    Installing on a Pi Zero
    175 Posts 33 Posters 264.8k Views 33 Watching
      aidandon
      I can confirm this works. To run server cd MagicMirror then run command node server only.
      Appreciate this work!
        Ramez
        great :raising_hands: i think your zero repository should be mentioned in the main MM readme
          andyc7687 @Ramez
          @ramez Thanks Ramez, I was hoping someone might say that; don’t know who is the contributors to the main repository. Happy for a link to be passed, or for my repo to be placed back in the MM repo.
            andyc7687 @aidandon
            @aidandon you will only need to cd MagicMirror and run node server only immediately after first install if you want it straight away. Otherwise when you reboot it will go automatically (after about a 1 minute or so wait)
            • idoodlerI Offline
              idoodler Module Developer @andyc7687
              @andyc7687 Nice work. I think you should fork the MagicMirror repository, add merge your scripts with the installers/raspberry.sh script for direct implementation in the project.
                andyc7687 @idoodler
                @idoodler Thanks for that advice, I have forked the original MagicMirror repo, but no idea how to merge scripts on github…
                idoodlerI 1 Reply Last reply Reply Quote 0
                • idoodlerI Offline
                  @andyc7687 You need to do the following:
                  • Clone your forked repository to your local machine
                  • Adopt installers/raspberry.sh to include your Raspberry Pi Zero specific code
                  • Commit and push your changes to Github
                  • Test it on a Raspberry Pi Zero by execute bash -c "$(curl -sL https://raw.githubusercontent.com/ac2799/MagicMirror/master/installers/raspberry.sh)"
                  • Create a Pull Request on the original MagicMirror repository
                  Just contact me if you need any help, I can also test your changes, I have a spare Raspberry Pi Zero W on hand.
                  A 1 Reply Last reply Reply Quote 1
                    andyc7687 @idoodler
                    @idoodler Great! I think I may have done it! I have tested most of it I think on a Pi Zero W and on a Pi 3B+; is anyone able to check whether any of my changes have affected usability on the Pi 3B and Pi 2 before I submit the pull request?
                    idoodlerI E 3 Replies Last reply Reply Quote 1
                    • idoodlerI Offline
                      @andyc7687 I am able to try it today, I will contact you again.
                      • idoodlerI Offline
                        @andyc7687 I just noticed, is this a server only installation?
                          andyc7687 @idoodler
                          @idoodler I didn’t really understand what was the difference between server only and not. This installs magic mirror, runs it as server only and runs three chromium browser on start-up to display it all… functionally I couldn’t tell the difference, but there might be something I’m missing
                            dazza120
                            Pi 3B+ can run the normal magic mirror load file no need to include it in the server only script, just means you need the full fat OS on the Pi
                              andyc7687 @dazza120
                              @dazza120 thanks, did you test my script? I was looking at a single installer that would auto detect 2B/3B Or Zero and install the appropriate script, thereby meaning a single repo for all platforms.
                              It’s able to detect 3B+ and Zero and does full install for 3B+ and server only for Zero, I don’t have a 3B though to make sure it works on that.
                                dazza120 @andyc7687
                                @andyc7687 no mate I done a normal install from the magic mirror bash,I’ve done it twice as I was trying to make the install as light as possible so I was trying to use Stretch with just the basic but it wouldn’t have any of it so had to install the fat version and purge all the bloat ware but from what I’ve looked at so far doesn’t use that much more ram than the lite version, only thing I ended up doing was installing PM2 manually as for some reason it wouldn’t work from the bash after restart.
                                • 1 Offline
                                  12wsx
                                  after install on piZero (no W version) everything is ok but serveronly and browser does not start automatically. When I send from terminal:
                                  cd ~/MagicMirror;
                                  node serveronly
                                  server start properly, In browser manually start localhost:8080 showing MagicMirror website properly. What m i missing?
                                    andyc7687 @12wsx
                                    @12wsx straight after installation did you restart the pi zero? It should run, it’s quite a slow start up process though… if you run pm2 show MagicMirror what does it say? It takes a good minute to fire up sometimes…
                                    • 1 Offline
                                      12wsx
                                      Yes i have rebooted and wait about 10min and nothing.
                                      pm2 show MagicMirror says:
                                      root@raspberrypi:/home/pi/MagicMirror# pm2 show MagicMirror
                                      [PM2] Spawning PM2 daemon with pm2_home=/root/.pm2
                                      [PM2] PM2 Successfully daemonized
                                      [PM2][WARN] MagicMirror doesn't exist
                                      :confused_face:
                                        andyc7687 @12wsx
                                        @12wsx Did you change the default user to be called root? I’m confused as to why your prompt says root@raspberrypi, but the home directory (/home/pi/MagicMirror) is that instead of /home/root/MagicMirror
                                        As I remember, the shell script refers directly to a home drive using the user pi; if you wish to change this on your installation, issue:
                                        EDIT: I just noticed I think you’re running off my installer rather than the forked magic mirror repository that I have been testing more recently. The edits are the same, except instead of being in ~/MagicMirror/installers it’ll be in ~/MagicMirror/PiZero, and the files won’t have Pi0 on the end of their names
                                        sudo nano ~/MagicMirror/installers/startMagicMirror.sh
                                        change the bottom line so instead of pi it is the correct user’s home drive e.g.
                                        sh /home/root/MagicMirror/installers/chromium_startPi0.sh
                                        Also check pm2_MagicMirrorPi0.json and chromium_startPi0.sh in case they also are pointing to the pi user folder.
                                        then do
                                        sudo chmod a+x ~/MagicMirror/installers/startMagicMirrorPi0.sh;
                                        sudo chmod a+x ~/MagicMirror/installers/pm2_MagicMirrorPi0.json;
                                        sudo chmod a+x ~/MagicMirror/installers/chromium_startPi0.sh;
                                        to make all the files executable (just in case they aren’t already)
                                        Now run:
                                        sudo su -c "env PATH=$PATH:/usr/bin pm2 startup systemd -u pi --hp /home/pi"
                                        pm2 start ~/MagicMirror/installers/pm2_MagicMirrorPi0.json
                                        pm2 save
                                        changing the /home/pi to ensure you are in the correct user.
                                        Then restart and let me know what happens.
                                        That’s the only thing that I can think it could be at the moment
                                          Big11
                                          @andyc7687 said in Installing on a Pi Zero:
                                          Need help…
                                          I have installed MM on my PiZero’s many times with no succes to start it just localy and automatically …
                                          i followed your script and all seems running well and i did what you decided to autostart with PM2…
                                          but it didn’t
                                          after rebooting i can see the process “PM2 v3.4.2 GOD” running, but Nothing happens on my screen
                                          I tried to start the three startscripts manually and i got an Gtk-Error starting chromium-browser which i can’t work
                                          That it basicly works is shown when i start first the xserver manually (startx) and then whitin starting chromium-browser and Point it to http://localhost:8080…
                                          What is going wrong?
                                          where i can see some Errors ?
                                          Thanks a lot…
                                            andyc7687 @Big11
                                            @big11 From what I am reading of your reply, are you booting into command line mode? You should be booting into Desktop AutoLogin from sudo raspi-config | Choose option: Boot Options | Choose option: Desktop / CLI | then Desktop Autologin.
                                            Can you confirm which install script you ran? Did you run the one from ac2799/MagicMirror or ac2799/MagicMirrorPi0Installer?
                                            • 1 / 9
