    Installing on a Pi Zero
    175 Posts 33 Posters 303.4k Views 33 Watching
    • idoodlerI
      idoodler Module Developer @andyc7687
      @andyc7687 You need to do the following:
      • Clone your forked repository to your local machine
      • Adopt installers/raspberry.sh to include your Raspberry Pi Zero specific code
      • Commit and push your changes to Github
      • Test it on a Raspberry Pi Zero by execute bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
      • Create a Pull Request on the original MagicMirror repository
      Just contact me if you need any help, I can also test your changes, I have a spare Raspberry Pi Zero W on hand.
      A 1 Reply Last reply
      • A
        andyc7687 @idoodler
        @idoodler Great! I think I may have done it! I have tested most of it I think on a Pi Zero W and on a Pi 3B+; is anyone able to check whether any of my changes have affected usability on the Pi 3B and Pi 2 before I submit the pull request?
        idoodlerI E 3 Replies Last reply
        • idoodlerI
          @andyc7687 I am able to try it today, I will contact you again.
          • idoodlerI
            @andyc7687 I just noticed, is this a server only installation?
            • A
              andyc7687 @idoodler
              @idoodler I didn’t really understand what was the difference between server only and not. This installs magic mirror, runs it as server only and runs three chromium browser on start-up to display it all… functionally I couldn’t tell the difference, but there might be something I’m missing
                dazza120
                Pi 3B+ can run the normal magic mirror load file no need to include it in the server only script, just means you need the full fat OS on the Pi
                • A
                  andyc7687 @dazza120
                  @dazza120 thanks, did you test my script? I was looking at a single installer that would auto detect 2B/3B Or Zero and install the appropriate script, thereby meaning a single repo for all platforms.
                  It’s able to detect 3B+ and Zero and does full install for 3B+ and server only for Zero, I don’t have a 3B though to make sure it works on that.
                  D 1 Reply Last reply
                    dazza120 @andyc7687
                    @andyc7687 no mate I done a normal install from the magic mirror bash,I’ve done it twice as I was trying to make the install as light as possible so I was trying to use Stretch with just the basic but it wouldn’t have any of it so had to install the fat version and purge all the bloat ware but from what I’ve looked at so far doesn’t use that much more ram than the lite version, only thing I ended up doing was installing PM2 manually as for some reason it wouldn’t work from the bash after restart.
                      12wsx
                      after install on piZero (no W version) everything is ok but serveronly and browser does not start automatically. When I send from terminal:
                      cd ~/MagicMirror;
                      node serveronly
                      server start properly, In browser manually start localhost:8080 showing MagicMirror website properly. What m i missing?
                      • A
                        andyc7687 @12wsx
                        @12wsx straight after installation did you restart the pi zero? It should run, it’s quite a slow start up process though… if you run pm2 show MagicMirror what does it say? It takes a good minute to fire up sometimes…
                          12wsx
                          Yes i have rebooted and wait about 10min and nothing.
                          pm2 show MagicMirror says:
                          root@raspberrypi:/home/pi/MagicMirror# pm2 show MagicMirror
                          [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
                          [PM2] PM2 Successfully daemonized
                          [PM2][WARN] MagicMirror doesn't exist
                          :confused_face:
                          • A
                            andyc7687 @12wsx
                            @12wsx Did you change the default user to be called root? I’m confused as to why your prompt says root@raspberrypi, but the home directory (/home/pi/MagicMirror) is that instead of /home/root/MagicMirror
                            As I remember, the shell script refers directly to a home drive using the user pi; if you wish to change this on your installation, issue:
                            EDIT: I just noticed I think you’re running off my installer rather than the forked magic mirror repository that I have been testing more recently. The edits are the same, except instead of being in ~/MagicMirror/installers it’ll be in ~/MagicMirror/PiZero, and the files won’t have Pi0 on the end of their names
                            sudo nano ~/MagicMirror/installers/startMagicMirror.sh
                            change the bottom line so instead of pi it is the correct user’s home drive e.g.
