Turn monitor on/off with MMM-voice
10 Posts 2 Posters 2.4k Views 2 Watching
    mdhenriksen
    Re: Want to turn off my monitor
    Hey guys! I’ve been reading some old threads and trying to make my monitor turn off and on with a voice command via MMM-voice.
    I’m NOT using a Pi, but a laptop. I’ve tried @Mykle1’s following commands: (from Hello-Lucy - which works)
    exec('xset dpms force off', null);
    exec('xset dpms force on', null);
    I’ve implemented the code in the node_helper.js that executes a command when a voice command is detected:
    } else if (/(CUSTOM)/g.test(data)) {
                this.sendSocketNotification('CUSTOM');
    The above code is executed when my mirror register the word “custom”.
    this.sendSocketNotification(‘CUSTOM’); is there just so I can see if the command is recognized.
    Problem: As it is right now, I can see that my mirror registers and executes the this.sendSocketNotification(‘CUSTOM’); however the exec(‘xset dpms force off’, null); does nothing. Any ideas?
    Thanks in advance!
    ? 1 Reply Last reply Dec 28, 2018, 11:00 AM Reply Quote 0
      A Former User @mdhenriksen
      @mdhenriksen
      Your laptop works with xset dpms force off on a shell? See your energy-saving setting in your environment.
      M 1 Reply Last reply Dec 28, 2018, 11:18 AM Reply Quote 1
        mdhenriksen @Guest
        @sean said in Turn monitor on/off with MMM-voice:
        @mdhenriksen
        Hey Sean! I’m on Ubuntu 18.10, so I guess it should work. I’m pretty sure Mykle1 is on Ubuntu 16.04.
        As far as I know there is no energy-saving settings really. Could you elaborate you answer maybe? :D
        ? 1 Reply Last reply Dec 28, 2018, 11:34 AM Reply Quote 0
          @mdhenriksen
          I’m not experienced with Ubuntu, but I think there might be DPMS manager (Screen saver, monitor on/off) on X. You’d better check using DPMS enabled.
          M 1 Reply Last reply Dec 28, 2018, 11:38 AM Reply Quote 1
            mdhenriksen @Guest
            @sean So you’re saying there might be a setting that allows for the DPMS being turned on and off, right?
            ? 1 Reply Last reply Dec 28, 2018, 11:40 AM Reply Quote 0
              @mdhenriksen
              What would be displayed as the result of xset -q ?
              M 1 Reply Last reply Dec 28, 2018, 3:03 PM Reply Quote 1
                mdhenriksen @Guest
                @sean Hey again Sean,
                So here’s the output of xset -q:
                I noticed the following: Server does not have the DPMS Extension :expressionless_face: Figured that’s why it’s not working. So I’m not sure about this whole DPMS thing. Is it an extension I can install or is it something native to a computer, e.g. hardware?
                Keyboard Control:
                  auto repeat:  on    key click percent:  0    LED mask:  00000000
                  XKB indicators:
                    00: Caps Lock:   off    01: Num Lock:    off    02: Scroll Lock: off
                    03: Compose:     off    04: Kana:        off    05: Sleep:       off
                    06: Suspend:     off    07: Mute:        off    08: Misc:        off
                    09: Mail:        off    10: Charging:    off    11: Shift Lock:  off
                    12: Group 2:     off    13: Mouse Keys:  off
                  auto repeat delay:  500    repeat rate:  33
                  auto repeating keys:  00ffffffdffffbbf
                                        fadfffefffedffff
                                        9fffffffffffffff
                                        fff7ffffffffffff
                  bell percent:  50    bell pitch:  400    bell duration:  100
                Pointer Control:
                  acceleration:  2/1    threshold:  4
                Screen Saver:
                  prefer blanking:  yes    allow exposures:  yes
                  timeout:  0    cycle:  0
                Colors:
                  default colormap:  0x23    BlackPixel:  0x0    WhitePixel:  0xffffff
                Font Path:
                  /usr/share/fonts/X11/misc,/usr/share/fonts/X11/Type1,built-ins
                DPMS (Energy Star):
                ? 1 Reply Last reply Dec 28, 2018, 3:29 PM Reply Quote 0
                  @mdhenriksen said in Turn monitor on/off with MMM-voice:
                  DPMS (Energy Star):
                  I’m not expert of this kind, so I might be wrong.
                  As I know, in nowadays modern linux machine, DPMS is auto detected and enabled if ACPI is also enabled at kernel runtime. However check /etc/X11/xorg.conf.d/ in the Monitor section (Or corresponding alternatives on your environment. Again, I’m not familiar with *nix machines :D )
                  Option "DPMS" "true"
                  M 1 Reply Last reply Dec 28, 2018, 4:31 PM Reply Quote 1
                    mdhenriksen @Guest
                    @sean Yeah, I’m trying to look into that right now, but without much luck at the moment :D
                      mdhenriksen
                      SOLVED
                      This is not really a solution, but my error was that I was logged in on “Ubuntu on Wayland” which doesn’t have DPMS.
                      On the login screen of Ubuntu you can click the little gear-icon and choose what kind of Ubuntu you want to login to. Wayland is a bit restricted, so just go with “Ubuntu” and not “Ubuntu on Wayland”
