    Strange issue
    24 Posts 6 Posters 12.5k Views 6 Watching
    • richland007R
      richland007 @evroom
      @evroom Mine is not slow it works “fine” it just keeps restarting
      I am really curious to see the output of that file and see whats causing this behavior
      D
      • V
        vinp Module Developer
        If previous suggestions dont help, try removing the MMM-WatchDog module and see if it crashes anymore.
        • evroomE
          evroom
          @richland007
          I re-read your first post and your problem is more restarting then actual crashing.
          Of course a restart can be caused by a crash …
          MMM-WatchDog tends to restart MM, so I too would suggest to remove this module.
          In principle all it does is sending a ping and restarting MM using pm2 when a timeout occurs.
          I also would expect to see some lines in the pm2 logs on WatchDog.
          Can you do ?:
          pi@MagicPi:~ $ grep -i watchdog /home/pi/.pm2/logs/mm-out.log
          pi@MagicPi:~ $ grep -i watchdog /home/pi/.pm2/logs/mm-error.log
          What is alo a good package to install is sysstat:
          pi@MagicPi:~ $ sudo apt-get install sysstat
          This allows for commands like iostat and sar.
          vmstat 10 10
          iostat 10 10
          sar 10 10
          MagicMirror version: 2.37.0
          richland007R 1 Reply Last reply Reply Quote 0
          • richland007R
            richland007 @evroom
            @evroom Ok so here is whats writen on that top.txt file
            pi@SmartMirror:~ $ tail -F top.txt
              834 pi        20   0  155396  17884   8104 S   0.0  1.9  23:20.77 lxpanel
              582 root      20   0  211836  13576   2440 S   0.0  1.4 418:48.14 Xorg
              457 alexapi   20   0  218108  10768   4772 S  47.4  1.1 878:20.67 python
              721 pi        20   0  122032  10600   4792 S   0.0  1.1   8:34.40 PM2 v3.0.3+
              835 pi        20   0  154056   5184   4016 S   0.0  0.5   0:43.57 pcmanfm
            18753 pi        20   0   47692   4896   3996 S   0.0  0.5   0:03.94 lxterminal
              829 pi        20   0   53536   4432   3556 S   0.0  0.5   0:13.22 openbox
              100 root      20   0   35220   3140   2980 S   0.0  0.3   2:16.35 systemd-jo+
             7236 pi        20   0    8112   3140   2712 R  15.8  0.3   0:00.07 top
            Sat Nov 17 11:25:01 CST 2018
            top - 11:25:01 up 3 days, 15:28,  1 user,  load average: 0.56, 2.88, 4.35
            Tasks: 135 total,   1 running,  89 sleeping,   0 stopped,   1 zombie
            %Cpu(s): 21.4 us,  5.5 sy,  0.0 ni, 69.4 id,  2.3 wa,  0.0 hi,  1.5 si,  0.0 st
            KiB Mem :   949452 total,   493928 free,   157456 used,   298068 buff/cache
            KiB Swap:   949440 total,   777124 free,   172316 used.   727276 avail Mem
              PID USER      PR  NI    VIRT    RES    SHR S  %CPU %MEM     TIME+ COMMAND
              582 root      20   0  218840  24540  12364 S  10.5  2.6 419:19.31 Xorg
              502 root      20   0   45188  23400  14452 S  36.8  2.5  27:20.07 vncserver-+
              834 pi        20   0  155396  21680  10616 S   0.0  2.3  23:23.35 lxpanel
             7558 pi        20   0   77052  21140  18404 S   0.0  2.2   0:03.37 leafpad
              835 pi        20   0  154156  16420  13232 S   0.0  1.7   0:46.57 pcmanfm
              721 pi        20   0  122032  14004   7360 S   0.0  1.5   8:34.81 PM2 v3.0.3+
              457 alexapi   20   0  218108  10772   4772 S  36.8  1.1 880:07.93 python
              636 root      20   0   15416   9020   8820 S   0.0  1.0   3:55.73 vncagent
            18753 pi        20   0   47692   8484   7164 S   0.0  0.9   0:04.22 lxterminal
              829 pi        20   0   53724   5888   4220 S   0.0  0.6   0:13.49 openbox
              953 pi        20   0   27236   5312   4812 S   0.0  0.6   0:03.05 vncserverui
              873 pi        20   0   27816   4328   3676 S   0.0  0.5   0:40.96 vncserverui
              804 pi        20   0   39468   3288   3000 S   0.0  0.3   0:02.79 gvfsd
              100 root      20   0   35220   3196   3036 S   0.0  0.3   2:16.50 systemd-jo+
             7603 pi        20   0    8112   3180   2752 R  10.5  0.3   0:00.05 top
            KiB Mem :   949452 total,   493776 free,   157600 used,   298076 buff/cache
            KiB Swap:   949440 total,   777124 free,   172316 used.   727128 avail Mem
              582 root      20   0  218840  24540  12364 S  11.1  2.6 419:19.33 Xorg
              502 root      20   0   45188  23400  14452 S  50.0  2.5  27:20.16 vncserver-+
              834 pi        20   0  155396  21680  10616 S   0.0  2.3  23:23.36 lxpanel
              457 alexapi   20   0  218108  10772   4772 S  61.1  1.1 880:08.05 python
            18753 pi        20   0   47692   8484   7164 S   0.0  0.9   0:04.24 lxterminal
             7608 pi        20   0    8112   3180   2752 R  22.2  0.3   0:00.07 top
            I use the command
            tail -F top.txt
            right?? i dont know how to read the above file so let me know if you see anything strange …i have increased the swap file to install opencv a while back for facial recognition to install rapidly but i do not use a usb …i could if i have to.
