    MMM-CalendarExt
    198 Posts 45 Posters 267.6k Views 45 Watching
      SK4018
      Hi all,
      I love the ‘daily’ view (as seen in the post just above), as it presents both events for 7 days and times. However, I want them it to stay at a “Monday to Sunday” order. Is this possible with the daily view? Thanks
        A Former User @SK4018
        @sk4018
        I think you can use weeks view instead daily view. But starting weekday depends on which locale are you using.
        • V Offline
          Vauxdvihl @Guest
          @sean
          Thx a lot
          It works
          Greetz
            redink
            I just updated this module, and it stopped working. I even tried resting to the simple config from the readme, and nothing is coming up. Where can I see the logs for it to try and fix this?
              A Former User @redink
              @redink
              stop pm2 mm then npm start dev in your MM directory root.
              • V Offline
                Vauxdvihl
                @Sean
                Sorry to ask again
                Is there any possibility to increase a little bit the size of the letters?
                I mean the ones showing in the calendar as a “task”?
                thanks
                  A Former User @Vauxdvihl
                  @vauxdvihl
                  You can adjust anything in CSS. (It could not be so easy but really funny)
                  Or tell me which letters to be increased.
                  • V Offline
                    Vauxdvihl
                    @Sean
                    I want to play around with the following values
                    Increase / Decrease “FINAL: SEA7 - OAK 6”
                    Increase / Decrease “Time (04:05-07:05)”
                    I am not a programmer :-)
                    Thanks a lot
                      @vauxdvihl
                      Add this into your MagicMirror/css/custom.css file.
                      .CALEXT .eventTime {
                        font-size: 120%;
                        line-height:110%;
                      .CALEXT .eventContent {
                        font-size: 140%;
                        line-height:110%;
                      You can adjust these values with relative % or absolute px (Or many other various things)
                      https://www.w3schools.com/cssref/pr_font_font-size.asp
                      • V Offline
                        Vauxdvihl
                        @Sean
                        Thanks a lot
                        In custom css file a have the following:
                        div.CALEXT  .event .symbol {
                            order:1;
                            display:block;
                            flex-basis: 30px; // Modify this
                            text-align:center;
                            min-width: 50px; // Modify this
                            font-size: 150%; // Add this
                        div.CALEXT .events .symbol.emoji {
                            font-size: 150%; //Adjust this as your wish. you can use px or %
                        div.CALEXT .events .symbol.font-awesome {
                            font-size: 250%; //Adjust this as your wish. you can use px or %
                        div.CALEXT .tableStyle .eventTime {
                            display:block;
                          font-size: 80%;
                          line-height:110%;
                          font-size: 250%;
                          line-height:110%;
                        The adjustment of time works fine.
                        But not of the initial content.
                        Sorry
                        But can you please help again
                        Thanks a lot
                          @vauxdvihl
                          Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
                          Anyway, you can use like this;
                           div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
                             font-size: 250%;
                             line-height:110%;
                          (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
                          • Y Offline
                            yoey2112
                            Hello @Sean ,
                            Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
                            -Yoey
                              A Former User @yoey2112
                              @yoey2112
                              Which parts do you want to grow up? More details I need to help. Image could be a help.
                              • Y Offline
                                yoey2112
                                So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
                                Second, any suggestions on making it look a little popping?
                                Thanks!
                                justjim1220J 2 Replies Last reply Reply Quote 0
                                • justjim1220J Offline
                                  justjim1220 Module Developer @yoey2112
                                  @yoey2112
                                  May I ask how you were able to show blank events?
                                  mine looks like this, all jumbled up and no blanks…
                                  Jim Hallock - 1995
                                    @yoey2112
                                    add the following to your custum.css file
                                     #CALEXT_month.tableStyle {
                                      max-width:100%;
                                      width:100%;
                                      background:none;
                                    Jim Hallock - 1995
                                      @Sean
                                      Do you see the calendar posted above by @yoey2112 ?
                                      It has blank events instead of collapsed events, I am wanting mine to look like that!
                                      But, I can’t figure out how to get it done!
                                      Jim Hallock - 1995
                                      • Y Offline
                                        yoey2112
                                        @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                                          @yoey2112
                                          what did you add? I have been looking to do this!
                                          the height is self-adjusting per the font sizes and line heights for the table cells.
                                          May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                                          Jim Hallock - 1995
                                            A Former User @justjim1220
                                            @justjim1220
                                            I’ve already sent email for which was talked between us.
                                            @yoey2112
                                            For the whole module width;
                                            .CALEXT .tableStyle {
                                                margin:auto;
                                                max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                                            But it will be affected by your MM body width (By default, it has some margin)
                                            • 10
                                            • 6 / 10
