    MMM-GooglePhotos
    294 Posts 56 Posters 409.1k Views 59 Watching
      A Former User @krishnatnl
      @krishnatnl
      Tomorrow I’ll research then I’ll leave my reply.
        bowlofred @krishnatnl
        @krishnatnl
        1. That’s what I do. I just used the default scan interval (10 minutes) and set the refresh to 1 minute.
                                        refreshInterval: 1000*60,
                                        scanInterval: 1000*60*10,
                                        sort: "random",
        1. I’m not aware you can use multiple albums. I just add any photos I want to display on a separate “magicmirror” album. The photos are simultaneously in multiple albums. That gives me control over what’s displayed, but it does mean I have to manually add everything into all the albums I want.
        2. What sort method are you using?
          A Former User @bowlofred
          @bowlofred
          1. 10,000 requests per project per day is allowed. In my calculation, 10 minutes as scanInterval is enough. Not only too short interval but also longer interval could be also problem, because temp URL of photo doesn’t live long. I fix scanInterval over 10 minutes to 10 minutes.
          2. Not possible at this moment, but I’m considering that feature.
          3. For last photo repeat issue : No. I think it might be bug. But on my test it didn’t happen. I’ll look inside.
          4. sort algorithm is here; https://github.com/eouia/MMM-GooglePhotos/blob/master/node_helper.js#L112
          EDITED
          2-1. Suddenly I’ve remembered why I didn’t make that feature. It was related with API quota. Since multi-album searching is not supported by API, module should scan each album on every scan time. It can consume API quota very soon. So I thought it could be problem on real usage.
          • K
            krishnatnl
            @bowlofred
            1. Thanks for your reply. I will set the Interval as you said.
            2. Regarding multiple albums - Now i get it based on your reply and Sean’s reply.
            3. I am using Random as the sort method.
            @Sean
            Thanks for response to all the questions.
            Regarding the Scan Finishing issue, I will try to change the Sort method and try again.
            Reason for asking multiple albums - I take family pics from 2 phones. Both syncing pictures to 2 different Google accounts. So there will be 2 albums. They are all automated and easy. I will work around by sharing one account into another, create an auto-album called ‘MagicMirror’. This should solve the issue.
              @krishnatnl
              If multi-albums could be supported, multi-albums from different accounst would make a problem about managing 2 auths. It might be possible, but I have some doubt about whether it is really needed and useful.
              As you’ve said, shared album would be a better solution. At the moment when I created this, I was regarding that usage.
              Until now, I have half forgotten this module. After solving more urgent issues from my real life, I promise I’ll examine what lays about your scan finishing issue. Could you send me your configuration(without auth info) about this module via email? My email address is eouia0819@gmail.com. And tell me how much photos in your album also.
              Thanks.
              • K
                krishnatnl
                Thanks @Sean
                Will send in the config tonight in email.
                I think Shared Album should work. Will try that once I find some time over weekend.
                I have 3K pictures for now from one phone. More coming from other device (another account which I will try to put in shared album).
                  bowlofred @Guest
                  @sean You mention 10,000 requests per day. Does the number of requests go up with the number of photos in the album? If the album had 1000 photos, would that be a problem? Or is that fine as long as the photos aren’t changing too often?
                    @bowlofred
                    If you have 1000 Photos in an album, and scanning per 10 minutes
                    • on each scan; 20 API quota will be consumed. (max items driven per request are 50)
                    • for 24H running, 144 scans will be performed.
                    • Total consumption : 20 * 144 = 2880 APIs
                    • Around 3000 photos could be safely scanned with 10min scan cycle.
                    However after this calculation, I think I’d better to add a feature to suspend and resume for unused(or hidden) module status.
                      @krishnatnl
                      See above post.
                      I think your problem might be caused by number of photos. API request quota might be over the limits. It could not get new photos from server, so last picture is only you could have at the moment.
                      I’m guessing how to solve this kind of problem now. Hmmm…
                      Growing scanInterval up is not so safe, Because Life of temp url of photo is somewhat short, the url could be expired. Hmmmm… difficult.
                      • K
                        krishnatnl
                        @Sean :
                        Got the scan calculation of how you got 2880 . thanks.
                        Question:
                        Does the Scan calculation mean If scanned every 10 mins, a total of 2880 photos will be scanned in 24 hours?
                        If refresh Interval is every 1 minute, then 60*24 = 144 photos out of the 2880 photos will be shown?
                          @krishnatnl
                          1api request could get 50 pics. 1000 pics need 20 api request. (1 scan)
                          1440scan(1min for 24h) needs 28800 api requests. Thats quota over.
                          • U
                            uzair82
                            I have installed this module and all options are working Except Fullscreen. When i setup to 100% nothing appears in Google Photos.
                            If i set resolution manually it works fine. what could be the reason.
                            Here is the setting.
                             sort: "time", //'time', 'reverse', 'random'
                                showWidth: "100%", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                                showHeight: "100%",
                                originalWidthPx: 1024, // original size of loaded image. (related with image quality)
                                originalHeightPx: 768, // Bigger size gives you better quality, but can give you network burden.
                                mode: "cover", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                              A Former User @uzair82
                              @uzair82 There is no reason not to work. Where(position) did you put your module for fullscreen?
