    MMM-Hotword problem with Black Screen
    2 Posts 1 Posters 1.4k Views 1 Watching
    • E
      eggwardo
      Hi, I’ve instaled MMM-AssistantMk2 and it seems to be working fine. I had a problem with blackscreen on that but used this post from a couple days ago to fix it.
      Now I’ve installed MMM-Hotword and am getting a black screen when i try to start my mirror with it configured. I believe snowboy is not installing, there isn’t a folder for it in “node_modules” (which, from my reading, I think there is supposed to be). I’ve run the “save snowboy” command a bunch of times but get the same errors every time.
      Any help would be appreciated.
      –edit-- I just realized i posted this in the main troubleshooting forum instead of the module troubleshooting. Should i delete and repost? Or can the Mods move it?
      pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install --save snowboy
      npm WARN deprecated hoek@2.16.3: The major version is no longer supported. Please update to 4.x or newer
      > snowboy@1.3.1 install /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
      > node-pre-gyp install --fallback-to-build
      node-pre-gyp ERR! Tried to download(403): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
      node-pre-gyp ERR! Pre-built binaries not found for snowboy@1.3.1 and node@10.11.0 (node-v64 ABI, glibc) (falling back to source compile with node-gyp)
      node-pre-gyp ERR! Tried to download(undefined): https://snowboy-release-node.s3-us-west-2.amazonaws.com/snowboy/v1.3.1/Release/snowboy-v1.3.1-node-v64-linux-arm.tar.gz
      internal/modules/cjs/loader.js:583
          throw err;
      Error: Cannot find module 'nan'
          at Function.Module._resolveFilename (internal/modules/cjs/loader.js:581:15)
          at Function.Module._load (internal/modules/cjs/loader.js:507:25)
          at Module.require (internal/modules/cjs/loader.js:637:17)
          at require (internal/modules/cjs/helpers.js:20:18)
          at [eval]:1:1
          at Script.runInThisContext (vm.js:96:20)
          at Object.runInThisContext (vm.js:303:38)
          at Object.<anonymous> ([eval]-wrapper:6:22)
          at Module._compile (internal/modules/cjs/loader.js:689:30)
          at evalScript (internal/bootstrap/node.js:576:27)
      gyp: Call to 'node -e "require('nan')"' returned exit status 1 while in binding.gyp. while trying to load binding.gyp
          throw err;
          at [eval]:1:1
      gypgyp ERR!  configure error
      gyp ERR! gypstack Error: `gyp` failed with exit code: 1
      gyp  ERR!ERR!  stack     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
      stackgyp Error: `gyp` failed with exit code: 1
       gypERR!  stackERR!     at ChildProcess.emit (events.js:182:13)
       stackgyp     at ChildProcess.onCpExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/configure.js:345:16)
       ERR!gyp  stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
      ERR! stack     at ChildProcess.emit (events.js:182:13)
      gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:240:12)
      gyp ERR! System Linux 4.14.50-v7+
      gyp ERR! Systemgyp Linux 4.14.50-v7+
       ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
      gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
      gyp gypERR! node -v  v10.11.0
      ERR! gypcommand  "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "configure" "--fallback-to-build" "--module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node" "--module_name=snowboy" "--module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm"
      ERR! node-gyp -v v3.8.0
      gyp ERR! not okgyp
      gyp ERR! node -v v10.11.0
      gyp ERR! node-gyp -v v3.8.0
      gyp ERR! not ok
      node-pre-gyp ERR! build error
      node-pre-gyp ERR! stack Error: Failed to execute '/usr/bin/node /usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js configure --fallback-to-build --module=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm/snowboy.node --module_name=snowboy --module_path=/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/lib/node/binding/Release/node-v64-linux-arm' (1)
      node-pre-gyp ERR! stack     at ChildProcess.<anonymous> (/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/node-pre-gyp/lib/util/compile.js:83:29)
      node-pre-gyp ERR! stack     at ChildProcess.emit (events.js:182:13)
      node-pre-gyp ERR! stack     at maybeClose (internal/child_process.js:962:16)
      node-pre-gyp ERR! stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:251:5)
      node-pre-gyp ERR! System Linux 4.14.50-v7+
      node-pre-gyp ERR! command "/usr/bin/node" "/home/pi/MagicMirror/modules/MMM-Hotword/node_modules/.bin/node-pre-gyp" "install" "--fallback-to-build"
      node-pre-gyp ERR! cwd /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
      node-pre-gyp ERR! node -v v10.11.0
      node-pre-gyp ERR! node-pre-gyp -v v0.6.39
      node-pre-gyp ERR! not ok
      npm WARN MMM-Hotword@1.0.0 No repository field.
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! snowboy@1.3.1 install: `node-pre-gyp install --fallback-to-build`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the snowboy@1.3.1 install script.
      npm ERR!     /home/pi/.npm/_logs/2018-10-21T03_32_36_367Z-debug.log
      • E
        eggwardo
        I’m going to call this solved, kinda. I restarted from scratch and got it to work. Snowboy was not installing for some reason. Possibly my raspbian was not up to date. But we’ll never know.