            As far as taking out the watchdog…commenting it out of the config.js should do the trick or do i have to uninstall it form the modules??
            Will pm2 still restart the MM if it crashes without the watchdog (it does if you do ctrl+q) ??
            D
            • evroomE
              evroom
              Okay, this calls for some more basics.
              Print the whole file:
              $ cat top.txt
              Load the file in an editor:
              $ nano top.txt
              $ vi top.txt
              I am old-school, so I use vi, but nano is more Word-like.
              To show the last 50 lines:
              $ tail -50 top.txt
              To show the first 50 lines:
              $ head -50 top.txt
              Where of course 50 is just an example.
              To show text that is appending:
              $ tail -f top.txt
              To show text that is appending and re-open the file when necessary (useful for rotating log files):
              $ tail -F top.txt
              On disabling a module see the next reply.
              • evroomE
                evroom
                To disable MMM-WatchDog, edit the config.js file.
                Locate:
                module: 'MMM-WatchDog',
                Edit this like this:
                disabled: true,
                and restart MM:
                $ pm2 restart mm
                Use
                pm2 list
                to check if your application name actually is mm, or something else.
                Later you can enable it again by updating config.js like this:
                disabled: false,
                This works for all modules.
                When I test modules I normally leave the config lines and disable a module in this fashion.
                • evroomE
                  evroom
                  @richland007
                  On pm2 and restarting I cannot say many.
                  On using ctrl+q neither, as I only access my MM via ssh.
                  Can you send the output of the following commands:
                  $ uname -a
                  $ swapon -s
                  $ free -h
                  $ cat /etc/dphys-swapfile | egrep -v ‘#|^$’
                  $ sudo service dphys-swapfile status
                  I just learned that swap is handled as a service.
                  Being old-school, this is something new to me :-)
                  richland007R 1 Reply Last reply Reply Quote 1
                  • evroomE
                    evroom
                    @richland007
                    Concerning your top.txt, was that the output on the moment that MM was restarted ?
                    I do not see obvious memory issues.
                    Only that vncserver and python are CPU hungry, but within limits.
                    And I do not see any electron processes.
                    • cowboysdudeC
                      cowboysdude Module Developer @OceanK
                      @oceank The BIGGEST problem that nobody either wants to admit or doesn’t realize is that the pi wasn’t made to be pounded on this hard.
                      It’s a simple computer…when you start adding constant pulls for data and scrolling text, etc it over heats and overloads the pi.
                      • richland007R
                        richland007
                        @evroom I appologise on the delay at answering i was at work during the weekend
                        here is the autput from
                        a bunch of these almost every 10-15 minutes
                        Fri Nov 09 2018 09:52:50 GMT-0600 (CST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
                        Fri Nov 09 2018 10:06:24 GMT-0600 (CST) - WatchDog: Heartbeat timeout. Frontend might have crashed. Exit now.
                        WatchDog started. Maximum timeout: 20s.
