    I know it's here but I cannot seem to find it.....
    7 Posts 5 Posters 2.6k Views 4 Watching
    • cowboysdudeC Offline
      I know there’s a way to run one main mirror and off of that you can show other mirrors…
      Does anyone know how to do that? Since I"m running my big mirror on a mini-itx it seems that I should just be piggy-backing off of that one for my bathroom mirror rather then running another instance on that. Having to change multiple mirror instances.
      Thanks guys!
      @strawberry-3-141
      • justjim1220J Offline
        justjim1220 Module Developer
        @cowboysdude
        to get more than one instance of the same mirror on different screens, I had to create copies of the mirror and run separate electrons in different windows and assign them to each separate monitor. I just had to create different configs for each one. Yeah, I have to make duplicate changes, But, like you, I would think there is a different way!
        If using the same mirror config, you just need to run separate instances of electron and assign them to the appropriate screen.
        Jim Hallock - 1995
          pwknowlton
          @cowboysdude
          Are you thinking of the ‘client only’ and ‘server only’ instructions off of the MagicMirror builders repository?
            broberg Project Sponsor
            If you are okay with the “same” output on both mirrors you can just start a webbrowser in fullscren on the other mirror and open the page from the itx one.
            Since the magicmirror is basically a webserver hosting one webpage it can be open on an infinit amount of computers at the same time.
            • strawberry 3.141S Offline
              You linked me here, so you might thought about the syslog slave module that I was writing?!
                cowboysdude Module Developer @strawberry 3.141
                @strawberry-3-141 That’s very possible, I will look at it. I’m just kinda tired of working on 2 mirrors when just one and showing it in 2 places would be so much easier :)
                  cowboysdude Module Developer @broberg
                  @broberg I will look into that also…that’ll be a weekend thing :)
                  Thank you!!!
