    Turn monitor on/off with MMM-voice
    10 Posts 2 Posters 3.1k Views 2 Watching
      A Former User @mdhenriksen
      @mdhenriksen
      I’m not experienced with Ubuntu, but I think there might be DPMS manager (Screen saver, monitor on/off) on X. You’d better check using DPMS enabled.
        mdhenriksen @Guest
        @sean So you’re saying there might be a setting that allows for the DPMS being turned on and off, right?
          @mdhenriksen
          What would be displayed as the result of xset -q ?
            mdhenriksen @Guest
            @sean Hey again Sean,
            So here’s the output of xset -q:
            I noticed the following: Server does not have the DPMS Extension :expressionless_face: Figured that’s why it’s not working. So I’m not sure about this whole DPMS thing. Is it an extension I can install or is it something native to a computer, e.g. hardware?
            Keyboard Control:
              auto repeat:  on    key click percent:  0    LED mask:  00000000
              XKB indicators:
                00: Caps Lock:   off    01: Num Lock:    off    02: Scroll Lock: off
                03: Compose:     off    04: Kana:        off    05: Sleep:       off
                06: Suspend:     off    07: Mute:        off    08: Misc:        off
                09: Mail:        off    10: Charging:    off    11: Shift Lock:  off
                12: Group 2:     off    13: Mouse Keys:  off
              auto repeat delay:  500    repeat rate:  33
              auto repeating keys:  00ffffffdffffbbf
                                    fadfffefffedffff
                                    9fffffffffffffff
                                    fff7ffffffffffff
              bell percent:  50    bell pitch:  400    bell duration:  100
            Pointer Control:
              acceleration:  2/1    threshold:  4
            Screen Saver:
              prefer blanking:  yes    allow exposures:  yes
              timeout:  0    cycle:  0
            Colors:
              default colormap:  0x23    BlackPixel:  0x0    WhitePixel:  0xffffff
            Font Path:
              /usr/share/fonts/X11/misc,/usr/share/fonts/X11/Type1,built-ins
            DPMS (Energy Star):
              @mdhenriksen said in Turn monitor on/off with MMM-voice:
              DPMS (Energy Star):
              I’m not expert of this kind, so I might be wrong.
              As I know, in nowadays modern linux machine, DPMS is auto detected and enabled if ACPI is also enabled at kernel runtime. However check /etc/X11/xorg.conf.d/ in the Monitor section (Or corresponding alternatives on your environment. Again, I’m not familiar with *nix machines :D )
              Option "DPMS" "true"
                mdhenriksen @Guest
                @sean Yeah, I’m trying to look into that right now, but without much luck at the moment :D
                  mdhenriksen
                  SOLVED
                  This is not really a solution, but my error was that I was logged in on “Ubuntu on Wayland” which doesn’t have DPMS.
                  On the login screen of Ubuntu you can click the little gear-icon and choose what kind of Ubuntu you want to login to. Wayland is a bit restricted, so just go with “Ubuntu” and not “Ubuntu on Wayland”