                        Module helper loaded: MMM-WatchDog
                        Connecting socket for: MMM-WatchDog
                        Starting module helper: MMM-WatchDog
                        Here is some sysstat output from the following commands
                        vmstat 10 10
                        iostat 10 10
                        sar 10 10
                        r  b   swpd   free   buff  cache   si   so    bi    bo   in   cs us sy id wa st
                         1  0  63744 209036  34364 567792    0    6    82    12  778  312 18  3 78  1  0
                         0  0  63744 209036  34372 567824    0    0     0     2 2431  278  4  0 96  0  0
                        avg-cpu:  %user   %nice %system %iowait  %steal   %idle
                                  17.75    0.00    3.32    0.57    0.00   78.36
                        Device:            tps    kB_read/s    kB_wrtn/s    kB_read    kB_wrtn
                        mmcblk0          13.75       311.58        45.87     821628     120969
                        zram0             1.77         0.95         6.13       2504      16164
                        zram1             1.73         0.78         6.12       2068      16132
                        zram2             1.70         0.74         6.08       1952      16028
                        zram3             1.74         0.94         6.02       2480      15880
                        06:44:46 PM     all      3.17      0.00      0.08      0.00      0.00     96.76
                        06:44:56 PM     all      4.12      0.00      0.25      0.03      0.00     95.60
                        • richland007R
                          richland007 @evroom
                          @evroom here is the rest of the commands you asked me to do :)
                          pi@SmartMirror:~ $ uname -a
                          Linux SmartMirror 4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 BST 2018 armv7l GNU/Linux
                          pi@SmartMirror:~ $ swapon -s
                          Filename				Type		Size	Used	Priority
                          /dev/zram0                             	partition	237360	15596	5
                          /dev/zram1                             	partition	237360	15636	5
                          /dev/zram2                             	partition	237360	15612	5
                          /dev/zram3                             	partition	237360	15364	5
                          pi@SmartMirror:~ $  free -h
                                        total        used        free      shared  buff/cache   available
                          Mem:           927M        135M        166M         16M        624M        718M
                          Swap:          927M         60M        866M
                          pi@SmartMirror:~ $ cat /etc/dphys-swapfile | egrep -v ‘#|^$’
                          bash: ^$’: command not found
                          pi@SmartMirror:~ $ sudo service dphys-swapfile status
                          ● dphys-swapfile.service - LSB: Autogenerate and use a swap file
                             Loaded: loaded (/etc/init.d/dphys-swapfile; generated; vendor preset: enabled
                             Active: active (exited) since Sun 2018-11-18 17:49:07 CST; 1h 36min ago
                               Docs: man:systemd-sysv-generator(8)
                            Process: 358 ExecStart=/etc/init.d/dphys-swapfile start (code=exited, status=0
                             CGroup: /system.slice/dphys-swapfile.service
                          Nov 18 17:49:06 SmartMirror systemd[1]: Starting LSB: Autogenerate and use a swa
                          Nov 18 17:49:06 SmartMirror dphys-swapfile[358]: Starting dphys-swapfile swapfil
                          Nov 18 17:49:07 SmartMirror dphys-swapfile[358]: want /var/swap=100MByte, checki
                          Nov 18 17:49:07 SmartMirror dphys-swapfile[358]: done.
                          Nov 18 17:49:07 SmartMirror systemd[1]: Started LSB: Autogenerate and use a swap
                          lines 1-12/12 (END)
                          And on the top.txt file neither the first 50 nor the last 50 are not saying much about magic mirror but i am going to start it again and tail top.txt again once it crashes.
                          Here is the output any how for the first and last 50 lines of the top.txt file
                          pi@SmartMirror:~ $ tail -50 top.txt
                            848 pi        20   0   27796   8972   8052 S   0.0  0.9   0:01.61 vncserverui
                            809 pi        20   0   42752   8256   8116 S   0.0  0.9   0:00.09 lxpolkit
                            890 pi        20   0   74324   7768   7596 S   0.0  0.8   0:00.15 gvfs-udisk+
                          Sun Nov 18 19:25:01 CST 2018
                          top - 19:25:01 up  1:25,  1 user,  load average: 0.39, 0.39, 0.37
                          Tasks: 134 total,   1 running,  88 sleeping,   0 stopped,   1 zombie
                          %Cpu(s): 12.5 us,  1.5 sy,  0.0 ni, 85.3 id,  0.3 wa,  0.0 hi,  0.3 si,  0.0 st
                          KiB Mem :   949452 total,   169780 free,   140140 used,   639532 buff/cache
                          KiB Swap:   949440 total,   887232 free,    62208 used.   734220 avail Mem
                            553 root      20   0  214532  54136  35564 S   0.0  5.7   3:10.64 Xorg
                            719 pi        20   0  120620  28044  15252 S   0.0  3.0   0:06.59 PM2 v3.0.3+
                            814 pi        20   0  144716  27976  24560 S   0.0  2.9   0:12.95 pcmanfm
                            455 alexapi   20   0  191228  27236  13820 S   5.6  2.9  21:37.81 python
