    MMM-CalendarWeek
    33 Posts 18 Posters 29.1k Views 18 Watching
    • O
      othomys
      I have integrated several calendars. I would like to add a separate icon to each calendar. In which folder do I have to put the new symbols? What properties must the symbols have? (Type, size)
      Many Thanks.
      H 1 Reply Last reply
      Reply Quote 2
        bolish
        Great module!
        Is there any way to display it as a table? I mean adding lines to separate each date cell?
        Something similar to :
        link text
        Maybe by aplying around with the .css?
          bolish
          I’m trying to use this module as a monthly calendar also!
          (7 days per row, 31 days max).
          Would be great if you could add below options to the modules!!::
          • Module start date options :
            - Today
            - Monday of the current week (monday of this week)
            - Monday of the week that precedes the day week of the month (this is the one I’m really looking for)
          I will have a look on my side on parallel but I’m far from having the skills for now… Let’s see.
          Cherry on the cake, be able to move the starting date upon notifications (i.e : move to next month following a gesture that triggers notification)
          Reply Quote 2
            peter_mcc
            We’re experimenting with MagicMirror to keep track of what’s going on with our family calendar. It works fairly well - we’ve got a calendar set up for each person (5 of us) and another one for family events.
            I have a problem though - when an event is in more than one calendar it only shows up as the first calendar. So if it’s in calendars 1, 2 & 3 MagicMirror will only show the event as being in Calendar 1.
            Is there any way to stop it getting rid of duplicate entries?
            D 1 Reply Last reply
              Daveey @peter_mcc
              @peter_mcc Just looking at the documentation, it looks like you’re running up against the allowDuplicate config, which is false by default, so it’s finding your multiple/same events and hiding them. add to the module config a line for
              allowDuplicate: true,
              • G
                Gingos
                Hey, I’m using this tool and I’m appreciate it very much - thank you!
                But is there any possibility/option to adjust the columns-width or the space between two days?
                  Cattoo
                  How should i type in for multiple calendars?
                  Have tried different things but its just ending up config error.
                  • H
                    heskja Module Developer @qjaxxx
                    @qjaxxx
                    As far as I can see, you have closed the “config”-section of the module configuration too soon. As you have posted a screenshot of your config, not the config yourself, I will refrain from typing it manually, but you have a closing bracket “}” between “fetchInterval” and “calendars”. Please remove it, as the array of calendars should be within your config section.
                      sdetweil @Cattoo
                      @Cattoo
                      repeat this block for each calendar
                      								 symbol: "some_label",
                      								 url: "http://someurl",
                      • H
                        heskja Module Developer @othomys
                        @othomys It depends on your setup. Calendar icons are supported using font awesome fonts, is that what you are looking for?
                        If so, you should use the “symbol” parameter in the calendar config as shown here:
                        			url: 'http://www.calendarlabs.com/templates/ical/US-Holidays.ics',
                        			symbol: 'calendar',
                        			auth: {
                        			    user: 'username',
                        			    pass: 'superstrongpassword',
                        			    method: 'basic'
                        • H
                          heskja Module Developer @bolish
                          @bolish
                          Great idea! Would need some “css magic”, but I’ve created an issue in the GitHub repository. Please feel free to follow the development here:
                          https://github.com/heskja/MMM-CalendarWeek/issues/27
                          • H
                            heskja Module Developer @Gingos
                            @Gingos
                            It is definitely doable with some CSS magic. I have created an issue in the GitHub repository to configure it with parameters as well. Please feel free to follow the development here: https://github.com/heskja/MMM-CalendarWeek/issues/28
                              Robtrowb
                              How do you get the calendar to space evenly ?0_1558485160383_Screen Shot 2019-05-21 at 8.30.09 PM.png
                              • H
                                hockey2112
                                Hello, love this module! Works great, and I have been able to customize it pretty easily with css.
                                One change I would like to make… How can I make the events into two td’s instead of three? I’d like a td on the left for the symbol, and then a td on the right with the event name on top and the time underneath the event name.
                                So the “time” td would instead be a div within the “title” td. It would look like this:
                                [SYMBOL] My Event Title
                                                   8:00 AM
                                • H
                                  hockey2112 @hockey2112
                                  I was able to solve this with some hacky absolute positioning.
                                  Having another issue now, though. Today is Tuesday, and my repeating events from Wednesday (tomorrow) are showing for today. But I can see that next Wednesday’s repeating events are showing on Wednesday (and not on Tuesdaay, the wrong day, like this week’s Wed events are).
                                  I have rebooted several times and I updates MM core. No change. Any ideas on why this is happening and how I can fix it?
                                    rookiepilot
                                    I have no idea what is going on either. I literally haven’t touched any code but ever since daylight savings (Sunday November 3rd) both my “MMM-MyCalendar” AND “MMM-CalendarExt2” modules are showing events on the wrong days. The problem seems to only occur with reoccurring events; they usually show up one day earlier. Rebooting does not correct the issue. I hope someone can figure this out soon :(
                                    S L 2 Replies Last reply
                                      sdetweil @rookiepilot
                                      @rookiepilot the calendar parser has a bug
                                      • L
                                        lotusvball @rookiepilot
                                        @rookiepilot I am having the exact same issue. I even tried to delete the event and re-add it and it still shows 1 day early.
                                        • E
                                          eddie2208
                                          @rookiepilot and @lotusvball - are you still having the same issue? I think I am having the same issue - some (not all) events appear a day early and at the wrong time. Do you know if there is a fix?
                                          R 1 Reply Last reply
                                            rookiepilot @eddie2208
                                            @eddie2208 I gave up on the problem and didn’t use my MM for a month or so. It was still running on a monitor mounted on the wall but I just didn’t pay attention to the calendar module or just hid that particular module. Oddly, after a month or two I noticed it just magically started to work correctly (it IS a magic mirror after all) without any intervention on my part; no problems since then :)
