    Blank screen after restarting magic mirror?
    14 Posts 2 Posters 5.7k Views 2 Watching
      sollekram
      this bug seems to appear after i restart the magic mirror many times
      • idoodlerI Offline
        idoodler Module Developer
        Did you install any new module? Please check the log via pm2 log mm. On the top there is the trailing last 15 lines of the error log, check it you may see some error on the node.js side.
        If you can’t see anything wrong you may want to look into the Webinterface and check if the browsers developer console throws an error.
          sollekram
          hmmmm seems i got something thank you!!
          one moment to attach the image
            sollekram
            it seems it is something that produces an error but not fatal one, thats why i see a black screen.
            is the adress to listen wrong?
              sollekram
              hmm
                sollekram
                it seems there is a conflict, i just kill some pid and now it is fine, but if i dont want to have them again starting?
                • idoodlerI Offline
                  It looks like you have multiple instances of MagicMirror running. I am not quite sure about that, but I the pm2 mode is set to fork on my Pi.
                    sollekram
                    Yeah it seems that 2 electro instances are open, how can I avoid that, what should I do to get away with the conflict?
                    So every time that I restart it will be 👌?
                    idoodlerI 1 Reply Last reply Reply Quote 0
                    • idoodlerI Offline
                      idoodler Module Developer @sollekram
                      @sollekram Just make sure you only one method of starting MagicMirror. I prefere pm2. Did you start MagicMirror wit any other method except pm2? prior to pm2 restart mm?
                        sollekram
                        To install the mm I had runned the installer automatically from github.com with curl, and then I have followed the guide for making it auto start at every boot. And then saved the instance
