    MMM-MirrorMirrorOnTheWall installation issue
    138 Posts 11 Posters 199.4k Views 10 Watching
    • richland007R Offline
      richland007 @blackpanda
      @blackpanda OK well i think i got it to work but not really …it doesn’t seem like it is working right!!!
      I changed the alexa.appId = APP_ID but when i test Lambda it is still giving this error onthe Lamda Test: application Id must be unique.
      START RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a Version: $LATEST
      2019-01-05T19:14:08.827Z	12e0e369-111e-11e9-9390-b5c3e0fcc19a	The applicationIds don't match: amzn1.ask.skill.[unique-value-here] and amzn1.ask.skill.e0223a06-d061-48bd-9b1c-XXX9a950fcf
      2019-01-05T19:14:08.850Z	12e0e369-111e-11e9-9390-b5c3e0fcc19a
          "errorMessage": "Invalid ApplicationId: amzn1.ask.skill.e0223a06-d061-48bd-9b1c-XXXX9a950fcf",
          "errorType": "Error",
          "stackTrace": [
              "AlexaRequestEmitter.ValidateRequest (/var/task/node_modules/alexa-sdk/lib/alexa.js:157:27)",
              "HandleLambdaEvent.i18n.use.init (/var/task/node_modules/alexa-sdk/lib/alexa.js:123:29)",
              "/var/task/node_modules/i18next/dist/commonjs/i18next.js:190:9",
              "done (/var/task/node_modules/i18next/dist/commonjs/i18next.js:281:21)",
              "/var/task/node_modules/i18next/dist/commonjs/i18next.js:302:7",
              "I18n.loadResources (/var/task/node_modules/i18next/dist/commonjs/i18next.js:238:7)",
              "I18n.changeLanguage (/var/task/node_modules/i18next/dist/commonjs/i18next.js:301:10)",
              "load (/var/task/node_modules/i18next/dist/commonjs/i18next.js:186:14)",
              "I18n.init (/var/task/node_modules/i18next/dist/commonjs/i18next.js:195:7)",
              "AlexaRequestEmitter.HandleLambdaEvent (/var/task/node_modules/alexa-sdk/lib/alexa.js:114:32)"
      END RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a
      REPORT RequestId: 12e0e369-111e-11e9-9390-b5c3e0fcc19a	Duration: 208.20 ms	Billed Duration: 300 ms Memory Size: 128 MB	Max Memory Used: 65 MB
      On a good note:
      When i start the MMM-MirrorMirrorOnTheWall now i can see:
      Display=:0 npm start
      Connected to AWS IoT:
      Subscribed: etc etc …for all 4: new-text, new-images, change-module, new-video just like yours so it is connected to IoT
      However when i go to developer.alexa site and try to build the new interaction model using the drag and drop template i get this error
      Again the Interaction Model Is the stock one that comes with the package form github
      Lets get this sucker going it is driving me nuts… i can confirm that the AppID is the right one
      Denis
        blackpanda @richland007
        @richland007 Yep. Ran into that one. The interaction model from the project is outdated. You’ll have to refactor it a bit.
        AMAZON.LITERAL was deprecated and you’ll have to create a Custom literal (pretty easy to do from the UI).
        Check this out: https://developer.amazon.com/docs/custom-skills/literal-slot-type-reference.html
        Regarding the app id, you’re sure you copied the skill value and added it to the APP_ID variable before uploading it to Lambda? Also, did you disable skill verification in Lambda (this was mentioned in the install doc)?
        richland007R 1 Reply Last reply Reply Quote 0
          @blackpanda said in MMM-MirrorMirrorOnTheWall installation issue:
          Yes i sure did copy and paste it to the index.js file before uploading i tried it also twice just now i also made sure that i disabled the skill verification on Alexa Skill Kit (it says right now on Lambda: "We recommend you enable skill verification for Alexa Skill Kit to do that delete and read the skill etc etc…)
          Its so wired … i just found that AMAZON.LITERAL post right before you posted here i will try to work as much asi can on it and ask for help again
          D
          • O Offline
            OceanK
            @blackpanda OMG!!! thanx a MILION DUDE! im so happy, its all working now, video, pcitures, modules…everything =)
            YES!