                            sh /home/root/MagicMirror/installers/chromium_startPi0.sh
                            Also check pm2_MagicMirrorPi0.json and chromium_startPi0.sh in case they also are pointing to the pi user folder.
                            then do
                            sudo chmod a+x ~/MagicMirror/installers/startMagicMirrorPi0.sh;
                            sudo chmod a+x ~/MagicMirror/installers/pm2_MagicMirrorPi0.json;
                            sudo chmod a+x ~/MagicMirror/installers/chromium_startPi0.sh;
                            to make all the files executable (just in case they aren’t already)
                            Now run:
                            sudo su -c "env PATH=$PATH:/usr/bin pm2 startup systemd -u pi --hp /home/pi"
                            pm2 start ~/MagicMirror/installers/pm2_MagicMirrorPi0.json
                            pm2 save
                            changing the /home/pi to ensure you are in the correct user.
                            Then restart and let me know what happens.
                            That’s the only thing that I can think it could be at the moment
                              Big11
                              @andyc7687 said in Installing on a Pi Zero:
                              Need help…
                              I have installed MM on my PiZero’s many times with no succes to start it just localy and automatically …
                              i followed your script and all seems running well and i did what you decided to autostart with PM2…
                              but it didn’t
                              after rebooting i can see the process “PM2 v3.4.2 GOD” running, but Nothing happens on my screen
                              I tried to start the three startscripts manually and i got an Gtk-Error starting chromium-browser which i can’t work
                              That it basicly works is shown when i start first the xserver manually (startx) and then whitin starting chromium-browser and Point it to http://localhost:8080…
                              What is going wrong?
                              where i can see some Errors ?
                              Thanks a lot…
                              • A
                                andyc7687 @Big11
                                @big11 From what I am reading of your reply, are you booting into command line mode? You should be booting into Desktop AutoLogin from sudo raspi-config | Choose option: Boot Options | Choose option: Desktop / CLI | then Desktop Autologin.
                                Can you confirm which install script you ran? Did you run the one from ac2799/MagicMirror or ac2799/MagicMirrorPi0Installer?
                                B 1 Reply Last reply
                                  12wsx
                                    12wsx
                                    same problem to me.
                                    using raspberry pi Zero (not W)
                                    installed latest Raspbian Stretch with desktop. update from first run creator.
                                    Full instalation LOG
                                    pi@raspberrypi:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/     MagicMirror/master/installers/raspberry.sh)"
                                    $$$\    $$$ |                    \__|          $$$\    $$$ |\__|                                             $$  __$$\
                                    $$$$\  $$$$ | $$$$$$\   $$$$$$\  $$\  $$$$$$$\ $$$$\  $$$$ |$$\  $$$$$$\   $$$$$     $\   $$$$$$\   $$$$$$\  \__/  $$ |
                                    $$\$$\$$ $$ | \____$$\ $$  __$$\ $$ |$$  _____|$$\$$\$$ $$ |$$ |$$  __$$\ $$  __     $$\ $$  __$$\ $$  __$$\  $$$$$$  |
                                    $$ \$$$  $$ | $$$$$$$ |$$ /  $$ |$$ |$$ /      $$ \$$$  $$ |$$ |$$ |  \__|$$ |       \__|$$ /  $$ |$$ |  \__|$$  ____/
                                    $$ |\$  /$$ |$$  __$$ |$$ |  $$ |$$ |$$ |      $$ |\$  /$$ |$$ |$$ |      $$ |           $$ |  $$ |$$ |      $$ |
                                    $$ | \_/ $$ |\$$$$$$$ |\$$$$$$$ |$$ |\$$$$$$$\ $$ | \_/ $$ |$$ |$$ |      $$ |           \$$$$$$  |$$ |      $$$$$$$$\
                                    \__|     \__| \_______| \____$$ |\__| \_______|\__|     \__|\__|\__|      \__|            \______/ \__|      \________|
                                                            \______/
                                    If you are running a Pi Zero, installation will continue, but you will have to r     un in server only mode.
