    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 199.4k Views 10 Watching
      blackpanda @Radu_Stancu
      @radu_stancu @OceanK posted his json config yesterday. Just need to go back a page or two in this thread.
      You’ll still need to understand what’s configured, in my opinion. Otherwise you’ll run into issue troubleshooting or extending the model. It’s pretty straight forward.
      • O Offline
        OceanK
        @Radu_Stancu check page 8 or 9 I posted it earlier the whole thing.
          Radu_Stancu @blackpanda
          @blackpanda Oh right, saw it, I initially thought it was the old version. Thanks mate. I do understand how it works to some extent. But when I have to rewrite it I get lost.
            @blackpanda Got it working + the policy thing. I get the connected to AWS in the console so I guess its good. The problem is that nothing happens when I say something. I suppose the mic is not set correctly. I have to troubleshoot this now.
            Connected to AWS IoT
            Subscribed: MagicMirror:new-text
            Subscribed: MagicMirror:new-images
            Subscribed: MagicMirror:change-module
            Subscribed: MagicMirror:new-video
            Means that I successfully installed it right? No more troubleshooting required on this side?
            • O Offline
              OceanK
              @Radu_Stancu
              you could try the alexa skill at alexa skill development console. to see everything is working OK. because you can then type in the commands and it will answer if all is OK.
              have you tryed that?
                Radu_Stancu @OceanK
                @oceank Yea that worked to some extent. When I say show me images it says that something is not supported.
                Amazon Photos is not supported on this device. View your photos using the Amazon Photos app or website, or on devices like Fire TV or Echo Show.
                When I say Alexa, start magic mirror, it promptly replies : “Hello my Queen, what can I do for you?” so that is working (Although I would like to change that message later)
                • O Offline
                  OceanK
                  @Radu_Stancu did you follow the guide for google custom search? you have to enable images search for the custom engine.
                  so the syntax will be “alexa…magic mirror…(then she will say hello my queen etc) and then you say .show me pictures of apples”
                    Radu_Stancu @OceanK
                    @oceank I did follow the guide, and put the necessary api keys. I will redo the steps, maybe I missed something.
                      Radu_Stancu @OceanK
                      @oceank I redid the steps. Just to be clear, I need to do only the api steps right? not installing whatever they are saying there?
                      I keep getting the same message after I re-uploaded to lamba with new api keys.
                      • O Offline
                        OceanK
                        @Radu_Stancu exactly just the API steps. when you made the custom search engine did you do :
                        1. Enable Image Search
                          In your search engine settings, enable “Image search”:
                        and I think you need 2 different projects at google developers console
                        1. google search (add google custom engine, and make the API key)
                        2. youtube (add the youtube data v3? I think its called, and the make API key)
                          Radu_Stancu @OceanK
                          @oceank I can confirm search images is on. I have also added youtube javascript v3 to the api. Are you sure 2 different projects are required?
                          • O Offline
                            OceanK @Radu_Stancu
                            @radu_stancu well I have read that in some forums that it was required. When I had 1 project with 2 different API it didnt work for me so thats why I tryed the other option with 2 seperate projects and API and then it worked for me.
                              Radu_Stancu @OceanK
                              @oceank Okay, I`ll try that now. Nothing changed unfortunately…
                              • O Offline
                                OceanK @Radu_Stancu
                                @radu_stancu
                                did you check the cloudwatch logs? see what error you get…
                                  Radu_Stancu @OceanK
                                  @oceank I can`t seem to find anything relevant in the logs… I keep getting
                                  and similar for videos.
                                  • O Offline
                                    OceanK
                                    @Radu_Stancu
                                    so how do you trigger the search for videos or pictures?
                                    seems that its not triggering the magic mirror module, seems that its trying to use some amazon service?
                                    Are you saying this to alexa?
                                    alexa…magic mirror…and then the whole hello my queen is going on. and then you say “find pictures of apples”
                                    or how do you trigger the syntax?
                                      Radu_Stancu @OceanK
                                      @oceank I start with Alexa, start magic mirror, which works just fine. Then Search image of apples, find image of apple or any other possible way of saying I want an image of an apple results in:
                                      for videos I get:
                                      I couldn’t find any enabled video skills that can find that. Go to the Alexa app to manage your video skills and devices.
                                      #Solved. Forgot to modify the app ID line pointed out a few pages ago. Waiting for my echo dot to arrive to play around.
                                      • O Offline
                                        OceanK
                                        @richland007 its all done man =)
                                        richland007R 1 Reply Last reply Reply Quote 0
                                        • richland007R Offline
                                          richland007 @OceanK
                                          @oceank Dang it man i am the only one who hasn’t gotten around to finish it up. I will try tonight but i might need your help my man :)
                                          • O Offline
                                            OceanK
                                            @richland007 im available today so just send me a chat!
                                            • 6 / 7
