    Updating 6db61b4..de57daa
    26 Posts 9 Posters 14.9k Views 9 Watching
    • idoodlerI
      idoodler Module Developer @icephreaq
      @icephreaq What is git status telling you?
        costascontis
        i also get an error from git pull:
        pi@magicmirror:~/MagicMirror $ sudo git pull && npm install
        error: Your local changes to the following files would be overwritten by merge:
        	package-lock.json
        	vendor/package-lock.json
        Please commit your changes or stash them before you merge.
        Aborting
        and i dont know what to do…
        D idoodlerI 2 Replies Last reply
          dazza120 @costascontis
          @costascontis rename them and the git pull will make a new version of them, but be warned I’m not sure if that’s why calendar just displays loading when it was working on previous but don’t think so as all the other modules work.
          • idoodlerI
            idoodler Module Developer @costascontis
            @costascontis You can just delete both package-lock.jsonfiles. Everything will work after you have deleted them.
            M 1 Reply Last reply
              MWel1977 @idoodler
              I have the same problem as @costascontis and will try to delete that file.
              But I also would like to know what the latest version of Node.js is.
              At https://github.com/nodesource/distributions#debinstall I can see a version 11.x.
              my version on the pi 3B+ is v9.11.2
              Is that the latest version or must I update to v11.x via:
              sudo su
              curl -sL https://deb.nodesource.com/setup_11.x | bash -
              apt-get install -y nodejs
                MWel1977 @MWel1977
                Just moved the package-lock.js to a new folder “Old files” and run “sudo git pull && npm install” again and it worked for me.
                I do get some warnings from “time-grunt@2.0.0” and 2 from npm skipping optional dependency’s but below that it reads: MagicMirror installation succesfull! NICE!.. well…that last word isn’t part of the update! Hahaha
                And below that it found 9 vulnerabilities. Is that a problem?
                  dazza120 @MWel1977
                  @mwel1977 even the calendar as mine is up the swannie
                    MWel1977 @dazza120
                    @dazza120 I’m not using the standard calendar.
                    But after the update my MM2 works like before. Only the modules I’m working on are still not showing correctly…becouse I’m working on them to get them to work properly. :smiling_face_with_open_mouth_cold_sweat: :smiling_face_with_open_mouth_cold_sweat:
                    But what do you mean with: “…is up the swannie”?
                    you mean it doesn’t work?
                    D 1 Reply Last reply
                      @mwel1977 said in Updating 6db61b4..de57daa:
                      the swannie
                      swannie river
                      up the river…
                      http://www.musicanet.org/robokopp/usa/waydownu.htm
                        dazza120 @MWel1977
                        @mwel1977 yep UK local slang, anyway I’ve sorted it now I downloaded the Magic Mirror from github on the Pi, unzipped it and then copied the whole folder to the module default location and over wrote everything, it was missing a lot of files for some reason. Anyway enough said it’s working like it should now 👌🏾
                        • idoodlerI
                          idoodler Module Developer @MWel1977
                          @mwel1977 The vulnerabilities needs to be fixed by the module developer. Thats not your responsibility, you can just ignore them.
                          Because of the Node.js version: You don’t have to update to a newer version of Node.js. Latest isn’t always the greatest, there are some known compatibility issues with v11.
                            rosenm
                            this one helped me:
                            https://forum.magicmirror.builders/topic/4418/update/3
                            • ScrewyoudriverS
                              Screwyoudriver
                              I renamed the old folder and did a fresh installation. Half an hour of work if you use the old config and css.
                              • I
                                icephreaq
                                I do have an active internet connection. I typically admin my mirror through SSH from a separate Linux machine and I’m able to connect to the mirror and update other items without issue. git status gives the following.
                                On branch master
                                Your branch is behind 'origin/master' by 124 commits, and can be fast-forwarded.
                                  (use "git pull" to update your local branch)
                                  (use "git add <file>..." to update what will be committed)
                                  (use "git checkout -- <file>..." to discard changes in working directory)
                                	modified:   fonts/package-lock.json
                                	modified:   package-lock.json
                                	modified:   package.json
                                	modified:   vendor/package-lock.json
                                Untracked files:
                                  (use "git add <file>..." to include in what will be committed)
                                	core
                                	nohup.out
                                no changes added to commit (use "git add" and/or "git commit -a")
                                B 1 Reply Last reply
                                  bhepler Module Developer @icephreaq
                                  @icephreaq - Give this a try:
                                  git stash
                                  git pull
                                  npm install
                                  Also, @costascontis - You shouldn’t run the git commands as sudo. You may end up screwing up your permissions on the files pulled down from git.
                                  • I
                                    icephreaq
                                    I ended up removing all instances of package-lock.json and ran git pull and was able to successfully update. Thanks for everyone’s input on this!
                                      MWel1977 @idoodler
                                      @idoodler Okay. Thanks for that answer! hehehehe…
                                      Anyway my MM2 is working like it should be after I moved that folder and did the git pull again.
                                      But about the steps to take on how to update a module or a dependency or Node.js in my case… is that written down somewere here on the forum?
                                      Like… all the steps someone needs to take in order to keep MM2 in shape?
                                        dazza120 @MWel1977
                                        @mwel1977 get yourself MMM-RemoteControl and MMM-RemoteRepositories to get those modules updated easily, it will check through them and update automagically when you go into the html page
                                          MWel1977 @dazza120
                                          @dazza120 Thanks for the tip!
                                          Downside of that is that I don’t learn how things work.
                                          Doing it myself (with some help of you all wonderfull people here) is the best way of learning things.
                                          I do have SSH setup so I can dail in via my smartphone…but first I need to get better in the commandline commands.
                                            dazza120 @MWel1977
                                            @mwel1977 I use VNC on my Pi to connect to it then terminal and just install those like you would any module then edit the config file, then just log into the html page which would be the address of your device xxxxxx:8080/remote.html
                                            and that’s the rest of the magic is done on that webpage
