is that the newsItems array is set from the rest api to pull the entries from the source. THAT data does NOT contain the icon you want to use.
            your feed DEFINITION does , but not the feed response data…
            so, can u tell from an item which ‘feeds’ entry caused this entry to be in the data? (ie, tell its source)… and can you search the feeds to locate the feed definition from any data in the item?
            once u can do that, then u can use the feed entry icon
            justjim1220J 2 Replies Last reply Reply Quote 0
              Not quite sure I am following you correctly…
              Do you mean to pull the icon from the feeds source? the website?
              Jim Hallock - 1995
                ok, so how would I be able to use the corresponding icons/images for the active feed showing if there isn’t any icon data in the rest API?
                Jim Hallock - 1995
                  @justjim1220 you have to match up the feed definition (feeds array) with the element in the source response (newsItems array) somehow
                  the source does not send the icon back
                    that’s because I don’t think the source has an icon to pull from it.
                    So, is there a way to put the icons in an image folder in the newsfeed directory and pull from there for each corresponding newsfeed?
                    Jim Hallock - 1995
                      this is how I was able to modify the code to show a single icon and to get it to scroll across the screen
                      https://forum.magicmirror.builders/assets/uploads/files/1539381868184-screenshot-146.png
                      Jim Hallock - 1995
                        right… you hard coded it…
                        • 1 / 6
