    MMM-Hue
    huehome automation
    25 Posts 16 Posters 28.6k Views 17 Watching
    • slametpsS Offline
      slametps
      @Mitchfarino : I did a pull-request for Indonesian translation and showLabel option to your MMM-Hue module.
      regards,
      Slamet PS
        schlachtkreuzer6
        hi!
        show only when on does not work for me… any tip? thanks!
          shane1234
          Would it be possible to have the icons match the color of the lights and/or display an icon for each light in the room?
            sirdizzle
            Can anyone assist me in configuring the module correctly?
            I have it set up, but having trouble filtering out more than one group via hideGroupsWithString
            Currently, I have hideGroupsWithString: "Custom group for $lights" and that works, but I’m not sure how to add more groups to the string correctly.
            I know this is an old thread, but any help would be appreciated.
              Mikrosoft
              Hi just installing this module and have set all id and ip correct and the only thing i have changed is made it bottom_left in the css file but i have nothing showing up when i load.
              what am i doing wrong ?
                Smotx @sirdizzle
                @sirdizzle said in MMM-Hue:
                Same question here.
                I want to hide my dimmer and hgrp.
                Thanks for help
                • WayneRigleyW Offline
                  WayneRigley
                  i ended up getting the Hue Module to work as preset config options. if i turn on the lights there is a long delay in showing on the Magic Mirror, but it does show after a while in our bedroom group. i have 6 bulbs in our bedroom group so if i change the Hue config file from groups to lights and restart the MM all the lights and names show up with an “x” and its impossible to get the MM to show the lights are ON … any help > as i want to add several bulbs arond the house NOT on a schedule and at a glance see where things are…
                  Wayne R
                  • F Offline
                    freescl
                    Hello there,
                    I am experiencing issues with getting MMM-hue to show on the screen.
                    I have successfully created a hue bridge user id, so maybe my config is wrong?
                    		    module: 'MMM-Hue',
                    		    position: 'top_right',
                    		    config:{
                                    	bridgeip: "192.168.xxx.xxx",
                    		        userid: "MY-ID-OF-HUE-BRIDGE",
                                   		colour: false
                    Can anyone help?
                    Thanks,
                    • F Offline
                      freescl @freescl
                      @freescl
                      Just found out, that copying the Module to default modules folder helps to get it run… Hope it helps someone else :)
                      • citizendevpiC Offline
                        citizendevpi
                        I am getting a no data returned on my display how can i fix this?
                          Mitchfarino Module Developer
                          Hi all,
                          I just wanted to update, that I have moved away from the Hue Bulbs/Bridge so I haven’t been able to work with this module for some time now.
                          Hopefully someone has forked it and resolved any issues.
                          I do still have my bridge and bulbs, just switched them out for alternatives. I may switch back at some point.
                          • mumblebajM Offline
                            mumblebaj Module Developer @Mitchfarino
                            @Mitchfarino What a pity though. The module works perfectly for me though. There are some instructions missing though but I managed to get it up and running when I first implemented it a few months ago. Great module.
                              dazza120
                              Not a fork but hue lights https://github.com/michael5r/mmm-hue-lights
