    MMM-GooglePhotos
    294 Posts 56 Posters 391.6k Views 59 Watching
    • K Offline
      krishnatnl
      @Sean :
      Got the scan calculation of how you got 2880 . thanks.
      Question:
      Does the Scan calculation mean If scanned every 10 mins, a total of 2880 photos will be scanned in 24 hours?
      If refresh Interval is every 1 minute, then 60*24 = 144 photos out of the 2880 photos will be shown?
        A Former User @krishnatnl
        @krishnatnl
        1api request could get 50 pics. 1000 pics need 20 api request. (1 scan)
        1440scan(1min for 24h) needs 28800 api requests. Thats quota over.
        • U Offline
          uzair82
          I have installed this module and all options are working Except Fullscreen. When i setup to 100% nothing appears in Google Photos.
          If i set resolution manually it works fine. what could be the reason.
          Here is the setting.
           sort: "time", //'time', 'reverse', 'random'
              showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
              showHeight: "100%",
              originalWidthPx: 1024, // original size of loaded image. (related with image quality)
              originalHeightPx: 768, // Bigger size gives you better quality, but can give you network burden.
              mode: "cover", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
            A Former User @uzair82
            @uzair82 There is no reason not to work. Where(position) did you put your module for fullscreen?
            • K Offline
              krishnatnl @Guest
              @sean
              This is working fine now.
              Below is my config snippet:
              refreshInterval: 1000*30,
              scanInterval: 1000*60*60, // too many scans might cause API quota limit also.
              //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
              sort: "random", //'time', 'reverse', 'random'
              showHeight: "100%",
              originalWidthPx: 1920, // original size of loaded image. (related with image quality)
              originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
              Question:
              My monitor is in Landscape mode. My Landscape pictures displays fine (Fitting exactly in screen). But portraits display in full size cropping the pic mostly and in an expanded view. Only part of image is visible since it large.
              Is there a way to “Fit the picture into the screen” when it is Portrait just like Landscape? I tried other mode. It is too small and has borders. I want the pic to fit exactly in the screen.
              My monitor is 22 inch, Full HD (1080P) if that helps.
                @krishnatnl
                Fit the picture into the screen has obvious meaning.
                Portrait image in Landscape Area (and vice versa) Is something like real pictures in real photoframe, you cannot fit your portrait picture into the landscape frame without cutting(mode:cover) or extra margin of both left&right sides(mode:contain). The bigger difference of ratio makes the more uncomfortable looks.
                Could be the 3rd option? Give me a suggestion.
                PS
                I thought options available to consider :
                • stretch the width of portrait picture fully to fit to landscape area. It makes your person in portrait looks like a hobbit.
                • cut the top and both moderately and also stretch horizontally not too much. Not displaying entire image and not covering whole area, but it will look nicer than current issue. The only problem is, where to cut and how much to expand is not be done automatically.
                Is there any idea?
                • K Offline
                  krishnatnl
                  @Sean
                  Maybe i did not explain properly. I need a layout for the portrait oriented pictures to fit in the screen without disturbing the aspect Ratio.
                  MODE:COVER
                  • Works perfectly for the landscape oriented pictures since it is fitting the picture perfectly in the screen. There is no stretch or crop.
                  • Portrait oriented pictures are cropped to landscape orientation (technically).
                  MODE:CONTAIN
                  • Works fine for the portrait oriented pictures i.e: The full image is visible in the screen, no crop, no stretch
                  • Landscape pictures are also displayed without crop, but there are borders.
                  Need something like this:
                  If the pic is a Landscape oriented one, Mode should be COVER, else should be CONTAIN.
                  In Other words, need an AUTO-SCALING option.
                  From a programming perspective, is this feasible? If not, I will try the COVER mode but not liking black borders for all the images.
                    @krishnatnl
                    In my MMM-DropboxWallpaper, I applied already that feature(automatically changing mode by ratio). I have been doubting whether it has really usefulness in real usage. Anyway I’ll consider this feature in this module too.
                      @krishnatnl
                      I’ve updated. mode:hybrid is available for changing mode:cover or mode:contain automatically by aspect ratio.
                      • K Offline
                        krishnatnl
                        This working fine and solved my issue @Sean . Happy Holidays :)
                        • K Offline
                          krouton
                          Hi Sean,
                          I keep getting the “[GPHOTO] Scan finished : 0/There is no scanned photo currently.” error however there are 3000 photos in the folder. Sometimes it will successfully scan and display the photos fine but more and more recently it fails.
