    A magic mirror based on Raspberry Pi3B, Respeaker sensor and google assistant (Tutorial Inside)
    6 Posts 4 Posters 10.0k Views 5 Watching
      Rosley GE
      I did a magic mirror with ReSpeaker 4 Mic Linear Array to add voice interface to a Magic Mirror. It is very interesting. Children like it so much. hahah
      As using a 4 Mic Linear Array, we are able to detect sound Direction of Arrial (DOA) which can be used to provide some creative functions. We can use beamforming to enhance a specific direction’s sound. It is really a good sensor to do voice related projects. The link is as below.
      respeaker-mic
      alt text
      Bild Text
      Material:
      Raspberry Pi 3B
      ReSpeaker 4 Mic Linear Array(sound card)
      HDMI display
      two way mirror
      frame
      SD card
      Raspberry Pi 3B
      HDMI display
      two way mirror
      frame
      SD card
      :grinning_face_with_smiling_eyes:
      Software Tutorial for you
      Setup Raspberry Pi
      Download a customized pi image, which includes the sound card’s driver and some voice related packages (Do not use the lite version for we need desktop enviroment to show GUI). We can write the image to a SD card with rufus (very tiny but only for windows) or ether.
      If you don’t have any extra keyboard to access and configure the Raspberry Pi, you can setup WiFi configuratio and enable SSH before first time boot. To do that, Juse add a file named ssh to the boot partition of the SD card, which enables SSH, and then create a file named wpa_supplicant.conf with the following content, replace ssid and psk with yours
      country=GB
      ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
      update_config=1
      network={
           ssid="WiFi SSID"
           psk="password"
      Power on your Pi, use Pi’s IP or raspberry.local(requires mDNS support, need to install Bonjour on Windows) to login via ssh (On Windows, putty is a handy ssh client).
      alt text
      Install Magic Mirror
      To install Magic Mirror software package, just run:
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      This command will clone MagicMirror repository from github to ~/MagicMirror, install node, npm and other dependencies.
      Note: Do not use apt install to install node and npm, node and npm in the deb repository is kind of outdated. Remove them if already installed.
      Install Magic Mirror modules: MMM-Remote-Control and MMM-kalliope
      cd ~/MagicMirror/modules
      git clone https://github.com/kalliope-project/MMM-kalliope.git
      git clone https://github.com/Jopyth/MMM-Remote-Control.git
      cd MMM-Remote-Control
      npm install
      and then add the configuration of MMM-Remote-Control and MMM-kalliope to moddules of ~/MagicMirror/config/config.js
          module: "MMM-kalliope",
          position: "upper_third",
              title: "",
              max: 1
          module: 'MMM-Remote-Control'
          // , position: 'bottom_left'
      restart MagicMirror to enable the new configuration. Use the following command to test if we can send a message to MagicMirror
      curl -H "Content-Type: application/json" -X POST -d '{"notification":"KALLIOPE", "payload": "my message"}' http://localhost:8080/kalliope
      Configure Weather module
      By default, a weather module using OpenWeatherMap is included, we need sign up OpenWeatherMap to get a API key and fill the key to ~/MagicMirror/config/config.js
      Set Google Assistant
      Go to Introduction to the Google Assistant Library to install and setup Google Assistant Library
      After authorization, we can just run mirror_with_google_assistant.py to start the Google Assistant for the Mirror.
      • zdenekZ
        zdenek
        @rosley-ge said in A magic mirror based on Raspberrt Pi3B, Respeaker sensor and google assistant (Tutorial Inside):
        respeaker-mic
        wow, looks great. I’ve no expirience connecting any HW to RPi. Can u plese give StepByStep how to connect Mic+Repro?
        thanks, Zdeněk
          Rosley GE
          Zdenek,
          Don’t worry. It is very easy. The respeaker mic sensor has many detailed connection guidance. You can visit respeaker wiki first.
          Respeaker-wiki
          If you have any question, I am happy to share my experience.
            canadrian
            Looks beautiful.
            Where I can download the image from? Thanks.
              Peter
              Interesting!
              Are MM and GA independend or can you influence MM with GA (like showing or hiding modules)?
              I think I made my mirror in the same way.
              I have the original Google AIY kit in my MM.
              They work independend: I can ask Google any kind of questions, set timers and turn on the gardenlights and the fountain in the pond with my voice.
              But I cannot hide or show modules with voice.
              I am very interested in integrating MM and GA, but I do not know how.
              Peter
                Rosley GE @canadrian
                @canadrian Just download it from Raspberry Pi official website. It is convenient.
