    how to pull new element added to an array?
    57 Posts 4 Posters 29.6k Views 4 Watching
    • justjim1220J
      justjim1220 Module Developer @Guest
      @sean
      Not sure why, but this didn’t work for me, I will try it again in a little while, probably something I’m doing wrong!
      Thank You!!!
      Jim Hallock - 1995
      • justjim1220J
        @sean
        This is ABSOLUTELY WONDERFUL!!!
        THANK YOU, THANK YOU, THANK YOU!!! :smiling_face: :smiling_face: :smiling_face:
        (still gonna try to get the first one going you sent link for in previous post!) :winking_face:
        Jim Hallock - 1995
          @sean and I have the same solution to GET the image url, the use of the tickertape widget which supports image is the key trick
          justjim1220J 1 Reply Last reply
          • justjim1220J
            justjim1220 Module Developer @sdetweil
            Thank You for ALL your help on this, I think I have learned a lot doing this module!
            THANK YOU! THANK YOU ! THANK YOU! !!! :smiling_face: :smiling_face: :smiling_face:
            I’m looking at doing a bit of tweaking with each solution and when I get them done, I will commit to the repository and add to 3rd party list! :smiling_face_with_sunglasses:
            Jim Hallock - 1995
              sdetweil @justjim1220
              @justjim1220 the key for all these callbacks and .on() routines, is that you cannot WAIT for things to happen in a browser, else it stops functioning… click,… nothing happens…
              so, you have all these little event handlers… and YOU have to think about WHEN the happen relative to each other in time…
              justjim1220J 2 Replies Last reply
              • justjim1220J
                I get that now. Thanks!
                My only issue at the moment is getting the speed of the animation to go faster on my original that Sean fixed to work. His re-worked one is adjustable, mine won’t budge!
                I’ve even tried to incorporate some od the same coding he used in his, and I can’t figure it out! It is very weird!!!
                Jim Hallock - 1995
                • justjim1220J
                  ok, so here are some of the differences between the one we have been working on, and the one Sean reworked:
                  His truncates the description, I cannot figure out how to make it not truncate.
                  His images are set to height and width, Mine, I can set the height and the width is auto configured for aspect-ratio.
                  His shows the same message repeatedly for a period of time, then changes, Mine changes after each message.
                  with his, I can adjust the scroll speed, mine, I can’t figure out why it won’t change.
                  So, I am trying to figure out how to make the scroll adjustable as it goes really slow.
                  Jim Hallock - 1995
                  ? 1 Reply Last reply
                    A Former User @justjim1220
                    @justjim1220
                    I’ve just modified
                    • extracting logo from feed or config
                    • dom for ticker
                    Other features are derived from original or just side effects. As possible I can, I tried to remain the originals, but some features could be affected or changed.
                    If you want explains, I can do that next weekdays.
                    • justjim1220J
                      @sean
                      its no problem, I was able to figure it all out by comparing code.
                      Thank you so much for ALL your help!!!
                      Jim Hallock - 1995
                      • justjim1220J
                        I think I have it done!
                        Repository updated.
                        Put on list in 3rd Party Modules page
                        MMM-NewsFeedTicker
                        Now, If only I can remember how to make those gh-cards!!! LMAO!!!
                        Thanks Everyone who helped me with this!!!
                        Jim Hallock - 1995
                        • 3 / 3
