    Unable to Install Dependencies
    4 Posts 2 Posters 3.6k Views 2 Watching
      alenba2
      Every time I try to install the magic mirror by using the command …
      bash -c "$(curl -sL https://raw.githubusercontent.com/MichMich/MagicMirror/master/installers/raspberry.sh)"
      I get thrown with this error after its done cloning Magic Mirror
      Cloning MagicMirror Done!
      Installing dependencies ...
      (node:8859) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm WARN deprecated express-ipfilter@0.3.1: This package is no longer being maintained and contains security vulnerabilities
      npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically unmaintained. Move on to something better. This package will continue to work with Grunt v1, but it will not receive any updates.
      npm ERR! Error: Method Not Allowed
      npm ERR!     at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
      npm ERR!     at /usr/share/npm/lib/cache/add-named.js:203:12
      npm ERR!     at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
      npm ERR!     at FSReqWrap.oncomplete (fs.js:135:15)
      npm ERR! If you need help, you may report this *entire* log,
      npm ERR! including the npm and node versions, at:
      npm ERR!     <http://github.com/npm/npm/issues>
      npm ERR! System Linux 4.14.79-v7+
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install"
      npm ERR! cwd /home/pi/MagicMirror
      npm ERR! node -v v8.11.1
      npm ERR! npm -v 1.4.21
      npm ERR! code E405
      npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
      > electron-chromedriver@1.7.1 install /home/pi/MagicMirror/node_modules/spectron/node_modules/electron-chromedriver
      > node ./download-chromedriver.js
      npm WARN deprecated circular-json@0.3.3: CircularJSON is in maintenance only, flatted is its successor.
      npm WARN deprecated browserslist@2.11.3: Browserslist 2 could fail on reading Browserslist >3.0 config used in other tools.
      npm ERR!
      npm ERR! Additional logging details can be found in:
      npm ERR!     /home/pi/MagicMirror/npm-debug.log
      npm ERR! not ok code 0
      Unable to install dependencies!
      I’ve noticed the npm version is a little low, but when i try to get it to the latest version, I get thrown with this.
      pi@raspberrypi:~ $ npm install latest-version
      (node:8905) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm ERR! tar.unpack untar error /home/pi/.npm/rc/1.2.8/package.tgz
      npm ERR! command "/usr/bin/node" "/usr/bin/npm" "install" "latest-version"
      npm ERR! code E405
      npm ERR!
      npm ERR!     /home/pi/npm-debug.log
      I also tried to update npm again, but i get this.
      (node:8915) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules/rc'
      npm ERR! error rolling back  package-json@5.0.0 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules/rc'
      npm ERR! error rolling back   errno: -39,
      npm ERR! error rolling back   code: 'ENOTEMPTY',
      npm ERR! error rolling back   syscall: 'rmdir',
      npm ERR! error rolling back   path: '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules/rc' }
      npm ERR! tar.unpack untar error /home/pi/.npm/safe-buffer/5.1.2/package.tgz
      npm ERR! error rolling back Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules'
      npm ERR! error rolling back  latest-version@4.0.0 { Error: ENOTEMPTY: directory not empty, rmdir '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules'
      npm ERR! error rolling back   path: '/home/pi/node_modules/latest-version/node_modules/package-json/node_modules/registry-url/node_modules' }
      npm ERR! code E405
      npm ERR!
      The raspberry pi I’m using is a Raspberry Pi 3 Model B Rev 1.2.
      I’m not quite sure if the error is coming from this
      or entirely something else.
      • lavolp3L Offline
        lavolp3 Module Developer @alenba2
        @alenba2 your npm and node versions are way too old.
        Update npm using:
        npm install npm@latest -g
        (you may need sudo access for that, I’m not sure anymore. Try without first.)
        Update node FOR EXAMPLE by using n:
        npm cache clean -f
        npm install -g n
        n stable
        Again, I’m not sure, try without sudo. If it’s not working try with sudo.
        How to troubleshoot modules
        MMM-soccer v2, MMM-AVStock
          alenba2
          Yea I just solved the problem. I basically changed software from Raspbian Sketch to Raspbian Jessie. Thanks for helping.
          • lavolp3L Offline
            @alenba2 Well MM definitely works with stretch but nevertheless… if it works, I guess it’s ok
