Blank screen after restarting magic mirror?
hmmmm seems i got something thank you!!
one moment to attach the image -
it seems it is something that produces an error but not fatal one, thats why i see a black screen.
is the adress to listen wrong? -
hmm
it seems there is a conflict, i just kill some pid and now it is fine, but if i dont want to have them again starting?
It looks like you have multiple instances of MagicMirror running. I am not quite sure about that, but I the
pm2mode is set toforkon my Pi. -
Yeah it seems that 2 electro instances are open, how can I avoid that, what should I do to get away with the conflict?
So every time that I restart it will be 👌? -
@sollekram Just make sure you only one method of starting MagicMirror. I prefere
pm2. Did you start MagicMirror wit any other method exceptpm2? prior topm2 restart mm? -
To install the mm I had runned the installer automatically from github.com with curl, and then I have followed the guide for making it auto start at every boot. And then saved the instance
@sollekram Ok, did you try to reboot your System yet?
@idoodler year I saved the currently instances and now the problem solved ;)
@sollekram Awesome!
