    City of Vienna - Public Transport Realtime Monitor
    11 Posts 4 Posters 7.4k Views 4 Watching
      cpramhofer
      Hi again ;)
      found the following:
      https://github.com/Metalab/oeffimonitor
      someone acutally did a lot of work on this in JS here on github. the point is to bring this into an MMM.
        spedja
        Hi people,
        i am also looking forward to this module.
        Here is another source, maybe can be useful:
        https://github.com/tom94zoe/magicMirror
        and to test API you can use:
        http://www.wienerlinien.at/ogd_realtime/monitor?rbl=4259&sender=GDxCvVKMAfrXja1F
        Search for RBL numbers:
        https://till.mabe.at/rbl/
        • strawberry 3.141S Offline
          I had a first look into this, but I could’t find a documentation neither I got a api_key from them.
          So I’m trying to get into this on my own, but therefore you guys need to test if the module is working for your needs. I will work on this tonight so propably you can test it today already
          You can follow the developing process here when I have started
          [card:fewieden/MMM-WienerLinien]
            cpramhofer
            Hi Strawberry,
            Mayen this Uri helps:
            I think the value After the Sender is the API key.
            Thanks a lot for your help!!
              maintenance on their API :(
                cpramhofer
                Hi @strawberry-3-141!
                Thanks a lot for work great work!
                It doesn’t only work, it also looks fantastic!
                if you are from vienna: the next beer is on me ;)
                greets
                Christoph
                strawberry 3.141S 1 Reply Last reply Reply Quote 1
                  strawberry 3.141 Project Sponsor Module Developer @cpramhofer
                  @cpramhofer Thanks for the offer, but I’m not located in Austria :D
