Updated to MM v2.6.0 now all I get is only a black Electron screen...
7 Posts 3 Posters 2.1k Views 1 Watching
    Cr4z33
    So I did the update and ended up with the black empty screen.
    I then made backup of my config and modules and deleted the whole MagicMirror folder to make a fresh install.
    I keep getting the black empty Electron screen and this with everything default (no custom config, no custom modules added yet)… :disappointed_face:
    Ran also sudo apt-get update and sudo apt-get upgrade
    Here is what comes up from the console:
    > magicmirror@2.6.0 start /home/pi/MagicMirror
    > sh run-start.sh
    Starting MagicMirror: v2.6.0
    Loading config ...
    Loading module helpers ...
    All module helpers loaded.
    Server started ...
    Starting module: newsfeed
    { Error: listen EADDRINUSE 127.0.0.1:8080
        at Object._errnoException (util.js:1024:11)
        at _exceptionWithHostPort (util.js:1046:20)
        at Server.setupListenHandle [as _listen2] (net.js:1351:14)
        at listenInCluster (net.js:1392:12)
        at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
        at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
      code: 'EADDRINUSE',
      errno: 'EADDRINUSE',
      syscall: 'listen',
      address: '127.0.0.1',
      port: 8080 }
    Launching application.
    Please help as my mirror is almost done. :confounded_face:
      @cr4z33 said in Updated to MM v2.6.0 now all I get is only a black Electron screen...:
      means some other app is using port 8080…
      I would reboot
      C 1 Reply Last reply Jan 3, 2019, 1:37 PM Reply Quote 0
        Cr4z33 @sdetweil
        @sdetweil doh how could I not think about it lol! :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing:
        Thanks working now!
        S 1 Reply Last reply Jan 3, 2019, 1:38 PM Reply Quote 0
          sdetweil @Cr4z33
          @cr4z33 great!.. can u mark your problem as closed…
          C 1 Reply Last reply Jan 3, 2019, 1:39 PM Reply Quote 0
            Cr4z33 @sdetweil
            @sdetweil done.
              michael5r Module Developer
              In case someone else has this problem, instead of rebooting just run the following in your terminal:
              kill -9 $(lsof -t -i :8080)
              That’ll kill the current process on port 8080.
                or kill all node related
                ps -ef | grep node | awk  '{print $2}' | xargs kill -9