                                    Updating packages ...
                                    Stary:1 http://archive.raspberrypi.org/debian stretch InRelease
                                    Stary:2 http://raspbian.raspberrypi.org/raspbian stretch InRelease
                                    Czytanie list pakietów... Gotowe
                                    Budowanie drzewa zależności
                                    Odczyt informacji o stanie... Gotowe
                                    Obliczanie aktualizacji... Gotowe
                                    0 aktualizowanych, 0 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
                                    E: Nie udało się otworzyć pliku blokady /var/lib/dpkg/lock - open (13: Brak dost     ępu)
                                    E: Nie udało się zablokować katalogu administracyjnego (/var/lib/dpkg/), czy uży     to uprawnień administratora?
                                    Update failed, carrying on installation ...
                                    Installing helper tools ...
                                    build-essential is already the newest version (12.3).
                                    curl is already the newest version (7.52.1-5+deb9u8).
                                    git is already the newest version (1:2.11.0-3+deb9u4).
                                    unzip is already the newest version (6.0-21).
                                    wget is already the newest version (1.18-5+deb9u2).
                                    Node.js is not installed.
                                    Installing Node.js ...
                                    Downloading node v11.6.0
                                      % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
        Dload  Upload   Total   Spent    Left  Speed
                                    100 17.0M  100 17.0M    0     0   861k      0  0:00:20  0:00:20 --:--:--  968k
                                    Extracting node v11.6.0
                                    Extracting node and npm
                                    Zostaną zainstalowane następujące NOWE pakiety:
                                      unclutter
                                    0 aktualizowanych, 1 nowo instalowanych, 0 usuwanych i 0 nieaktualizowanych.
                                    Konieczne pobranie 16,6 kB archiwów.
                                    Po tej operacji zostanie dodatkowo użyte 47,1 kB miejsca na dysku.
                                    Pobieranie:1 http://ftp.icm.edu.pl/pub/Linux/distributions/raspbian/raspbian str     etch/main armhf unclutter armhf 8-20 [16,6 kB]
                                    Pobrano 16,6 kB w 1s (14,1 kB/s)
                                    Prekonfiguracja pakietów ...
                                    Wybieranie wcześniej niewybranego pakietu unclutter.
                                    (Odczytywanie bazy danych ... 80763 pliki i katalogi obecnie zainstalowane.)
                                    Przygotowywanie do rozpakowania pakietu .../unclutter_8-20_armhf.deb ...
                                    Rozpakowywanie pakietu unclutter (8-20) ...
                                    Konfigurowanie pakietu unclutter (8-20) ...
                                    Przetwarzanie wyzwalaczy pakietu man-db (2.7.6.1-2)...
                                    Cloning MagicMirror ...
                                    Cloning into 'MagicMirror'...
                                    remote: Enumerating objects: 305, done.
                                    remote: Counting objects: 100% (305/305), done.
                                    remote: Compressing objects: 100% (273/273), done.
                                    remote: Total 305 (delta 37), reused 169 (delta 22), pack-reused 0
                                    Receiving objects: 100% (305/305), 614.71 KiB | 747.00 KiB/s, done.
                                    Resolving deltas: 100% (37/37), done.
                                    Cloning MagicMirror Done!
                                    Installing dependencies ...
                                    npx: zainstalowano 405 w 218.392s
                                    npm notice CANARY npmc is experimental software. If you find an issue, please fi     le it in the main npm repository, and call out that you were using npmc.
                                    npm WARN deprecated time-grunt@2.0.0: Deprecated because Grunt is practically un     maintained. Move on to something better. This package will continue to work with      Grunt v1, but it will not receive any updates.
                                    npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@n     pmjs.com for more info.
                                    > electron-chromedriver@1.8.0 install /home/pi/MagicMirror/node_modules/electron     -chromedriver
                                    > node ./download-chromedriver.js
                                    successfully dowloaded and extracted!
