Unsolved Problem with the Module "email"
ok, i changed it. Thanks for the information -
@cyrus1337 thank you…
But I have not come further. Is there something wrong with my config?
@cyrus1337 ok, I cut/pasted your config, changed to my userid and password…
failed… module imap not found…
had to run npm install from the modules/email folder…
restart mirror…
note: this only shows NEWLY arriving email… i don’t know how the mail drops off, as it hasn’t updated for me… 5 emails shown…
@sdetweil I did that you’ve got. Unfortunately without success
pi@raspberrypi2:~ $ cd MagicMirror pi@raspberrypi2:~/MagicMirror $ cd modules pi@raspberrypi2:~/MagicMirror/modules $ cd email pi@raspberrypi2:~/MagicMirror/modules/email $ npm install npm WARN email@0.0.1 No repository field. npm WARN email@0.0.1 No license field. audited 24 packages in 4.491s found 0 vulnerabilities pi@raspberrypi2:~/MagicMirror/modules/email $ sudo reboot login as: pi pi@192.168.1.102's password: Linux raspberrypi2 4.14.67-v7+ #1139 SMP Wed Aug 29 15:17:05 BST 2018 armv7l The programs included with the Debian GNU/Linux system are free software; the exact distribution terms for each program are described in the individual files in /usr/share/doc/*/copyright. Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent permitted by applicable law. Last login: Thu Nov 8 20:03:08 2018 from 192.168.1.134 pi@raspberrypi2:~ $
@cyrus1337 ok , open a command prompt so we can look at the error output…
then cd MagaicMirror and type
npm starti see stuff like this
> magicmirror@2.5.0 start /home/odroid/Magi > sh run-start.sh Starting MagicMirror: v2.5.0 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: calendar Initializing new module helper ... Module helper loaded: newsfeed handler helper in init Module helper loaded: MMM-SleepWake Initializing new module helper ... Module helper loaded: MMM-ImagesPhotos Initializing new module helper ... Module helper loaded: MMM-BMW-DS All module helpers loaded. Starting server on port 8086 ... You're using a full whitelist configuration Server started ... Connecting socket for: updatenotification Connecting socket for: calendar Starting node helper for: calendar Connecting socket for: newsfeed Starting module: newsfeed Connecting socket for: MMM-SleepWake handler helper in start Connecting socket for: MMM-ImagesPhotos Starting node helper for: MMM-ImagesPhotos Connecting socket for: MMM-BMW-DS Starting node_helper for: MMM-BMW-DS Sockets connected & modules started ... Launching application.
@sdetweil Thanks for the help, I will post my log tonight
I also see things like you. Here are my logs:
pi@raspberrypi2:~ $ cd MagicMirror pi@raspberrypi2:~/MagicMirror $ npm start > magicmirror@2.5.0 start /home/pi/MagicMirror > sh run-start.sh Starting MagicMirror: v2.5.0 Loading config ... Loading module helpers ... No helper found for module: alert. Initializing new module helper ... Module helper loaded: updatenotification No helper found for module: clock. Initializing new module helper ... Module helper loaded: MMM-SystemStats Initializing new module helper ... Module helper loaded: MMM-MyCommute Initializing new module helper ... Module helper loaded: newsfeed Initializing new module helper ... Module helper loaded: MMM-GoogleMapsTraffic No helper found for module: MMM-PIR-Sensor. Initializing new module helper ... Module helper loaded: MMM-SoccerLiveScore Initializing new module helper ... Module helper loaded: MMM-MyCalendar Initializing new module helper ... Module helper loaded: email All module helpers loaded. Starting server on port 8080 ... Server started ... Connecting socket for: updatenotification Connecting socket for: MMM-SystemStats Connecting socket for: MMM-MyCommute ====================== Starting node_helper for module [MMM-MyCommute] Connecting socket for: newsfeed Starting module: newsfeed Connecting socket for: MMM-GoogleMapsTraffic Starting node_helper for module: MMM-GoogleMapsTraffic Connecting socket for: MMM-SoccerLiveScore MMM-SoccerLiveScore helper started... Connecting socket for: MMM-MyCalendar Starting node helper for: MMM-MyCalendar Connecting socket for: email email helper started ... Sockets connected & modules started ... Launching application. Create new news fetcher for url: https://api.20min.ch/rss/view/1 - Interval: 300000 Create new news fetcher for url: https://api.20min.ch/rss/view/67 - Interval: 300000 Working notification system. Notification: MMM-GOOGLE_MAPS_TRAFFIC-GET payload: { style: 'standard' } Create new calendar fetcher for url: https://calendar.google.com/calendar/ical/zeptrion%40gmail.com/private-75149d8982f910a209e0fe7d0363d75f/basic.ics - Interval: 300000 listening for emails...
Looks good. What happens when you send a new mail to the emailaddress when the logs shows listening for email?
@cirdan said in Problem with the Module "email":
I could try that :) Also, I have 1 unread email in the folder. But I’m trying to send an email to myself tonight and see what happens.
I’ll call you tonight
