    MMM-CalendarExt
    198 Posts 45 Posters 248.5k Views 45 Watching
      A Former User @Vauxdvihl
      @vauxdvihl
      Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
      Anyway, you can use like this;
       div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
         font-size: 250%;
         line-height:110%;
      (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
      • Y Offline
        yoey2112
        Hello @Sean ,
        Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
        -Yoey
          A Former User @yoey2112
          @yoey2112
          Which parts do you want to grow up? More details I need to help. Image could be a help.
          • Y Offline
            yoey2112
            So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
            Second, any suggestions on making it look a little popping?
            Thanks!
            justjim1220J 2 Replies Last reply Reply Quote 0
            • justjim1220J Offline
              justjim1220 Module Developer @yoey2112
              @yoey2112
              May I ask how you were able to show blank events?
              mine looks like this, all jumbled up and no blanks…
              "Life's Too Short To Dance With Ugly People"
              Jim Hallock - 1995
                @yoey2112
                add the following to your custum.css file
                 #CALEXT_month.tableStyle {
                  max-width:100%;
                  width:100%;
                  background:none;
                Jim Hallock - 1995
                  @Sean
                  Do you see the calendar posted above by @yoey2112 ?
                  It has blank events instead of collapsed events, I am wanting mine to look like that!
                  But, I can’t figure out how to get it done!
                  Jim Hallock - 1995
                  • Y Offline
                    yoey2112
                    @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                      @yoey2112
                      what did you add? I have been looking to do this!
                      the height is self-adjusting per the font sizes and line heights for the table cells.
                      May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                      Jim Hallock - 1995
                        A Former User @justjim1220
                        @justjim1220
                        I’ve already sent email for which was talked between us.
                        @yoey2112
                        For the whole module width;
                        .CALEXT .tableStyle {
                            margin:auto;
                            max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                        But it will be affected by your MM body width (By default, it has some margin)
                        • Y Offline
                          yoey2112
                          @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                            @yoey2112
                            Not easy, but I think possible.
                            It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                            .CALEXT .tableStyle td.slot {
                              max-height:150px;
                              height:150px;
                            Add above codes in your css/custom.css. Adjust the value for your purpose.
                            Then, in your config,
                              views: {
                                weeks: {
                                  overflowHeight:150,
                            For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                            But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                              bokifide
                              Hi! Love this module :) thank you.
                              Just wondering if there’s a way to omit Saturday and Sunday?
                              Been poking around and I haven’t been able to figure it out =/
                              Thanks ahead <3 :)
                                A Former User @bokifide
                                @bokifide
                                Add this to your css/custom.css
                                .day_6 {
                                  display:none;
                                .day_7 {
                                  display:none;
                                .CALEXT .tableStyle td {
                                  width:17%;
                                  bokifide
                                  @sean said in MMM-CalendarExt:
                                  .day_6 {
                                  display:none;
                                  .day_7 {
                                  display:none;
                                  width:17%;
                                  Worked!! Thank you so much, that’s perfect :)
                                    Doudy
                                    alt text
                                    How can I delete the text ‘in 15 hours’
                                    In addition it does not seem right to me.
                                    Or does this indicate the end of the event?
                                    module: 'MMM-CalendarExt',
                                    		colored: true,
                                    		        system: {
                                    		        show: ['current','daily'],
                                    		        locale: 'fr-be', //when omitted, default value would be your system default locale by moment.js
                                    			showEmptyView: 0,
                                    			fullDayEventLocalize: 0,
                                    			redrawInterval: 30*60*1000, //minimum 60000
                                    			userProfileConfig: 0,
                                    			startProfile: ''
                                    views: {
                                    	current: {
                                    		title: "Aujourdhui",
                                    		limit: 3,
                                    etc...
                                    Thanks![alt text]
                                    ? D 3 Replies Last reply Reply Quote 0
                                      A Former User @Doudy
                                      @doudy
                                      I’m on travel, so I’ll reply to you on Monday.
                                        Doudy @Doudy
                                        @doudy
                                          @doudy said in MMM-CalendarExt:
                                          How can I delete the text 'in 15 hours’
                                          add this in your ~/MagicMirror/css/custom.css
                                          .CALEXT .current .eventTime {
                                            display:none;
                                          Sorry, That’s not available.
                                            Doudy
                                            That is OK.
                                            • 10
                                            • 6 / 10