                              • K
                                krishnatnl @Guest
                                @sean
                                This is working fine now.
                                Below is my config snippet:
                                refreshInterval: 1000*30,
                                scanInterval: 1000*60*60, // too many scans might cause API quota limit also.
                                //note(2018-07-29). It is some weird. API documents said temporal image url would live for 1 hour, but it might be broken shorter. So, per 10 min scanning could prevent dead url.
                                sort: "random", //'time', 'reverse', 'random'
                                showHeight: "100%",
                                originalWidthPx: 1920, // original size of loaded image. (related with image quality)
                                originalHeightPx: 1080, // Bigger size gives you better quality, but can give you network burden.
                                Question:
                                My monitor is in Landscape mode. My Landscape pictures displays fine (Fitting exactly in screen). But portraits display in full size cropping the pic mostly and in an expanded view. Only part of image is visible since it large.
                                Is there a way to “Fit the picture into the screen” when it is Portrait just like Landscape? I tried other mode. It is too small and has borders. I want the pic to fit exactly in the screen.
                                My monitor is 22 inch, Full HD (1080P) if that helps.
                                  @krishnatnl
                                  Fit the picture into the screen has obvious meaning.
                                  Portrait image in Landscape Area (and vice versa) Is something like real pictures in real photoframe, you cannot fit your portrait picture into the landscape frame without cutting(mode:cover) or extra margin of both left&right sides(mode:contain). The bigger difference of ratio makes the more uncomfortable looks.
                                  Could be the 3rd option? Give me a suggestion.
                                  PS
                                  I thought options available to consider :
                                  • stretch the width of portrait picture fully to fit to landscape area. It makes your person in portrait looks like a hobbit.
                                  • cut the top and both moderately and also stretch horizontally not too much. Not displaying entire image and not covering whole area, but it will look nicer than current issue. The only problem is, where to cut and how much to expand is not be done automatically.
                                  Is there any idea?
                                  • K
                                    krishnatnl
                                    @Sean
                                    Maybe i did not explain properly. I need a layout for the portrait oriented pictures to fit in the screen without disturbing the aspect Ratio.
                                    MODE:COVER
                                    • Works perfectly for the landscape oriented pictures since it is fitting the picture perfectly in the screen. There is no stretch or crop.
                                    • Portrait oriented pictures are cropped to landscape orientation (technically).
                                    MODE:CONTAIN
                                    • Works fine for the portrait oriented pictures i.e: The full image is visible in the screen, no crop, no stretch
                                    • Landscape pictures are also displayed without crop, but there are borders.
                                    Need something like this:
                                    If the pic is a Landscape oriented one, Mode should be COVER, else should be CONTAIN.
                                    In Other words, need an AUTO-SCALING option.
                                    From a programming perspective, is this feasible? If not, I will try the COVER mode but not liking black borders for all the images.
                                      @krishnatnl
                                      In my MMM-DropboxWallpaper, I applied already that feature(automatically changing mode by ratio). I have been doubting whether it has really usefulness in real usage. Anyway I’ll consider this feature in this module too.
                                        @krishnatnl
                                        I’ve updated. mode:hybrid is available for changing mode:cover or mode:contain automatically by aspect ratio.
                                        • K
                                          krishnatnl
                                          This working fine and solved my issue @Sean . Happy Holidays :)
                                          • K
                                            krouton
                                            Hi Sean,
                                            I keep getting the “[GPHOTO] Scan finished : 0/There is no scanned photo currently.” error however there are 3000 photos in the folder. Sometimes it will successfully scan and display the photos fine but more and more recently it fails.
                                            		module: "MMM-GooglePhotos",
                                            		position: "fullscreen_below",
                                            		disabled: false,
                                            		albumId: "xxxxx", // your album id from result of `auth_and_test.js`
                                            		refreshInterval: 1000*60*5,
                                            		scanInterval: 1000*60*10, // too many scans might cause API quota limit also.
                                            		showWidth: "1380px", // how large the photo will be shown as. (e.g;'100%' for fullscreen)
                                            		showHeight: "1060px",
                                            		originalWidthPx: 1380, // original size of loaded image. (related with image quality)
                                            		originalHeightPx: 1060, // Bigger size gives you better quality, but can give you network burden.
                                            		mode: "contain", // "cover" or "contain" (https://www.w3schools.com/cssref/css3_pr_background-size.asp)
                                            Connecting socket for: MMM-GooglePhotos
                                            MMM-GooglePhotos started
                                            Connecting socket for: MMM-MyCalendar
                                            Starting node helper for: MMM-MyCalendar
                                            Sockets connected & modules started …
                                            Ready to go! Please point your browser to: http://0.0.0.0:8080
                                            MMM-ModuleScheduler is removing all scheduled jobs
                                            MMM-ModuleScheduler received CREATE_GLOBAL_SCHEDULE
                                            MMM-ModuleScheduler is creating a global schedule for all modules using “30 6 * * *” and “00 18 * * *” with dim level 40
                                            MMM-GooglePhotos initialized after loading.
                                            [RCREPO] Repository scanning…
                                            [RCREPO] modules.json is updated.
                                            Inspector shows it loads the module but not an actual photo.
                                            Any help would be greatly appreciated.
                                            • 14
                                            • 15
                                            • 4 / 15