            • O Offline
              OceanK
              @blackpanda last question: If I made a picture search I see the pictures. But how do I clear those? same goes to video.
                blackpanda @OceanK
                @oceank Cool beans. I think this was referenced in the installation doc passively. But you have to use your invocation command again and then “turn off {whatever you module is named}”
                • O Offline
                  OceanK
                  @blackpanda hmmm ok. So for example if I say " magic mirror…show pictures of dogs"
                  I can see all pictures of dogs on the mirror…how do I clear that? I mean what is the module name for that?
                  then I understand that I can say turn off (whatever) but I dont get what that module name is for clearing the pictures…
                    blackpanda @OceanK
                    @oceank magic mirror… turn off {whatever you named your mm module}. Check out ModuleNames.json in your local mm module. There’s a mapping of variables to modules.
                    • O Offline
                      OceanK
                      @blackpanda so this is what I have in my Modulenames.json
                      “alert”: “alert”,
                      “calendar”: “calendar”,
                      “clock”: “clock”,
                      “compliments”: “compliments”,
                      “current weather”: “currentweather”,
                      “weather forecast”: “weatherforecast”,
                      “news feed”: “newsfeed”,
                      “facial recognition”: “MMM-Facial-Recognition”,
                      “smile test”: “MMM-Smile”,
                      “globe”: “MMM-Globe”,
                      “jokes”: “MMM-jokes”,
                      “magic mirror”: “MMM-MirrorMirrorOnTheWall”
                      witch one is for turning off pictures? or videos? to clear it.
                        Radu_Stancu @OceanK
                        @oceank Note: To clear the text/images/video displayed by this module, you can simply turn this module off.
                        I suppose that means closing MMM-MirrorMirrorOnTheWall module
                          blackpanda
                          @OceanK @Radu_Stancu “turn off magic mirror”
                          • O Offline
                            OceanK
                            @blackpanda @Radu_Stancu
                            maybe something is wrong with my interaction model because when I say magic mirror…and then say turn off magic mirror…I get " closing all modules"
                            how does your interaction model look like? something is missing from mine I guess I posted earlier?
                              Radu_Stancu
                              I have not managed to get the JSON code to build so I cant help. Im trying to use the one you have posted.
                              • O Offline
                                OceanK
                                @Radu_Stancu aaah ok. Well that one posted is working great except I cannot clear videos nor pictures. So thats no good.
                                @blackpanda is clearing video/photos working for you? if so…any suggestion for solving it?
                                R B 2 Replies Last reply Reply Quote 0
                                  Radu_Stancu
                                    Radu_Stancu @OceanK
                                    @oceank Did you modify the AMAZON.LITERAL?
                                      blackpanda @OceanK
                                      @oceank you have to understand what you’ve configured in your interaction model.
                                      “name”: “TurnOffModuleIntent”,
                                      “slots”: [
                                      “name”: “moduleName”,
                                      “type”: “LIST_OF_MODULES”
                                      “samples”: [
                                      “close {moduleName}”,
                                      "close module {moduleName} ",
                                      “hide {moduleName}”,
                                      "hide module {moduleName} ",
                                      “turn off {moduleName}”,
                                      “turn off module {moduleName}”
                                      Check and understand your interaction model and intents. Does the type “LIST_OF_MODULES” defined in your interaction model include the module that you are trying to turn off?
                                      • O Offline
                                        OceanK
                                        @blackpanda thanx for the info! I have to check it! because I can hide all other modules etc, except clearing video/pictures. Thanx a million!
                                          Radu_Stancu @OceanK
                                          @oceank Can you share your current json config? I can`t get past the amazon.literal
                                            @radu_stancu AMAZON.LITERAL has been deprecated.
                                            • 5 / 7
