    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 203.1k Views 10 Watching
    • O
      OceanK
      @Radu_Stancu check page 8 or 9 I posted it earlier the whole thing.
        Radu_Stancu @blackpanda
        @blackpanda Oh right, saw it, I initially thought it was the old version. Thanks mate. I do understand how it works to some extent. But when I have to rewrite it I get lost.
          @blackpanda Got it working + the policy thing. I get the connected to AWS in the console so I guess its good. The problem is that nothing happens when I say something. I suppose the mic is not set correctly. I have to troubleshoot this now.
          Connected to AWS IoT
          Subscribed: MagicMirror:new-text
          Subscribed: MagicMirror:new-images
          Subscribed: MagicMirror:change-module
          Subscribed: MagicMirror:new-video
          Means that I successfully installed it right? No more troubleshooting required on this side?
          • O
            OceanK
            @Radu_Stancu
            you could try the alexa skill at alexa skill development console. to see everything is working OK. because you can then type in the commands and it will answer if all is OK.
            have you tryed that?
            R 1 Reply Last reply
              Radu_Stancu @OceanK
              @oceank Yea that worked to some extent. When I say show me images it says that something is not supported.
              Amazon Photos is not supported on this device. View your photos using the Amazon Photos app or website, or on devices like Fire TV or Echo Show.
              When I say Alexa, start magic mirror, it promptly replies : “Hello my Queen, what can I do for you?” so that is working (Although I would like to change that message later)
              • O
                OceanK
                @Radu_Stancu did you follow the guide for google custom search? you have to enable images search for the custom engine.
                so the syntax will be “alexa…magic mirror…(then she will say hello my queen etc) and then you say .show me pictures of apples”
                R 2 Replies Last reply
                  Radu_Stancu @OceanK
                  @oceank I did follow the guide, and put the necessary api keys. I will redo the steps, maybe I missed something.
                    Radu_Stancu @OceanK
                    @oceank I redid the steps. Just to be clear, I need to do only the api steps right? not installing whatever they are saying there?
                    I keep getting the same message after I re-uploaded to lamba with new api keys.
                    • O
                      OceanK
                      @Radu_Stancu exactly just the API steps. when you made the custom search engine did you do :
                      1. Enable Image Search
                        In your search engine settings, enable “Image search”:
                      and I think you need 2 different projects at google developers console
                      1. google search (add google custom engine, and make the API key)
                      2. youtube (add the youtube data v3? I think its called, and the make API key)
                        Radu_Stancu @OceanK
                        @oceank I can confirm search images is on. I have also added youtube javascript v3 to the api. Are you sure 2 different projects are required?
                        O 1 Reply Last reply
                        • O
                          OceanK @Radu_Stancu
                          @radu_stancu well I have read that in some forums that it was required. When I had 1 project with 2 different API it didnt work for me so thats why I tryed the other option with 2 seperate projects and API and then it worked for me.
                            Radu_Stancu @OceanK
                            @oceank Okay, I`ll try that now. Nothing changed unfortunately…
                            • O
                              OceanK @Radu_Stancu
                              @radu_stancu
                              did you check the cloudwatch logs? see what error you get…
                                Radu_Stancu @OceanK
                                @oceank I can`t seem to find anything relevant in the logs… I keep getting
                                and similar for videos.
                                • O
                                  OceanK
                                  @Radu_Stancu
                                  so how do you trigger the search for videos or pictures?
                                  seems that its not triggering the magic mirror module, seems that its trying to use some amazon service?
                                  Are you saying this to alexa?
                                  alexa…magic mirror…and then the whole hello my queen is going on. and then you say “find pictures of apples”
                                  or how do you trigger the syntax?
                                    Radu_Stancu @OceanK
                                    @oceank I start with Alexa, start magic mirror, which works just fine. Then Search image of apples, find image of apple or any other possible way of saying I want an image of an apple results in:
                                    for videos I get:
                                    I couldn’t find any enabled video skills that can find that. Go to the Alexa app to manage your video skills and devices.
                                    #Solved. Forgot to modify the app ID line pointed out a few pages ago. Waiting for my echo dot to arrive to play around.
                                    • O
                                      OceanK
                                      @richland007 its all done man =)
                                      richland007R 1 Reply Last reply
                                      • richland007R
                                        richland007 @OceanK
                                        @oceank Dang it man i am the only one who hasn’t gotten around to finish it up. I will try tonight but i might need your help my man :)
                                        • O
                                          OceanK
                                          @richland007 im available today so just send me a chat!
                                          • richland007R
                                            richland007 @OceanK
                                            @oceank @blackpanda OK well i have triple checked my appID and pasted on the index.js file i have triple checked the endpoint and pasted on the mirrormirror.js file.
                                            Went and checked my API keys on Google i had like 8 of them, however none of them were what i had on keys.json file (so wired) so i picked 2 from the list and wrote them there along with my custom search ID uploaded to Lambda and copied over to the MMM-MirrorMirrorOnTheWall folder as well.
                                            I can see the MagicMirror: Connected to AWS IoT Subscribed for new-text, new-images, new-video, change-module also on Lambda i see the invocations getting posted on the logs all the time when i test from the developer.alexa with the invocation “magic mirror” i get the response “hello my queen blah blah blah…” but when i type show pictures of dwarfs i still get “there was a problem with requested skills response”
                                            What am i doing wrong???
                                            Is it the API keys form google ?? Where i can i see if they are getting hit with requests?
                                            …and do you all get any errors on Lambda logs when you test Lambda (how do you test Lamda) i still get the appId not unique when it is absolutely mine!!!
                                            It is an ass whooping this module :) i am gonna throw a party when its done LOL
                                            D
                                            • 6 / 7