                            481 root      20   0   45136  22548  13788 S   0.0  2.4   3:25.82 vncserver-+
                           1840 pi        20   0   77044  21280  18496 S   0.0  2.2   0:08.20 leafpad
                            812 pi        20   0  138632  20484  18116 S   0.0  2.2   0:21.17 lxpanel
                           1656 pi        20   0   49308  20328  16408 S   0.0  2.1   0:40.59 lxterminal
                            868 pi        20   0   27820  14160  12840 S   0.0  1.5   0:00.35 vncserverui
                            806 pi        20   0   53684  13080  10916 S   0.0  1.4   0:02.33 openbox
                            557 root      20   0   15416  10640  10312 S   5.6  1.1   0:29.86 vncagent
                            673 pi        20   0   52180  10472  10140 S   0.0  1.1   0:00.85 lxsession
                          KiB Mem :   949452 total,   170032 free,   139888 used,   639532 buff/cache
                          KiB Swap:   949440 total,   887232 free,    62208 used.   734472 avail Mem
                            814 pi        20   0  144716  27976  24560 S   0.0  2.9   0:12.96 pcmanfm
                            455 alexapi   20   0  191228  27236  13820 S   0.0  2.9  21:37.81 python
                            557 root      20   0   15416  10640  10312 S   0.0  1.1   0:29.86 vncagent
                          pi@SmartMirror:~ $ head -50 top.txt
                          Fri Nov 16 22:55:01 CST 2018
                          top - 22:55:02 up 3 days,  2:58,  1 user,  load average: 0.18, 0.31, 0.21
                          Tasks: 132 total,   1 running,  88 sleeping,   0 stopped,   1 zombie
                          %Cpu(s): 18.3 us,  4.2 sy,  0.0 ni, 74.3 id,  2.0 wa,  0.0 hi,  1.2 si,  0.0 st
                          KiB Mem :   949452 total,   276412 free,   169288 used,   503752 buff/cache
                          KiB Swap:   949440 total,   825760 free,   123680 used.   687104 avail Mem
                            582 root      20   0  219092  34684  17284 S   0.0  3.7 302:37.78 Xorg
                            457 alexapi   20   0  210684  27312  13416 S   0.0  2.9 799:59.04 python
                            834 pi        20   0  152648  26352  11692 S   0.0  2.8  19:11.56 lxpanel
                            502 root      20   0   45188  23764  14620 S   0.0  2.5  26:30.86 vncserver-+
                            835 pi        20   0  154056  17252  14084 S   0.0  1.8   0:33.17 pcmanfm
                            721 pi        20   0  127960  16648   7700 S   0.0  1.8   6:21.25 PM2 v3.0.3+
                           2011 pi        20   0   48208  12352  10328 S   0.0  1.3   0:10.66 lxterminal
                            100 root      20   0   35220   9068   8840 S   0.0  1.0   2:10.19 systemd-jo+
                            636 root      20   0   15416   9048   8840 S   0.0  1.0   3:51.37 vncagent
                            829 pi        20   0   53536   6128   4664 S   0.0  0.6   0:09.74 openbox
                            953 pi        20   0   27236   4904   4428 S   0.0  0.5   0:02.30 vncserverui
                            873 pi        20   0   27816   4280   3616 S   0.0  0.5   0:32.84 vncserverui
                              1 root      20   0   27024   3680   2972 S   0.0  0.4   0:12.38 systemd
                            598 root      20   0    7272   3464   3192 S   0.0  0.4   0:01.09 bluetoothd
                            979 raspoti+  20   0   18924   3432   3036 S   0.0  0.4   1:10.74 librespot
                          KiB Mem :   949452 total,   276684 free,   168980 used,   503788 buff/cache
                          KiB Swap:   949440 total,   825760 free,   123680 used.   687416 avail Mem
                            457 alexapi   20   0  210684  27312  13416 S   5.9  2.9 799:59.05 python
                            835 pi        20   0  154056  17252  14084 S   0.0  1.8   0:33.18 pcmanfm
                          Fri Nov 16 23:00:01 CST 2018
                          top - 23:00:01 up 3 days,  3:03,  1 user,  load average: 3.02, 1.49, 0.69
                          Tasks: 138 total,   4 running,  91 sleeping,   0 stopped,   1 zombie
                          %Cpu(s): 18.4 us,  4.2 sy,  0.0 ni, 74.3 id,  2.0 wa,  0.0 hi,  1.2 si,  0.0 st
                          Thank you
                          D
                          • richland007R
                            richland007
                            Its holding better i haven’t seen it restart in the past few hours i think MMM-watchdog was the problem
                            • evroomE
                              evroom
                              @richland007
                              Unless someone tells different, from my point of view you do not have any CPU or memory issues.
                              In fact, it makes me wonder why I am seeing the electron.js processes so high in my output.
                              I do not use MMM-watchdog and I do not know exactly what it is doing.
                              Do not know what it is pinging, but something on your MM makes it time out and as a cause it restarts mm.
                              The log only tells you that it failed, but not what exactly failed.
                              Would be nice to know how you can send this ping manually, then you can observe the behavior yourself.
                              I take it, that you have your monitor connected to your Pi.
                              So MM not running as server only and the display not on a client.
                              Anyway, good to hear that you potentially have found the issue and you learned a bit of Linux on the side.
