    MMM-CalendarExt
    198 Posts 45 Posters 262.6k Views 45 Watching
    • V Offline
      Vauxdvihl @Guest
      @sean
      Thx a lot
      It works
      Greetz
        redink
        I just updated this module, and it stopped working. I even tried resting to the simple config from the readme, and nothing is coming up. Where can I see the logs for it to try and fix this?
          A Former User @redink
          @redink
          stop pm2 mm then npm start dev in your MM directory root.
          • V Offline
            Vauxdvihl
            @Sean
            Sorry to ask again
            Is there any possibility to increase a little bit the size of the letters?
            I mean the ones showing in the calendar as a “task”?
            thanks
              A Former User @Vauxdvihl
              @vauxdvihl
              You can adjust anything in CSS. (It could not be so easy but really funny)
              Or tell me which letters to be increased.
              • V Offline
                Vauxdvihl
                @Sean
                I want to play around with the following values
                Increase / Decrease “FINAL: SEA7 - OAK 6”
                Increase / Decrease “Time (04:05-07:05)”
                I am not a programmer :-)
                Thanks a lot
                  @vauxdvihl
                  Add this into your MagicMirror/css/custom.css file.
                  .CALEXT .eventTime {
                    font-size: 120%;
                    line-height:110%;
                  .CALEXT .eventContent {
                    font-size: 140%;
                    line-height:110%;
                  You can adjust these values with relative % or absolute px (Or many other various things)
                  https://www.w3schools.com/cssref/pr_font_font-size.asp
                  • V Offline
                    Vauxdvihl
                    @Sean
                    Thanks a lot
                    In custom css file a have the following:
                    div.CALEXT  .event .symbol {
                        order:1;
                        display:block;
                        flex-basis: 30px; // Modify this
                        text-align:center;
                        min-width: 50px; // Modify this
                        font-size: 150%; // Add this
                    div.CALEXT .events .symbol.emoji {
                        font-size: 150%; //Adjust this as your wish. you can use px or %
                    div.CALEXT .events .symbol.font-awesome {
                        font-size: 250%; //Adjust this as your wish. you can use px or %
                    div.CALEXT .tableStyle .eventTime {
                        display:block;
                      font-size: 80%;
                      line-height:110%;
                      font-size: 250%;
                      line-height:110%;
                    The adjustment of time works fine.
                    But not of the initial content.
                    Sorry
                    But can you please help again
                    Thanks a lot
                      @vauxdvihl
                      Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
                      Anyway, you can use like this;
                       div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
                         font-size: 250%;
                         line-height:110%;
                      (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
                      • Y Offline
                        yoey2112
                        Hello @Sean ,
                        Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
                        -Yoey
                          A Former User @yoey2112
                          @yoey2112
                          Which parts do you want to grow up? More details I need to help. Image could be a help.
                          • Y Offline
                            yoey2112
                            So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
                            Second, any suggestions on making it look a little popping?
                            Thanks!
                            justjim1220J 2 Replies Last reply Reply Quote 0
                            • justjim1220J Offline
                              justjim1220 Module Developer @yoey2112
                              @yoey2112
                              May I ask how you were able to show blank events?
                              mine looks like this, all jumbled up and no blanks…
                              Jim Hallock - 1995
                                @yoey2112
                                add the following to your custum.css file
                                 #CALEXT_month.tableStyle {
                                  max-width:100%;
                                  width:100%;
                                  background:none;
                                Jim Hallock - 1995
                                  @Sean
                                  Do you see the calendar posted above by @yoey2112 ?
                                  It has blank events instead of collapsed events, I am wanting mine to look like that!
                                  But, I can’t figure out how to get it done!
                                  Jim Hallock - 1995
                                  • Y Offline
                                    yoey2112
                                    @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                                      @yoey2112
                                      what did you add? I have been looking to do this!
                                      the height is self-adjusting per the font sizes and line heights for the table cells.
                                      May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                                      Jim Hallock - 1995
                                        A Former User @justjim1220
                                        @justjim1220
                                        I’ve already sent email for which was talked between us.
                                        @yoey2112
                                        For the whole module width;
                                        .CALEXT .tableStyle {
                                            margin:auto;
                                            max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                                        But it will be affected by your MM body width (By default, it has some margin)
                                        • Y Offline
                                          yoey2112
                                          @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                                            @yoey2112
                                            Not easy, but I think possible.
                                            It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                                            .CALEXT .tableStyle td.slot {
                                              max-height:150px;
                                              height:150px;
                                            Add above codes in your css/custom.css. Adjust the value for your purpose.
                                            Then, in your config,
                                              views: {
                                                weeks: {
                                                  overflowHeight:150,
                                            For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                            But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                                            • 10
                                            • 6 / 10