                                    > electron@2.0.16 postinstall /home/pi/MagicMirror/node_modules/electron
                                    > node install.js
                                    Downloading SHASUMS256.txt
                                    [============================================>] 100.0% of 5.39 kB (5.39 kB/s)
                                    > magicmirror@2.6.0 install /home/pi/MagicMirror
                                    > cd vendor && npm install
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fse     vents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@     1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"}     )
                                    added 82 packages from 57 contributors and audited 220 packages in 118.631s
                                    found 3 low severity vulnerabilities
                                      run `npm audit fix` to fix them, or `npm audit` for details
                                    > magicmirror@2.6.0 postinstall /home/pi/MagicMirror
                                    > sh installers/postinstall/postinstall.sh && npm run install-fonts
                                    MagicMirror installation successful!
                                    > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                                    > cd fonts && npm install
                                    added 1 package from 1 contributor and audited 1 package in 42.42s
                                    found 0 vulnerabilities
                                    npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is      installed. You must install peer dependencies yourself.
                                    npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed.      You must install peer dependencies yourself.
                                    added 921 packages from 1366 contributors in 1049.638s
                                    Errors while installing dependencies! (source command: npmc@latest install)
                                    + acorn@6.0.5
                                    added 2 packages from 78 contributors, updated 1 package and audited 2467 packag     es in 175.814s
                                    found 8 vulnerabilities (7 low, 1 high)
                                    Errors while installing dependencies! (source command: npm install acorn@latest)
                                    + stylelint@9.9.0
                                    added 155 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 458.975s
                                    found 4 vulnerabilities (3 low, 1 high)
                                    Errors while installing dependencies! (source command: pm install stylelint@latest)
                                    + jshint@2.9.7
                                    added 2 packages from 1 contributor, removed 6 packages and updated 5 packages in 226.509s
                                    fixed 3 of 4 vulnerabilities in 4452 scanned packages
                                      1 vulnerability required manual review and could not be updated
                                    Vulnerabilities may remain!
                                    Check plymouth installation ...
                                    Splashscreen: Checking themes directory.
                                    Splashscreen: Create theme directory if not exists.
                                    Splashscreen: Theme copied successfully.
                                    Splashscreen: Changed theme to MagicMirror successfully.
                                    Do you want use pm2 for auto starting of your MagicMirror (y/N)?y
                                    /usr/local/bin/pm2 -> /usr/local/lib/node_modules/pm2/bin/pm2
                                    /usr/local/bin/pm2-dev -> /usr/local/lib/node_modules/pm2/bin/pm2-dev
                                    /usr/local/bin/pm2-docker -> /usr/local/lib/node_modules/pm2/bin/pm2-docker
                                    /usr/local/bin/pm2-runtime -> /usr/local/lib/node_modules/pm2/bin/pm2-runtime
                                    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/pm2/node_modules/fsevents):
                                    npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm"})
                                    + pm2@3.2.4
                                    added 313 packages from 246 contributors in 320.301s
                                    __/\\\\\\\\\\\\\____/\\\\____________/\\\\____/\\\\\\\\\_____
                                     _\/\\\/////////\\\_\/\\\\\\________/\\\\\\__/\\\///////\\\___
                                      _\/\\\_______\/\\\_\/\\\//\\\____/\\\//\\\_\///______\//\\\__
                                       _\/\\\\\\\\\\\\\/__\/\\\\///\\\/\\\/_\/\\\___________/\\\/___
                                        _\/\\\/////////____\/\\\__\///\\\/___\/\\\________/\\\//_____
                                         _\/\\\_____________\/\\\____\///_____\/\\\_____/\\\//________
                                          _\/\\\_____________\/\\\_____________\/\\\___/\\\/___________
                                           _\/\\\_____________\/\\\_____________\/\\\__/\\\\\\\\\\\\\\\_
                                            _\///______________\///______________\///__\///////////////__
                                                              Runtime Edition
                                            PM2 is a Production Process Manager for Node.js applications
                                                         with a built-in Load Balancer.
