    how and where should I use the hide&show function offered by MM?
    Scheduled Pinned Locked Moved Solved Development
    7 Posts 4 Posters 2.7k Views 4 Watching
    • G
      grasshopper001
      I tried to hide all other modules except the current module, but it seems does not work. I put my codes to hide other modules inside the start function of the current module.
      Module.register("MMM-hideOtherModules",{
          defaults:{},
          start:function(){
               setTimeout("shutOtherModule",5000);
               function shutOtherModule(){
                   MM.getModules().exceptModule(this).enumerate(function(module){
                       module.hide();
      //not important functions
      Could anyone help me with a sample module to hide other modules? Are there any place to learn about the inner structure of inter-modules communication except the doc?
        turn on the developers console with Ctrl-Shift=i, or npm start dev, then you can use the console and sources tabs to see errors in the module.js and also put stops on code and look at the variables
        as u found, the MM variable is only available in the module.js
        • G
          grasshopper001
          codes&question updated
          setTimeout(shutOtherModule(),10000);
                               module.hide();
          question:
          When I put the above codes in start function, the module never hides other modules.
          When I put the above codes in notificationReceived function and let MagicMirror do the codes after receiving “DOM_OBJECT_CREATED” notification, It seems that the module shuts down all modules including itself, leaving me with a blank mirror.
          • strawberry 3.141S
            strawberry 3.141 Project Sponsor Module Developer @grasshopper001
            @grasshopper001 join me for a bit in discord and we will solve your problem https://forum.magicmirror.builders/topic/9298/magicmirror-hackathon-2018
            • G
              grasshopper001
              It seems that MM is not available?
              I tried to write shutOtherModule function in node-helper, and MagicMirror told me that
              ReferenceError: MM is not defined
              How could I get access to MM object? Why my MagicMirror responded me with a blank mirror when the function is called after receiving “DOM_OBJECT_CREATED” notification?
              • G
                grasshopper001
                Finally I deleted the node helper, it seems that MM functions does not work in node helper functions.
                But the setTimeout function in notificationReceived function still does not work with “DOM_OBJECT_CREATED”.
                  • A
                    Arjan Project Sponsor
                    I use MMM-ModuleScheduler to show or hide modules. It works very simple out of the box.
