    Default Module - Calender
    6 Posts 3 Posters 3.5k Views 1 Watching
      bjoern
      Hi, first of all I must say that I am not good in Java . But I have an idea that I would like transpose for the default module “calendar” . But I do not know where and how .
      Every time the when in calendar is an event that has the label " Birthday " or " … Sport " , the foregoing Icon should be change . For the birthday => Awesome.Icon " Birthday Cake " or sports icon " trophy " .
      Can someone help me to implement this ?
      • KirAsh4K Offline
        KirAsh4 Moderator
        That’s what the 'symbol' config option is for. Please read the instructions on how to set a symbol for your calendars:
        https://github.com/MichMich/MagicMirror/tree/master/modules/default/calendar
        Example:
                symbol: 'calendar-check-o ',
                symbol: 'calendar',
                url: 'https://calendar.google.com/calendar/ical/....'
          bjoern
          sorry, thats not my question. in your example i can set a symbol for a special calendar! i have only one calender. in this calender are event. for example: “Geburtstag Björn” or “Sport Cycling”. when the event is “Geburstag …” than i will change the symbol in front of the line by the event.
          • KirAsh4K Offline
            KirAsh4 Moderator
            That’s not possible with the current setup. You can only change the symbol on a per-calendar basis.
            • MichMichM Offline
              MichMich
              Not a supported feature, but the calendar supports text replacements. You might be able to replace “Geburtstag” with the HTML to display the icon: <i class="fa fa-birthday-cake"></i>. But since this an unsupported feature, this is as far as my support goes. :) Check the documentation and knock yourself out.
              Also note: MagicMirror² is built using Javascript, not Java (those are two different languages which might be important for you if you’re googeling …)
                bjoern
                thx MichMich! i will check later. thx