                                                    Start and Daemonize any application:
                                                    $ pm2 start app.js
                                                    Load Balance 4 instances of api.js:
                                                    $ pm2 start api.js -i 4
                                                    Monitor in production:
                                                    $ pm2 monitor
                                                    Make pm2 auto-boot at server restart:
                                                    $ pm2 startup
                                                    To go further checkout:
                                                    http://pm2.io/
                                    [PM2] Init System found: systemd
                                    Platform systemd
                                    Template
                                    [Unit]
                                    Description=PM2 process manager
                                    Documentation=https://pm2.keymetrics.io/
                                    After=network.target
                                    [Service]
                                    Type=forking
                                    User=pi
                                    LimitNOFILE=infinity
                                    LimitNPROC=infinity
                                    LimitCORE=infinity
                                    Environment=PATH=/usr/local/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                                    Environment=PM2_HOME=/home/pi/.pm2
                                    PIDFile=/home/pi/.pm2/pm2.pid
                                    ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
                                    ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
                                    ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
                                    [Install]
                                    WantedBy=multi-user.target
                                    Target path
                                    /etc/systemd/system/pm2-pi.service
                                    Command list
                                    [ 'systemctl enable pm2-pi' ]
                                    [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                                    [PM2] Making script booting at startup...
                                    [PM2] [-] Executing: systemctl enable pm2-pi...
                                    Created symlink /etc/systemd/system/multi-user.target.wants/pm2-pi.service → /etc/systemd/system/pm2-pi.service.
                                    [PM2] [v] Command successfully executed.
                                    [PM2] Freeze a process list on reboot via:
                                    $ pm2 save
                                    [PM2] Remove init script via:
                                    $ pm2 unstartup systemd
                                                              Runtime Edition
                                                    $ pm2 start app.js
                                                    $ pm2 monitor
                                                    $ pm2 startup
                                                    http://pm2.io/
                                    [PM2] Spawning PM2 daemon with pm2_home=/home/pi/.pm2
                                    [PM2][WARN] Applications MagicMirror not running, starting...
                                    [PM2] App [MagicMirror] launched (1 instances)
                                    │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory │
                                    │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 0   │ 0%     │ 2.5 MB   │
                                     Use `pm2 show ` to get more details about an app
                                    [PM2] Saving current process list...
                                    [PM2] Successfully saved in /home/pi/.pm2/dump.pm2
                                    We're ready! Restart your Pi Zero to start your MagicMirror.
                                    pi@raspberrypi:~ $ sudo login as: pi
                                    individual files in /usr/share/doc/*/copyright.
                                    Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
                                    permitted by applicable law.
                                    Last login: Mon Jan  7 20:33:42 2019
                                                            \______/
                                      unclutter
                                    > node install.js
                                    + acorn@6.0.5
                                    + stylelint@9.9.0
                                    + jshint@2.9.7
                                    Do you want usHasło:
                                    Nieprawidłowe logowanie
                                    raspberrypi login: rror (y/N)?y
                                    + pm2@3.2.4
                                                              Runtime Edition
                                                    $ pm2 start app.js
                                                    $ pm2 monitor
                                                    $ pm2 startup
                                                    http://pm2.io/
                                    Platform systemd
                                    Template
                                    [Unit]
                                    [Service]
                                    Type=forking
                                    User=pi
                                    LimitNPROC=infinity
                                    LimitCORE=infinity
                                    [Install]
                                    Target path
                                    Command list
                                    $ pm2 save
                                                              Runtime Edition
                                                    $ pm2 start app.js
                                                 Hasło:
                                    after reboot server work properly. If I connect from my computer webbrowser everythings is fine.
                                    On local LCD raspberry load to desktop and do not run chromium (default browser)
                                    sorry for 2 post one by one.
                                      Big11 @andyc7687
                                      @andyc7687
                                      i run just
                                      bash -c “$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)”
                                      don’t know if this leads to bare or Pi0 …
                                      This is your “modified” installer script also for the Pi0…
                                      • A
                                        andyc7687 @Big11
                                        @big11 this goes to my forked repo. Are you booting through to the desktop or to the console?
