    MMM-CalendarWeek
    33 Posts 18 Posters 23.4k Views 18 Watching
    • H Offline
      heskja Module Developer
      Description:
      This calendar module for Magic Mirror² is functionally the same as the default calendar app, however its presentation is different as it uses week view. This module displays events from a public .ical calendar. It can combine multiple calendars.
      Screenshots:
      Screenshot
      Download:
      [card:heskja/MMM-CalendarWeek]
      Ideas wanted
      Please feel free to submit issues to the repository for new ideas, bugs, feature requests and so on!
        cptkex
        • lavolp3L Offline
          lavolp3 Module Developer
          Looks good!
          Since I’m currently working on the calendar module: What does your module do with multi-day events?
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
          • H Offline
            heskja Module Developer @lavolp3
            @lavolp3 It does currently not support multi-day events very well. Had to do some testing as I saw your question, but ended up creating an issue on this one… :)
            • H Offline
              heskja Module Developer @heskja
              Actually made an attempt to solve the multi day issue, hope it works :)
                Cattoo
                I have set the config to
                maximumNumberOfDays: 7,
                showEndDate: true
                displayDescription: true
                But it aint taking it, what could be wrong?
                Only seeing the default values.
                • yawnsY Offline
                  yawns Moderator @Cattoo
                  @cattoo said in MMM-CalendarWeek:
                  showEndDate: true
                  Please post the entire MMM-CalendarWeek section of your config.js, just remove any personal details like links to your calendars. Maybe you added the config details in the wrong place?
                    Cattoo @yawns
                    Here is the code
                    			module: "MMM-CalendarWeek",
                    			position: "bottom_bar",
                    						symbol: "calendar-check-o",
                    						displayLocation: 'true',
                    						displayDescriptio: "true",
                    						maximumNumberOfDays: '5',
                    						showEndDate: "true",
                    						url: "************"
                    • yawnsY Offline
                      yawns Moderator
                      Okay, please try this.
                      		showEndDate: true,
                      		displayLocation: true,
                      		displayDescription: true,
                      				maximumNumberOfDays: 5,
                      				url: "************"
                        Cattoo @yawns
                        That did the trick, thanks a lot :)
                        @yawns said in MMM-CalendarWeek:
                        		showEndDate: true,
                        				url: "************"
                        • 1 / 4
