    MMM-CalendarWeek
    33 Posts 18 Posters 29.1k Views 18 Watching
      Cattoo
      I have set the config to
      maximumNumberOfDays: 7,
      showEndDate: true
      displayDescription: true
      But it aint taking it, what could be wrong?
      Only seeing the default values.
      yawnsY 1 Reply Last reply
      • yawnsY
        yawns Moderator @Cattoo
        @cattoo said in MMM-CalendarWeek:
        showEndDate: true
        Please post the entire MMM-CalendarWeek section of your config.js, just remove any personal details like links to your calendars. Maybe you added the config details in the wrong place?
        C 1 Reply Last reply
          Cattoo @yawns
          Here is the code
          			module: "MMM-CalendarWeek",
          			position: "bottom_bar",
          						symbol: "calendar-check-o",
          						displayLocation: 'true',
          						displayDescriptio: "true",
          						maximumNumberOfDays: '5',
          						showEndDate: "true",
          						url: "************"
          • yawnsY
            yawns Moderator
            Okay, please try this.
            		showEndDate: true,
            		displayLocation: true,
            		displayDescription: true,
            				maximumNumberOfDays: 5,
            				url: "************"
              Cattoo @yawns
              That did the trick, thanks a lot :)
              @yawns said in MMM-CalendarWeek:
              		showEndDate: true,
              				url: "************"
                PTcrusher
                For some reason i cannot get CalendarWeek to display more than 4 days, could you kindly take a look at my configuration?
                		 maximumNumberOfDays: "7",
                		 maximumDaysPerLine: "7",
                		 position: "bottom_bar", // This can be any of the regions. Best results in bottom region.
                				 // If no config is set, an example calendar is shown.
                								 symbol: "google",
                								 url: "",
                								 symbol: "umbrella-beach",
                								 url: "",
                								 symbol: "building",
                								 url: "",
                								 symbol: "birthday-cake",
                								 url: "",
                Thanks in advance,
                Edgar Santos
                P 1 Reply Last reply
                  PTcrusher @PTcrusher
                  @ptcrusher said in MMM-CalendarWeek:
                  								 symbol: "google",
                  								 url: "",
                  								 url: "",
                  								 symbol: "building",
                  								 url: "",
                  								 url: "",
                  Thanks in advance,
                  Edgar Santos
                  This options need to go to the config key :)
                  Now it works fine
                  • Q
                    qjaxxx
                    Hi sorry for the lack of information, I have gotten your module to the point where it shows that no upcoming events are listed. So it IS showing up now. Would I actually make the config adjustments in the main config file, or are those adjustments to be made in the secondary file or node helper I think is what it is called? My code is attached. I adjusted my specific Ical url and username/password. Any help is appreciated.
                    Thanks,
                    H 1 Reply Last reply
                    • O
                      othomys
                      I have integrated several calendars. I would like to add a separate icon to each calendar. In which folder do I have to put the new symbols? What properties must the symbols have? (Type, size)
                      Many Thanks.
                      Reply Quote 2
                        bolish
                        Great module!
                        Is there any way to display it as a table? I mean adding lines to separate each date cell?
                        Something similar to :
                        link text
                        Maybe by aplying around with the .css?
                          bolish
                          I’m trying to use this module as a monthly calendar also!
                          (7 days per row, 31 days max).
                          Would be great if you could add below options to the modules!!::
                          • Module start date options :
                            - Today
                            - Monday of the current week (monday of this week)
                            - Monday of the week that precedes the day week of the month (this is the one I’m really looking for)
                          I will have a look on my side on parallel but I’m far from having the skills for now… Let’s see.
                          Cherry on the cake, be able to move the starting date upon notifications (i.e : move to next month following a gesture that triggers notification)
                          Reply Quote 2
                            peter_mcc
                            We’re experimenting with MagicMirror to keep track of what’s going on with our family calendar. It works fairly well - we’ve got a calendar set up for each person (5 of us) and another one for family events.
                            I have a problem though - when an event is in more than one calendar it only shows up as the first calendar. So if it’s in calendars 1, 2 & 3 MagicMirror will only show the event as being in Calendar 1.
                            Is there any way to stop it getting rid of duplicate entries?
                            D 1 Reply Last reply
                              Daveey @peter_mcc
                              @peter_mcc Just looking at the documentation, it looks like you’re running up against the allowDuplicate config, which is false by default, so it’s finding your multiple/same events and hiding them. add to the module config a line for
                              allowDuplicate: true,
                              • G
                                Gingos
                                Hey, I’m using this tool and I’m appreciate it very much - thank you!
                                But is there any possibility/option to adjust the columns-width or the space between two days?
                                  Cattoo
                                  How should i type in for multiple calendars?
                                  Have tried different things but its just ending up config error.
                                  • H
                                    heskja Module Developer @qjaxxx
                                    @qjaxxx
                                    As far as I can see, you have closed the “config”-section of the module configuration too soon. As you have posted a screenshot of your config, not the config yourself, I will refrain from typing it manually, but you have a closing bracket “}” between “fetchInterval” and “calendars”. Please remove it, as the array of calendars should be within your config section.
                                      sdetweil @Cattoo
                                      @Cattoo
                                      repeat this block for each calendar
                                      								 symbol: "some_label",
                                      								 url: "http://someurl",
                                      • H
                                        heskja Module Developer @othomys
                                        @othomys It depends on your setup. Calendar icons are supported using font awesome fonts, is that what you are looking for?
                                        If so, you should use the “symbol” parameter in the calendar config as shown here:
                                        			url: 'http://www.calendarlabs.com/templates/ical/US-Holidays.ics',
                                        			symbol: 'calendar',
                                        			auth: {
                                        			    user: 'username',
                                        			    pass: 'superstrongpassword',
                                        			    method: 'basic'
                                        • H
                                          heskja Module Developer @bolish
                                          @bolish
                                          Great idea! Would need some “css magic”, but I’ve created an issue in the GitHub repository. Please feel free to follow the development here:
                                          https://github.com/heskja/MMM-CalendarWeek/issues/27
                                          • H
                                            heskja Module Developer @Gingos
                                            @Gingos
                                            It is definitely doable with some CSS magic. I have created an issue in the GitHub repository to configure it with parameters as well. Please feel free to follow the development here: https://github.com/heskja/MMM-CalendarWeek/issues/28
