    MMM-CalendarWeek
    33 Posts 18 Posters 28.4k Views 18 Watching
    • H
      heskja Module Developer
      Description:
      This calendar module for Magic Mirror² is functionally the same as the default calendar app, however its presentation is different as it uses week view. This module displays events from a public .ical calendar. It can combine multiple calendars.
      Screenshots:
      Screenshot
      Download:
      [card:heskja/MMM-CalendarWeek]
      Ideas wanted
      Please feel free to submit issues to the repository for new ideas, bugs, feature requests and so on!
        cptkex
        • lavolp3L
          lavolp3 Module Developer
          Looks good!
          Since I’m currently working on the calendar module: What does your module do with multi-day events?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • H
            heskja Module Developer @lavolp3
            @lavolp3 It does currently not support multi-day events very well. Had to do some testing as I saw your question, but ended up creating an issue on this one… :)
            • H
              heskja Module Developer @heskja
              Actually made an attempt to solve the multi day issue, hope it works :)
                Cattoo
                I have set the config to
                maximumNumberOfDays: 7,
                showEndDate: true
                displayDescription: true
                But it aint taking it, what could be wrong?
                Only seeing the default values.
                • Y
                  yawns Moderator @Cattoo
                  @cattoo said in MMM-CalendarWeek:
                  showEndDate: true
                  Please post the entire MMM-CalendarWeek section of your config.js, just remove any personal details like links to your calendars. Maybe you added the config details in the wrong place?
                    Cattoo @yawns
                    Here is the code
                    			module: "MMM-CalendarWeek",
                    			position: "bottom_bar",
                    						symbol: "calendar-check-o",
                    						displayLocation: 'true',
                    						displayDescriptio: "true",
                    						maximumNumberOfDays: '5',
                    						showEndDate: "true",
                    						url: "************"
                    • Y
                      yawns Moderator
                      Okay, please try this.
                      		showEndDate: true,
                      		displayLocation: true,
                      		displayDescription: true,
                      				maximumNumberOfDays: 5,
                      				url: "************"
                        Cattoo @yawns
                        That did the trick, thanks a lot :)
                        @yawns said in MMM-CalendarWeek:
                        		showEndDate: true,
                        				url: "************"
                          PTcrusher
                          For some reason i cannot get CalendarWeek to display more than 4 days, could you kindly take a look at my configuration?
                          		 maximumNumberOfDays: "7",
                          		 maximumDaysPerLine: "7",
                          		 position: "bottom_bar", // This can be any of the regions. Best results in bottom region.
                          				 // If no config is set, an example calendar is shown.
                          								 symbol: "google",
                          								 url: "",
                          								 symbol: "umbrella-beach",
                          								 url: "",
                          								 symbol: "building",
                          								 url: "",
                          								 symbol: "birthday-cake",
                          								 url: "",
                          Thanks in advance,
                          Edgar Santos
                            PTcrusher @PTcrusher
                            @ptcrusher said in MMM-CalendarWeek:
                            								 symbol: "google",
                            								 url: "",
                            								 url: "",
                            								 symbol: "building",
                            								 url: "",
                            								 url: "",
                            Thanks in advance,
                            Edgar Santos
                            This options need to go to the config key :)
                            Now it works fine
                            • Q
                              qjaxxx
                              Hi sorry for the lack of information, I have gotten your module to the point where it shows that no upcoming events are listed. So it IS showing up now. Would I actually make the config adjustments in the main config file, or are those adjustments to be made in the secondary file or node helper I think is what it is called? My code is attached. I adjusted my specific Ical url and username/password. Any help is appreciated.
                              Thanks,
                              • O
                                othomys
                                I have integrated several calendars. I would like to add a separate icon to each calendar. In which folder do I have to put the new symbols? What properties must the symbols have? (Type, size)
                                Many Thanks.
                                H 1 Reply Last reply Reply Quote 2
                                  bolish
                                  Great module!
                                  Is there any way to display it as a table? I mean adding lines to separate each date cell?
                                  Something similar to :
                                  link text
                                  Maybe by aplying around with the .css?
                                    bolish
                                    I’m trying to use this module as a monthly calendar also!
                                    (7 days per row, 31 days max).
                                    Would be great if you could add below options to the modules!!::
                                    • Module start date options :
                                      - Today
                                      - Monday of the current week (monday of this week)
                                      - Monday of the week that precedes the day week of the month (this is the one I’m really looking for)
                                    I will have a look on my side on parallel but I’m far from having the skills for now… Let’s see.
                                    Cherry on the cake, be able to move the starting date upon notifications (i.e : move to next month following a gesture that triggers notification)
                                      peter_mcc
                                      We’re experimenting with MagicMirror to keep track of what’s going on with our family calendar. It works fairly well - we’ve got a calendar set up for each person (5 of us) and another one for family events.
                                      I have a problem though - when an event is in more than one calendar it only shows up as the first calendar. So if it’s in calendars 1, 2 & 3 MagicMirror will only show the event as being in Calendar 1.
                                      Is there any way to stop it getting rid of duplicate entries?
                                        Daveey @peter_mcc
                                        @peter_mcc Just looking at the documentation, it looks like you’re running up against the allowDuplicate config, which is false by default, so it’s finding your multiple/same events and hiding them. add to the module config a line for
                                        allowDuplicate: true,
                                        • G
                                          Gingos
                                          Hey, I’m using this tool and I’m appreciate it very much - thank you!
                                          But is there any possibility/option to adjust the columns-width or the space between two days?
                                            Cattoo
                                            How should i type in for multiple calendars?
                                            Have tried different things but its just ending up config error.
