    MMM-BackgroundSlideshow
    23 Posts 5 Posters 12.9k Views 5 Watching
    • CyruS1337C Offline
      CyruS1337 Project Sponsor
      I have a question about the background photos. I’ve found that the images are larger when viewed on the raspberry than when I look at them on the PC.
      I am using the MMM BackgroundSlideshow module to display a new image every 10 seconds.
      In custom.css I have the following codes deposited:
       * Magic Mirror                                      *
       * Custom CSS                                        *
       * By Michael Teeuw http://michaelteeuw.nl           *
       * MIT Licensed.                                     *
       * Add any custom CSS below.                         *
       * Changes to this files will be ignored by GIT. *
      .MMM-SystemStats  {
              color: #CEF6CE;
      .normal,
      .dimmed,
      header,
      .MMM-BackgroundSlideshow  {
          color: #fff;
      .MMM-EasyPix  {
              font-weight: 400;
      .MMM-SystemStats {
          font-size: 45%;
      .MMM-darksky-hourly {
      	color: #ffffff;
      Can someone tell me why the PI are “bigger” than when I look at them on the PC
      That’s still my config
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	address: "0.0.0.0", // Address to listen on, can be:
      	port: 8080,
      	language: "de",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			module: "compliments",
      			position: "lower_third"
      	disabled: false,
          module: "MMM-NewsFeedTicker",
      	position: "bottom_bar",
      	//classes: "day_scheduler",
      	    feeds: [
      			title: "20 min",
      			url: "https://api.20min.ch/rss/view/67",
      			encoding: "UTF-8", //ISO-8859-1
      			className: "myClass",
      			defaultLogo : ""
      	 module: 'internet-monitor',
      	 position: 'top_center',
      		 type: 'minimal',
      		 maxTime: 7000,
      		 updateInterval: 120000,
      		 verbose: false,
      		 displayStrength: true,
      		 displaySpeed: false,
      		 strengthIconSize: 40,
      		 maxGaugeScale: 25,
      		 wifiSymbol:{
      			 fullColor: '#3afc25',
      			 almostColor: '#ffff0c',
      			 halfColor: '#ff8c00',
      			 noneColor: '#ff1111'
          module: 'MMM-darksky-hourly',
          position: 'top_right',  // This can be any of the regions.
            apiKey: 'xxx', // Dark Sky API key.
            latitude:   47.309714,
            longitude: 7.8106514,
      		module: 'MMM-SystemStats',
      		position: 'bottom_left', // This can be any of the regions.
      		classes: 'small dimmed', // Add your own styling. Optional.// classes: 'small dimmed',
      		// header: 'System Stats', // Set the header text OPTIONAL
      			updateInterval: 10000, // every 10 seconds
      			align: 'right', // align labels
      			view: 'textAndIcon',
          module: "MMM-EasyPix",
      	header: "WLAN-Code",
      	position: "bottom_right",
      		picName: "guest_wifi_config.png", // Enter the picture file name.
      		maxWidth: "100%",        // Size picture precisely. Retains aspect ratio.
          module: 'MMM-BackgroundSlideshow',
          position: 'fullscreen_below',
            imagePaths: ['modules/MMM-BackgroundSlideshow/Amerika_2018'],
            transitionImages: true,
            randomizeImageOrder: true
        //disabled:true,
        module: "MMM-AVStock",
        position: "top_right", //"bottom_bar" is better for `mode:ticker`
          apiKey : "WPYPLO6M92PTF7PB", // https://www.alphavantage.co/
          timeFormat: "YYYY-MM-DD HH:mm:ss",
          symbols : ["aapl", "GOOGL", "005930.KS", "SCHN.SW", "UBS", "NOVN.VX",],
          alias: ["Apple", "Google", "SAMSUNG Electronics", "Schindler", "UBS", "Novartis",], //Easy name of each symbol. When you use `alias`, the number of symbols and alias should be the same. If value is null or "", symbol string will be used by default.
          tickerDuration: 60, // Ticker will be cycled once per this second.
          chartDays: 90, //For `mode:series`, how much daily data will be taken. (max. 90)
          poolInterval : 1000*15, // If your AV account is free, at least 13 sec is needed.
          mode : "table", // "table", "ticker", "series"
      			module: "newsfeed",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
        Ok, thanks for your help. I downloaded the program PhotoScape and changed the height and width of all photos. Look, there you go !! Thank you
          Enclosed I send you the two different views. Once on the PI and once on the PC monitor.
          Bild Text
          Bild Text
            A Former User @CyruS1337
            @cyrus1337
            I’m not sure, I don’t know anything about backgroundSlideShow, but,
            Your pictures would be greater than resolution of screen.
            Then, your PC viewer might have resized your pictures automatically when they were shown. But backgroundSlideShow might not have that feature. However, there is a possibility of controlling by CSS. Ask to creator.
            CyruS1337C 1 Reply Last reply Reply Quote 0
              CyruS1337 Project Sponsor @Guest
              @sean Thanks for your quick reply.
              garblefluxG 1 Reply Last reply Reply Quote 0
              • garblefluxG Offline
                garbleflux Project Sponsor @CyruS1337
                @cyrus1337 said in MMM-BackgroundSlideshow:
                I also use this module very successfully. Try to resize the pictures to the resolution of your screen (photoshop), normaly 1920 x 1080, 1024 x 760. Sometimes it is also necessary to set the pictures to the correct aspect ratio 16:9. For me it works fine.
                Regards Mike
                  sdetweil @garbleflux
                  @garbleflux i had to modify another image display module to get the correct presentation of images, no zoom in and no crop of portrait mode. does mean that some of the background shows thru, but the pictures are correctly displayed
                  CyruS1337C 1 Reply Last reply Reply Quote -1
                    CyruS1337 Project Sponsor @sdetweil
                    @sdetweil And what would be your module :)
                      sdetweil @CyruS1337
                      @cyrus1337 I am using the MMM-ImagePhotos module… but I had to change the code to keep my images properly formatted…
                      landscape
                      https://www.dropbox.com/s/adzzi3bc7wwq8q5/IMG_20181114_102356.jpg?dl=0
                      portrait
                      https://www.dropbox.com/s/htxdm7b8sayqazh/IMG_20181114_102350.jpg?dl=0
                      can’t get the pics to actually display here…
                        A Former User
                        I made several modules handling photos - MMM-GooglePhotos, MMM-WeatherBackground, MMM-DropboxWallpaper,…
                        All modules can display photos by its aspect-ratio with covering the target area or resizing to show whole picture.
                        Try them.
                        • MMM-DropboxWallpaper (https://github.com/eouia/MMM-DropboxWallpaper)
                        • MMM-GooglePhotos (https://github.com/eouia/MMM-GooglePhotos)
                        S CyruS1337C 2 Replies Last reply Reply Quote 0
                          A Former User
                          Anyway, If your module would be using img tag for showing photos, module should know the exact image size and calculate to resize it by proper target ratio.
                          Instead, I prefer using Background CSS trick. background-size:cover will cover whole image to entire area of it’s element, background-size:contain will resize image to fit to target element size. Suprisingly, without any calculation.
