    MMM-CalendarExt
    198 Posts 45 Posters 267.6k Views 45 Watching
      A Former User @Vauxdvihl
      @vauxdvihl
      Add this into your MagicMirror/css/custom.css file.
      .CALEXT .eventTime {
        font-size: 120%;
        line-height:110%;
      .CALEXT .eventContent {
        font-size: 140%;
        line-height:110%;
      You can adjust these values with relative % or absolute px (Or many other various things)
      https://www.w3schools.com/cssref/pr_font_font-size.asp
      • V Offline
        Vauxdvihl
        @Sean
        Thanks a lot
        In custom css file a have the following:
        div.CALEXT  .event .symbol {
            order:1;
            display:block;
            flex-basis: 30px; // Modify this
            text-align:center;
            min-width: 50px; // Modify this
            font-size: 150%; // Add this
        div.CALEXT .events .symbol.emoji {
            font-size: 150%; //Adjust this as your wish. you can use px or %
        div.CALEXT .events .symbol.font-awesome {
            font-size: 250%; //Adjust this as your wish. you can use px or %
        div.CALEXT .tableStyle .eventTime {
            display:block;
          font-size: 80%;
          line-height:110%;
          font-size: 250%;
          line-height:110%;
        The adjustment of time works fine.
        But not of the initial content.
        Sorry
        But can you please help again
        Thanks a lot
          @vauxdvihl
          Because your other CSS rules might override that rule. (Simpler rule name might have lower priority). See this. https://developer.mozilla.org/en-US/docs/Web/CSS/Specificity
          Anyway, you can use like this;
           div.CALEXT div.slot div.eventsBoard div.eventContainer div.eventContent {
             font-size: 250%;
             line-height:110%;
          (For more exact rule specificity, I should know whole CSS of your MM, but I believe above code enough)
          • Y Offline
            yoey2112
            Hello @Sean ,
            Been playing around with this module for a day now (not very savvy with javascript) and I cannot figure out how to increase the size of my Calendar. I’m using weeks (4 count) and position bottom_bar, but I would like it to take up about a third of the bottom (vertical monitor). I know this must be a change in CSS, but I dont know what to do. Any help would be great!
            -Yoey
              A Former User @yoey2112
              @yoey2112
              Which parts do you want to grow up? More details I need to help. Image could be a help.
              • Y Offline
                yoey2112
                So 2 things really. I’d like the Calendar to take up the entire bottom 3rd of the screen.
                Second, any suggestions on making it look a little popping?
                Thanks!
                justjim1220J 2 Replies Last reply Reply Quote 0
                • justjim1220J Offline
                  justjim1220 Module Developer @yoey2112
                  @yoey2112
                  May I ask how you were able to show blank events?
                  mine looks like this, all jumbled up and no blanks…
                  Jim Hallock - 1995
                    @yoey2112
                    add the following to your custum.css file
                     #CALEXT_month.tableStyle {
                      max-width:100%;
                      width:100%;
                      background:none;
                    Jim Hallock - 1995
                      @Sean
                      Do you see the calendar posted above by @yoey2112 ?
                      It has blank events instead of collapsed events, I am wanting mine to look like that!
                      But, I can’t figure out how to get it done!
                      Jim Hallock - 1995
                      • Y Offline
                        yoey2112
                        @justjim1220 I added that to my custom CSS but its still fairly small, a little bigger though. Is there any way to adjust the height of that location as well?
                          @yoey2112
                          what did you add? I have been looking to do this!
                          the height is self-adjusting per the font sizes and line heights for the table cells.
                          May be able to figure out a better way if I had the code you used to get the empty cells to show like that.
                          Jim Hallock - 1995
                            A Former User @justjim1220
                            @justjim1220
                            I’ve already sent email for which was talked between us.
                            @yoey2112
                            For the whole module width;
                            .CALEXT .tableStyle {
                                margin:auto;
                                max-width: 90%; /*  change to 100%  and if you want, you can add field `width` */
                            But it will be affected by your MM body width (By default, it has some margin)
                            • Y Offline
                              yoey2112
                              @Sean Can I also adjust the height of the calendar? Example, if I wanted the Calendar to take up the entire bottom half of a Vertical screen?
                                @yoey2112
                                Not easy, but I think possible.
                                It looks you are using weeks (4 weeks) view, So you can adjust the height of each day slot inweeks or months view with this;
                                .CALEXT .tableStyle td.slot {
                                  max-height:150px;
                                  height:150px;
                                Add above codes in your css/custom.css. Adjust the value for your purpose.
                                Then, in your config,
                                  views: {
                                    weeks: {
                                      overflowHeight:150,
                                For further details; https://github.com/eouia/MMM-CalendarExt/wiki/Manipulation-of-looks#viewlimit--viewoverflow
                                But there could be performance issue in RPI; https://github.com/eouia/MMM-CalendarExt/wiki/Performance-Issues
                                  bokifide
                                  Hi! Love this module :) thank you.
                                  Just wondering if there’s a way to omit Saturday and Sunday?
                                  Been poking around and I haven’t been able to figure it out =/
                                  Thanks ahead <3 :)
                                    A Former User @bokifide
                                    @bokifide
                                    Add this to your css/custom.css
                                    .day_6 {
                                      display:none;
                                    .day_7 {
                                      display:none;
                                    .CALEXT .tableStyle td {
                                      width:17%;
                                      bokifide
                                      @sean said in MMM-CalendarExt:
                                      .day_6 {
                                      display:none;
                                      .day_7 {
                                      display:none;
                                      width:17%;
                                      Worked!! Thank you so much, that’s perfect :)
                                        Doudy
                                        alt text
                                        How can I delete the text ‘in 15 hours’
                                        In addition it does not seem right to me.
                                        Or does this indicate the end of the event?
                                        module: 'MMM-CalendarExt',
                                        		colored: true,
                                        		        system: {
                                        		        show: ['current','daily'],
                                        		        locale: 'fr-be', //when omitted, default value would be your system default locale by moment.js
                                        			showEmptyView: 0,
                                        			fullDayEventLocalize: 0,
                                        			redrawInterval: 30*60*1000, //minimum 60000
                                        			userProfileConfig: 0,
                                        			startProfile: ''
                                        views: {
                                        	current: {
                                        		title: "Aujourdhui",
                                        		limit: 3,
                                        etc...
                                        Thanks![alt text]
                                        ? D 3 Replies Last reply Reply Quote 0
                                          A Former User @Doudy
                                          @doudy
                                          I’m on travel, so I’ll reply to you on Monday.
                                            Doudy @Doudy
                                            @doudy
                                            • 10
                                            • 6 / 10
