    Can't find out what I did wrong in my config.js...
    7 Posts 3 Posters 2.4k Views 3 Watching
    • evroomE Offline
      evroom
      Perhaps this is a start, provided I copy/pasted it right ?
      Although I think you are familiar with this and used other linters to find the ‘mistake’.
      pi@MagicPi:~/MagicMirror $ cd ~/MagicMirror; npm run config:check
      Checking file...  /home/pi/MagicMirror/config/config.js
      Line 213 col 42 Missing semicolon.
      Line 218 col 18 Missing semicolon.
      Line 222 col 5 Expected '}' to match '{' from line 190 and instead saw '{'.
      Line 223 col 7 Expected ']' to match '[' from line 28 and instead saw 'module'.
      Line 223 col 13 Expected '}' to match '{' from line 11 and instead saw ':'.
      Line 223 col 14 Missing semicolon.
      Line 224 col 7 Expected an assignment or function call and instead saw an expression.
      Line 224 col 15 Missing semicolon.
      Line 224 col 7 Unrecoverable syntax error. (94% scanned).
      I think you missed a } around line 220.
      The “Missing semicolon” messages normally are just nitpicking, but the "Expected ‘}’ to match ‘{’ " are usually true.
      MagicMirror version: 2.33.0
      Test environment:
      MagicMirror version: v2.33.0
      Cr4z33C 2 Replies Last reply Reply Quote 0
      • Cr4z33C Offline
        Cr4z33 @evroom
        @evroom thanks for the help I give it immediately a look. :)
        Also didn’t know that terminal command.
        • Cr4z33C Offline
          Cr4z33 @evroom
          @evroom found out the mistake thanks to your suggestion:
          I missed to add an additional close curly bracket after line 213!
          • evroomE Offline
            evroom
            Glad to help.
            So many errors after only one mistake (the most common to make; we all did it sometime I guess) :slightly_smiling_face:
            Test environment:
            • Cr4z33C Offline
              Cr4z33 @evroom
              @evroom lol indeed! :grinning_face_with_smiling_eyes:
              • BKeyportB Offline
                BKeyport Module Developer
                Wait, you can audit the config file right from NPM?
                Daaaaaaaaaaaaaaaaaaaang.