                          		module: "MMM-GooglePhotos",
                          		position: "fullscreen_below",
                          		disabled: false,
                          		albumId: "xxxxx", // your album id from result of `auth_and_test.js`
                          		refreshInterval: 1000*60*5,
                          		scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                          		showWidth: "1380px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                          		showHeight: "1060px",
                          		originalWidthPx: 1380, // original size of loaded image. (related with image quality)
                          		originalHeightPx: 1060, // Bigger size gives you better quality, but can give you network burden.
                          		mode: "contain", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                          Connecting socket for: MMM-GooglePhotos
                          MMM-GooglePhotos started
                          Connecting socket for: MMM-MyCalendar
                          Starting node helper for: MMM-MyCalendar
                          Sockets connected & modules started …
                          Ready to go! Please point your browser to: http://0.0.0.0:8080
                          MMM-ModuleScheduler is removing all scheduled jobs
                          MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
                          MMM-ModuleScheduler is creating a global schedule for all modules using “30 6 * * *” and “00 18 * * *” with dim level 40
                          MMM-GooglePhotos initialized after loading.
                          [RCREPO] Repository scanning…
                          [RCREPO] modules.json is updated.
                          Inspector shows it loads the module but not an actual photo.
                          Any help would be greatly appreciated.
                            A Former User @krouton
                            @krouton
                            Move to some smaller folder than try again. 3000 would be so many photos, and ther could be more in your subdirectories.
                              @krouton
                              By the way, sorry for out of topic, but…
                              RCREPO seems too many times working. Scanning should be executed at start of MM once. Why did the log say so many times?
                              Would you try again after removing MMM-Remote-Control-Repository from config.js??
                              • Y Offline
                                yupwho
                                @Sean , thanks a ton for this great module. My wife would have never been ok with a Smart display in our family room without having family pictures on it.
                                I have MMM-Google photos on full screen mode (monitor is in portrait mode). It works perfectly as expected - although the pictures come up as pixelated or not as sharp in lower resolution. All photos in my configured album are uploaded in full resolution. Is there any way to display it in high(est/er) resolution?
                                My configuration is as below:-
                                		    albumId: "XXXXX", // your album id from result of `auth_and_test.js`
                                		    refreshInterval: 1000*60,
                                		    showHeight: "100%",
                                		    mode: "hybrid", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                                		    //ADDED. "hybrid" : if you set as "hybrid" it will change "cover" and "contain" automatically by aspect ratio.
                                  bhepler Module Developer @yupwho
                                  @yupwho - Hmm. If you uploaded at full resolution, they are probably higher than 1920x1080. Specifying those parameters may be causing some weird resizing artifacts.
                                  As an experiment, trying taking out the orginalWidthPix and originalHeightPx parameters and see what you get.
                                  • Y Offline
                                    yupwho @bhepler
                                    @bhepler Thanks! Removing it seemed to worsen the quality. I think I am going to experiment with different values here - https://en.wikipedia.org/wiki/Display_resolution#Common_display_resolutions.
                                    I have tried the 2560*1440 and it looks little bit better.
                                    Still looking if there is a more definite solution.
                                    Thanks!
                                      A Former User @yupwho
                                      @yupwho
                                      Set originalWidthPx and originalHeightPx to higher value.
                                      But dithering would be unescapable destiny. Because Max Screen Size of supported in RPI would be 1920*1080 and your pictures are larger than, so Dithering should be happened.
                                      Usually Dithering - Scaling up/down, by index of 2 (e.g: X2, X4, X1/2, X1/4) would be better than other values.
                                      So, dithering to 800X480 from 1600x960 could be better from 2000X1200.
                                      And I think the best values would be the same size to display.
                                      Because, if dithering would be happened, it would be done twice - once when your Google Photo send picture to RPI by OriginalWidth/Height and once again when my module showing it by showWidth/Height.
                                      So, The best case would be all the same sizes - your picture original, OriginalWidth/Height, showWidth/Height are same. In other case, somewhat quality down is unavoidable. My module has no correction/manipulation method because this is not photoshop. sorry.
                                      • Y Offline
                                        yupwho @Guest
                                        @sean Thanks for the details - agreed! I am going to experiment with various config values and picture types. Awesome work with the module - works out of the box as expected!
                                          Joeysface
                                          I have been messing around with this module for a couple of days now and am really impressed with the way it works and the aspect ratio switching. I have a question though about the way the module displays pictures with borders. Would there be a way to either: display the image at the top of the frame and leave all of the black space below the image, or display two landscape images on top of each other instead of bordering the images?
                                          Thanks for any help with this.
                                            A Former User @Joeysface
                                            @joeysface
                                            Sorry for my poor English, I have a trouble to catch your points. If you can show me the example (simple image??) It will be a help.
                                            • 14
                                            • 15
                                            • 4 / 15
