Blank screen after restarting magic mirror?
Did you install any new module? Please check the log via
pm2 log mm
. On the top there is the trailing last 15 lines of the error log, check it you may see some error on thenode.js
side.If you can’t see anything wrong you may want to look into the Webinterface and check if the browsers developer console throws an error.
hmmmm seems i got something thank you!!
one moment to attach the image -
it seems it is something that produces an error but not fatal one, thats why i see a black screen.
is the adress to listen wrong? -
hmm
it seems there is a conflict, i just kill some pid and now it is fine, but if i dont want to have them again starting?
It looks like you have multiple instances of MagicMirror running. I am not quite sure about that, but I the
pm2
mode is set tofork
on my Pi. -
Yeah it seems that 2 electro instances are open, how can I avoid that, what should I do to get away with the conflict?
So every time that I restart it will be 👌? -
@sollekram Just make sure you only one method of starting MagicMirror. I prefere
pm2
. Did you start MagicMirror wit any other method exceptpm2
? prior topm2 restart mm
To install the mm I had runned the installer automatically from github.com with curl, and then I have followed the guide for making it auto start at every boot. And then saved the instance
@sollekram Ok, did you try to reboot your System yet?
