    Darksky weather module not loading
    18 Posts 5 Posters 9.0k Views 4 Watching
    • K Offline
      Kaviish @Lolololito
      • K Offline
        Kaviish @Mykle1
        @mykle1 I did follow what the readme said but still it isn’t loading
          AxLed Module Developer
          @Kaviish
          It looks that there is a comma to much.
          Try
          longitude: 72.8777
          instead of
          longitude: 72.8777,
          AxLED
          • K Offline
            Kaviish @AxLed
            @axled still not working. Opened console this is wat i got. 0_1540729568319_Screenshot 2018-10-28 at 5.55.24 PM.png
              Mykle1 Project Sponsor Module Developer @Kaviish
              @kaviish
              Looking at that error message it appears your latitude is 149.076. That will break the module. Clear the latitude line of your config entry and re=enter.
              • K Offline
                Kaviish
                What does that mean the latitude on my config file is 19.0760
                  @kaviish said in Darksky weather module not loading:
                  Not according to the console error message you posted.
                    buzzman
                    @Kaviish
                    here is mine lat and long . you need the ’ at the start and at the end of the number .it works great
                    ‘43.xxxx’,
                    ‘-88.xxxx’
                      Mykle1 Project Sponsor Module Developer @buzzman
                      @buzzman said in Darksky weather module not loading:
                      No sir, you do not need the quotes, nor are they called for in the readme. However, it does work with the quotes but that is not his issue at this point.
                      • K Offline
                        Kaviish @Mykle1
                        @mykle1 so should I delete the module and download it again?
