    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 203.1k Views 10 Watching
    • O
      OceanK
      @blackpanda @Radu_Stancu
      maybe something is wrong with my interaction model because when I say magic mirror…and then say turn off magic mirror…I get " closing all modules"
      how does your interaction model look like? something is missing from mine I guess I posted earlier?
        Radu_Stancu
        I have not managed to get the JSON code to build so I cant help. Im trying to use the one you have posted.
        • O
          OceanK
          @Radu_Stancu aaah ok. Well that one posted is working great except I cannot clear videos nor pictures. So thats no good.
          @blackpanda is clearing video/photos working for you? if so…any suggestion for solving it?
          R B 2 Replies Last reply
            Radu_Stancu
              Radu_Stancu @OceanK
              @oceank Did you modify the AMAZON.LITERAL?
                blackpanda @OceanK
                @oceank you have to understand what you’ve configured in your interaction model.
                “name”: “TurnOffModuleIntent”,
                “slots”: [
                “name”: “moduleName”,
                “type”: “LIST_OF_MODULES”
                “samples”: [
                “close {moduleName}”,
                "close module {moduleName} ",
                “hide {moduleName}”,
                "hide module {moduleName} ",
                “turn off {moduleName}”,
                “turn off module {moduleName}”
                Check and understand your interaction model and intents. Does the type “LIST_OF_MODULES” defined in your interaction model include the module that you are trying to turn off?
                • O
                  OceanK
                  @blackpanda thanx for the info! I have to check it! because I can hide all other modules etc, except clearing video/pictures. Thanx a million!
                  R 1 Reply Last reply
                    Radu_Stancu @OceanK
                    @oceank Can you share your current json config? I can`t get past the amazon.literal
                    B 1 Reply Last reply
                      @radu_stancu AMAZON.LITERAL has been deprecated.
                      Check this out: https://developer.amazon.com/docs/custom-skills/literal-slot-type-reference.html
                      R 2 Replies Last reply
                        Radu_Stancu @blackpanda
                        @blackpanda Yeah, Im working on it, I was hoping somebody did this already so I dont have to troubleshoot. I`m trying to get this module working for more than a month now.
                          @radu_stancu @OceanK posted his json config yesterday. Just need to go back a page or two in this thread.
                          You’ll still need to understand what’s configured, in my opinion. Otherwise you’ll run into issue troubleshooting or extending the model. It’s pretty straight forward.
                          • O
                            OceanK
                            @Radu_Stancu check page 8 or 9 I posted it earlier the whole thing.
                              @blackpanda Oh right, saw it, I initially thought it was the old version. Thanks mate. I do understand how it works to some extent. But when I have to rewrite it I get lost.
                                @blackpanda Got it working + the policy thing. I get the connected to AWS in the console so I guess its good. The problem is that nothing happens when I say something. I suppose the mic is not set correctly. I have to troubleshoot this now.
                                Connected to AWS IoT
                                Subscribed: MagicMirror:new-text
                                Subscribed: MagicMirror:new-images
                                Subscribed: MagicMirror:change-module
                                Subscribed: MagicMirror:new-video
                                Means that I successfully installed it right? No more troubleshooting required on this side?
                                • O
                                  OceanK
                                  @Radu_Stancu
                                  you could try the alexa skill at alexa skill development console. to see everything is working OK. because you can then type in the commands and it will answer if all is OK.
                                  have you tryed that?
                                    Radu_Stancu @OceanK
                                    @oceank Yea that worked to some extent. When I say show me images it says that something is not supported.
                                    Amazon Photos is not supported on this device. View your photos using the Amazon Photos app or website, or on devices like Fire TV or Echo Show.
                                    When I say Alexa, start magic mirror, it promptly replies : “Hello my Queen, what can I do for you?” so that is working (Although I would like to change that message later)
                                    • O
                                      OceanK
                                      @Radu_Stancu did you follow the guide for google custom search? you have to enable images search for the custom engine.
                                      so the syntax will be “alexa…magic mirror…(then she will say hello my queen etc) and then you say .show me pictures of apples”
                                        Radu_Stancu @OceanK
                                        @oceank I did follow the guide, and put the necessary api keys. I will redo the steps, maybe I missed something.
                                          Radu_Stancu @OceanK
                                          @oceank I redid the steps. Just to be clear, I need to do only the api steps right? not installing whatever they are saying there?
                                          I keep getting the same message after I re-uploaded to lamba with new api keys.
                                          • O
                                            OceanK
                                            @Radu_Stancu exactly just the API steps. when you made the custom search engine did you do :
                                            1. Enable Image Search
                                              In your search engine settings, enable “Image search”:
                                            and I think you need 2 different projects at google developers console
                                            1. google search (add google custom engine, and make the API key)
                                            2. youtube (add the youtube data v3? I think its called, and the make API key)
                                            • 6 / 7
