    Need some advise. Digital Ocean Modules
    19 Posts 2 Posters 12.7k Views 2 Watching
      andrewchumchal @strawberry 3.141
      @strawberry-3.141
      Any ideas where i can start? like where i can get the name and status.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @andrewchumchal
        @andrewchumchal
        for(var i = 0; i < this.droplets.droplets.length; i++;){
            var name = this.droplets.droplets[i].name;
            var status = this.droplets.droplets[i].status;
            var ip = '';
            for(var n = 0; n < this.droplets.droplets[i].networks['v4'].length; n++;){
                ip += this.droplets.droplets[i].networks['v4'].ip_address + ' | ';
            for(var n = 0; n < this.droplets.droplets[i].networks['v6'].length; n++;){
                ip += this.droplets.droplets[i].networks['v6'].ip_address + ' | ';
            ip = ip.replace(/ | $/, '');
          @strawberry-3.141
          sorry to bug you so much dose that go in the get dom ?
            @andrewchumchal this is just how you can access status name and the ip in getDom for example but you still need to render this
              andrewchumchal
                andrewchumchal
                @strawberry-3-141 Hey. I was not able to get it to display it last night. I try everything i could. Any more ideas ?
                  @andrewchumchal
                  getDom: function() {
                      if(this.droplets){
                          var table = document.createElement("table");
                          for(var i = 0; i < this.droplets.droplets.length; i++){
                              var row = document.createElement("tr");
                              var name = document.createElement("td");
                              name.innerHTML = this.droplets.droplets[i].name;
                              row.appendChild(name);
                              var status = document.createElement("td");
                              status.innerHTML = this.droplets.droplets[i].status;
                              row.appendChild(status);
                              var ips = '';
                                  ips += this.droplets.droplets[i].networks['v4'][n].ip_address + ' | ';
                                  ips += this.droplets.droplets[i].networks['v6'][n].ip_address + ' | ';
                              ips = ips.replace(/ | $/, '');
                              var ip = document.createElement("td");
                              ip.innerHTML = ips;
                              row.appendChild(ip);
                              table.appendChild(row);
                          wrapper.appendChild(table);
                      } else {
                          wrapper.innerHTML = "No data to show!";
                      return wrapper;
                    @strawberry-3.141
                    I just update my code.
                    And i have a droplet created but it shows no data to show ?
                      @andrewchumchal this is all untested and should give you just a direction on how it could be solved. make sure you update the dom when receiving data
                      socketNotificationReceived: function(notification, payload){
                          if(notification === "DATA"){
                             this.droplets = payload;
                             this.updateDom();
                        andrewchumchal
                        Thanks you so much @strawberry-3-141.