                                          Big11 @andyc7687
                                          @andyc7687
                                          so since yesterday i installed many times from Scratch but without success……
                                          With your script i ran into Troubles with a lot of Errors…
                                          missing dependencies….
                                          so i suggest to do more steps after “sudo apt INSTALL --fix-missing” -> “apt UPGRADE --fix-missing” does not work…
                                          sudo dpkg –configure -a. and.
                                          sudo apt install -f.
                                          at npm install a lot of Warnings e.g.
                                          added 921 packages from 1366 contributors and audited 2466 packages in 859.404s
                                          + stylelint@9.9.0
                                          added 156 packages from 107 contributors, removed 32 packages, updated 99 packages, moved 6 packages and audited 4452 packages in 370.707s
                                          pi@magicpi:~ $   run `npm audit fix` to fix them, or `npm audit` for details
                                          npm ERR! code EAUDITNOPJSON
                                          npm ERR! audit No package.json found: Cannot audit a project without a package.json
                                          npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_26_138Z-debug.log
                                          npm ERR!     /home/pi/.npm/_logs/2019-01-09T07_05_35_497Z-debug.log
                                          -bash: run: Kommando nicht gefunden.
                                          pi@magicpi:~ $ Errors while installing dependencies! (source command: pm install stylelint@latest)
                                          -bash: Syntaxfehler beim unerwarteten Wort `('
                                          i could fix this with
                                          "npm audit fix" or "npm audit fix --force" in directory MagicMirror
                                          and then i figured out autostart with PM2 as described in MM-Wiki but…
                                          it won’t start …
                                          as done in the guide i created a mm.sh script und configured this for autostart with pm2
                                          at next start Nothing happens to start MagicMirror localy
                                          a “pm2 logs mm”
                                          Shows a loop of “sh run-start.sh”
                                          |mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                                          0|mm       | > sh run-start.sh
                                          0|mm       |
                                          0|mm       |
                                          0|mm       | > magicmirror@2.6.0 start /home/pi/MagicMirror
                                          0|mm       |
                                          0|mm       |
                                          0|mm       |
                                          0|mm       |
                                          a cat to run-start.sh Shows
                                          pi@magicpi:~/MagicMirror $ cat run-start.sh
                                          if [ -z "$DISPLAY" ]; then #If not set DISPLAY is SSH remote or tty
                                                  export DISPLAY=:0 # Set by default display
                                          fi
                                          electron js/electron.js $1
                                          but electron.js isn’t installed
                                          trying manually install this with
                                          sudo npm install electron -g
                                          ended again in Error-Messages
                                          Error: EACCES: permission denied, mkdir '/usr/local/lib/node_modules/electron/.electron'
                                          npm ERR! code ELIFECYCLE
                                          npm ERR! errno 1
                                          npm ERR! electron@4.0.1 postinstall: `node install.js`
                                          npm ERR! Exit status 1
                                          npm ERR!
                                          npm ERR! Failed at the electron@4.0.1 postinstall script.
                                          npm ERR!     /root/.npm/_logs/2019-01-09T09_13_51_893Z-debug.log
                                          so… now i’m giving up for These days….
                                          does anybody know where my Failure is ??
                                          Thank you
                                          • A
                                            andyc7687 @Big11
                                            @big11 I did a test install today, so I’m really not sure what you are doing.
                                            You will notice that the missing dependencies are installed in subsequent steps (e.g. there’s a problem with style lint and acorn. This is then fixed (see where it says + stylelint@9.9.0 and + acorn lower down in your warnings).
                                            This installation is completely different from the MM-Wiki. It does not use sh run-start.sh at all. Therefore there may well be problems.
                                            Can I ask, are you doing your installation over SSH/Telnet? or on the Pi itself? because you keep mentioning ‘locally’ and I just want to make sure I know what you mean by that.
                                            Edit: Also, don’t use npm install in sudo; it should be run as the normal user
                                            • 1 / 9
