    Blank screen after restarting magic mirror?
    14 Posts 2 Posters 5.7k Views 2 Watching
      sollekram
      it seems it is something that produces an error but not fatal one, thats why i see a black screen.
      is the adress to listen wrong?
        sollekram
        hmm
          sollekram
          it seems there is a conflict, i just kill some pid and now it is fine, but if i dont want to have them again starting?
          • idoodlerI Offline
            idoodler Module Developer
            It looks like you have multiple instances of MagicMirror running. I am not quite sure about that, but I the pm2 mode is set to fork on my Pi.
              sollekram
              Yeah it seems that 2 electro instances are open, how can I avoid that, what should I do to get away with the conflict?
              So every time that I restart it will be 👌?
              idoodlerI 1 Reply Last reply Reply Quote 0
              • idoodlerI Offline
                idoodler Module Developer @sollekram
                @sollekram Just make sure you only one method of starting MagicMirror. I prefere pm2. Did you start MagicMirror wit any other method except pm2? prior to pm2 restart mm?
                  sollekram
                  To install the mm I had runned the installer automatically from github.com with curl, and then I have followed the guide for making it auto start at every boot. And then saved the instance
                  • idoodlerI Offline
                    @sollekram Ok, did you try to reboot your System yet?
                      sollekram @idoodler
                      @idoodler year I saved the currently instances and now the problem solved ;)
                      idoodlerI 1 Reply Last reply Reply Quote 2
                      • idoodlerI Offline
                        @sollekram Awesome!
