    MMM-CalendarExt
    198 Posts 45 Posters 276.1k Views 45 Watching
      A Former User @yoey2112
      @yoey2112
      Which parts do you want to grow up? More details I need to help. Image could be a help.
      • Y
        yoey2112
        So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
        Second, any suggestions on making it look a little popping?
        Thanks!
        justjim1220J 2 Replies Last reply
        • justjim1220J
          justjim1220 Module Developer @yoey2112
          @yoey2112
          May I ask how you were able to show blank events?
          mine looks like this, all jumbled up and no blanks…
          Jim Hallock - 1995
          • justjim1220J
            @yoey2112
            add the following to your custum.css file
             #CALEXT_month.tableStyle {
              max-width:100%;
              width:100%;
              background:none;
            Jim Hallock - 1995
            • justjim1220J
              @Sean
              Do you see the calendar posted above by @yoey2112 ?
              It has blank events instead of collapsed events, I am wanting mine to look like that!
              But, I can’t figure out how to get it done!
              Jim Hallock - 1995
              ? 1 Reply Last reply
              • Y
                yoey2112
                @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                justjim1220J 1 Reply Last reply
                • justjim1220J
                  @yoey2112
                  what did you add? I have been looking to do this!
                  the height is self-adjusting per the font sizes and line heights for the table cells.
                  May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                  Jim Hallock - 1995
                    A Former User @justjim1220
                    @justjim1220
                    I’ve already sent email for which was talked between us.
                    @yoey2112
                    For the whole module width;
                    .CALEXT .tableStyle {
                        margin:auto;
                        max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                    But it will be affected by your MM body width (By default, it has some margin)
                    • Y
                      yoey2112
                      @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                        @yoey2112
                        Not easy, but I think possible.
                        It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                        .CALEXT .tableStyle td.slot {
                          max-height:150px;
                          height:150px;
                        Add above codes in your css/custom.css. Adjust the value for your purpose.
                        Then, in your config,
                          views: {
                            weeks: {
                              overflowHeight:150,
                        For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                        But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                        • bokifideB
                          bokifide
                          Hi! Love this module :) thank you.
                          Just wondering if there’s a way to omit Saturday and Sunday?
                          Been poking around and I haven’t been able to figure it out =/
                          Thanks ahead <3 :)
                            A Former User @bokifide
                            @bokifide
                            Add this to your css/custom.css
                            .day_6 {
                              display:none;
                            .day_7 {
                              display:none;
                            .CALEXT .tableStyle td {
                              width:17%;
                            • bokifideB
                              bokifide
                              @sean said in MMM-CalendarExt:
                              .day_6 {
                              display:none;
                              .day_7 {
                              display:none;
                              width:17%;
                              Worked!! Thank you so much, that’s perfect :)
                                Doudy
                                alt text
                                How can I delete the text ‘in 15 hours’
                                In addition it does not seem right to me.
                                Or does this indicate the end of the event?
                                module: 'MMM-CalendarExt',
                                		colored: true,
                                		        system: {
                                		        show: ['current','daily'],
                                		        locale: 'fr-be', //when omitted, default value would be your system default locale by moment.js
                                			showEmptyView: 0,
                                			fullDayEventLocalize: 0,
                                			redrawInterval: 30*60*1000, //minimum 60000
                                			userProfileConfig: 0,
                                			startProfile: ''
                                views: {
                                	current: {
                                		title: "Aujourdhui",
                                		limit: 3,
                                etc...
                                Thanks![alt text]
                                ? D 3 Replies Last reply
                                  A Former User @Doudy
                                  @doudy
                                  I’m on travel, so I’ll reply to you on Monday.
                                    Doudy @Doudy
                                    @doudy
                                      @doudy said in MMM-CalendarExt:
                                      How can I delete the text 'in 15 hours’
                                      add this in your ~/MagicMirror/css/custom.css
                                      .CALEXT .current .eventTime {
                                        display:none;
                                      Sorry, That’s not available.
                                        Doudy
                                        That is OK.
                                          cptkex
                                          hi! still loving your module but im having some issues :/
                                          i´ve been trying to add the code you have linked previously to make the calender bigger but i cant seem to stretch it to the screen sides?
                                          also, why is tuesday bigger then the rest?
                                          how do i remove the corners for each entry text?
                                          it doesnt seem to recognize my oneLineEvent: 1; ?
                                          any help is greatly appriciated
                                            A Former User @cptkex
                                            @cptkex
                                            First, I should know your whole CSS and Configuration to give detail and exact answer,
                                            Anyway,
                                            Add this into your MagicMirror/css/custom.css
                                                margin:0;
                                                max-width: 100%;
                                            More detailed adjustment could be needed. But most of case, this is enough.
                                            Because Tuesday has more long-text event than other day. I set this as relative-width. You can fix it by this.
                                                /* Set values for your environment or screen size */
                                                width: 17%;
                                                max-width: 17%;
                                                min-width: 17%;
                                            Or This.
                                              /* adjust for your screen size */
                                                width: 100px;
                                            #CALEXT_weeks.tableStyle .event.endHere .eventContainer{
                                              border:none;
                                              border-radius:0;
                                            #CALEXT_weeks.tableStyle .event.startHere {
                                              border:none;
                                              border-radius:0;
                                            It is working. So, Some events are showing only start time. If you grow the width of cell, you can see more clearly.
                                            Anyway, weeks and months types are not so good for Vertical Screen because vertical-width could be around 1080px,(Maximized, when you remove all the default margin of MM) It means each cell could have only 140px width at most. it would be not enough space for displaying event. You need to use smaller font size.
                                            (you’d better to learn some CSS skills if you have interests.)
                                            C 1 Reply Last reply
                                            • 10
                                            • 6 / 10
