    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 199.4k Views 10 Watching
    • richland007R Offline
      richland007 @blackpanda
      @blackpanda said in MMM-MirrorMirrorOnTheWall installation issue:
      Regarding the app id, you’re sure you copied the skill value and added it to the APP_ID variable before uploading it to Lambda? Also, did you disable skill verification in Lambda (this was mentioned in the install doc)?
      Yes i sure did copy and paste it to the index.js file before uploading i tried it also twice just now i also made sure that i disabled the skill verification on Alexa Skill Kit (it says right now on Lambda: "We recommend you enable skill verification for Alexa Skill Kit to do that delete and read the skill etc etc…)
      Its so wired … i just found that AMAZON.LITERAL post right before you posted here i will try to work as much asi can on it and ask for help again
      D
      • O Offline
        OceanK
        @blackpanda OMG!!! thanx a MILION DUDE! im so happy, its all working now, video, pcitures, modules…everything =)
        YES!
        • O Offline
          OceanK
          @blackpanda last question: If I made a picture search I see the pictures. But how do I clear those? same goes to video.
            blackpanda @OceanK
            @oceank Cool beans. I think this was referenced in the installation doc passively. But you have to use your invocation command again and then “turn off {whatever you module is named}”
            • O Offline
              OceanK
              @blackpanda hmmm ok. So for example if I say " magic mirror…show pictures of dogs"
              I can see all pictures of dogs on the mirror…how do I clear that? I mean what is the module name for that?
              then I understand that I can say turn off (whatever) but I dont get what that module name is for clearing the pictures…
                blackpanda @OceanK
                @oceank magic mirror… turn off {whatever you named your mm module}. Check out ModuleNames.json in your local mm module. There’s a mapping of variables to modules.
                • O Offline
                  OceanK
                  @blackpanda so this is what I have in my Modulenames.json
                  “alert”: “alert”,
                  “calendar”: “calendar”,
                  “clock”: “clock”,
                  “compliments”: “compliments”,
                  “current weather”: “currentweather”,
                  “weather forecast”: “weatherforecast”,
                  “news feed”: “newsfeed”,
                  “facial recognition”: “MMM-Facial-Recognition”,
                  “smile test”: “MMM-Smile”,
                  “globe”: “MMM-Globe”,
                  “jokes”: “MMM-jokes”,
                  “magic mirror”: “MMM-MirrorMirrorOnTheWall”
                  witch one is for turning off pictures? or videos? to clear it.
                    Radu_Stancu @OceanK
                    @oceank Note: To clear the text/images/video displayed by this module, you can simply turn this module off.
                    I suppose that means closing MMM-MirrorMirrorOnTheWall module
                      blackpanda
                      @OceanK @Radu_Stancu “turn off magic mirror”
                      • O Offline
                        OceanK
                        @blackpanda @Radu_Stancu
                        maybe something is wrong with my interaction model because when I say magic mirror…and then say turn off magic mirror…I get " closing all modules"
                        how does your interaction model look like? something is missing from mine I guess I posted earlier?
                          Radu_Stancu
                          I have not managed to get the JSON code to build so I cant help. Im trying to use the one you have posted.
                          • O Offline
                            OceanK
                            @Radu_Stancu aaah ok. Well that one posted is working great except I cannot clear videos nor pictures. So thats no good.
                            @blackpanda is clearing video/photos working for you? if so…any suggestion for solving it?
                            R B 2 Replies Last reply Reply Quote 0
                              Radu_Stancu
                                Radu_Stancu @OceanK
                                @oceank Did you modify the AMAZON.LITERAL?
                                  blackpanda @OceanK
                                  @oceank you have to understand what you’ve configured in your interaction model.
                                  “name”: “TurnOffModuleIntent”,
                                  “slots”: [
                                  “name”: “moduleName”,
                                  “type”: “LIST_OF_MODULES”
                                  “samples”: [
                                  “close {moduleName}”,
                                  "close module {moduleName} ",
                                  “hide {moduleName}”,
                                  "hide module {moduleName} ",
                                  “turn off {moduleName}”,
                                  “turn off module {moduleName}”
                                  Check and understand your interaction model and intents. Does the type “LIST_OF_MODULES” defined in your interaction model include the module that you are trying to turn off?
                                  • O Offline
                                    OceanK
                                    @blackpanda thanx for the info! I have to check it! because I can hide all other modules etc, except clearing video/pictures. Thanx a million!
                                      Radu_Stancu @OceanK
                                      @oceank Can you share your current json config? I can`t get past the amazon.literal
                                        @radu_stancu AMAZON.LITERAL has been deprecated.
                                        Check this out: https://developer.amazon.com/docs/custom-skills/literal-slot-type-reference.html
                                          Radu_Stancu @blackpanda
                                          @blackpanda Yeah, Im working on it, I was hoping somebody did this already so I dont have to troubleshoot. I`m trying to get this module working for more than a month now.
                                            @radu_stancu @OceanK posted his json config yesterday. Just need to go back a page or two in this thread.
                                            You’ll still need to understand what’s configured, in my opinion. Otherwise you’ll run into issue troubleshooting or extending the model. It’s pretty straight forward.
                                            • 5 / 7
