SOLVED Why keeps MM2 starting even when I've pressed ctrl+Q?
I just have installed MM2 and I would like to make changes now to the setup of MM2 but when I press Alt and close the MM2 (or use Ctrl+Q) after a few seconds MM2 is up and running agian!!
How can I stop this? I would like to have MM2 to start after the Pi has booted or after I started it from the commanline. Not on it’s own! -
@mwel1977 I use an ssh session from my Windows box and kill the npm start process. Actually a little script kills all node related tasks
@sdetweil: I’m just starting with a raspberry pi (well… I have Domoticz running on a Pi zero W to check my plants) so I have no idea how to make/write a script like that.
But I just rebooted my pi and MM2 didn’t start. So I can make changes to the setting now and start MM2 via the commandline. -
@mwel1977 The reason seems to be pm2. You seem to have that installed. It runs a script always restarting MagicMirror after you close it.
To close MagicMirror properly if you have pm2 running do apm2 stop mm
or however your process was called. You can find the name of the process running
pm2 status
Other useful commands
pm2 restart mm pm2 start mm.sh //Name of the shell file that has been created by YOU!
