    2318 commits behind...
    17 Posts 8 Posters 9.9k Views 7 Watching
      savona @dazza120
      @dazza120 But then if I rebuild the docker container wouldn’t it just put me back 2318 commits?
      UPDATE: Yes, I rebuilt the docker container and it reverted right back.
        savona @savona
        @bastilimbach Any help?
          bhepler Module Developer @savona
          @savona - Would it make sense to build from image, rename the git files, pull, update and then upload the fixed image as a PR?
            savona @bhepler
            @bhepler maybe.
            but I saw that the originator of the docker image said it was updated daily with a cronjob on this post:
            https://forum.magicmirror.builders/topic/5316/automatic-docker-build/2
            • idoodlerI Offline
              idoodler Module Developer @savona
              @savona Both package-lock.json can just be deleted. Did you intentionally change the files in the default directory?
                savona @idoodler
                @idoodler No I did not change the default directory at all. That is why this is so odd to me.
                idoodlerI 1 Reply Last reply Reply Quote 0
                  rummyr
                  I got a message saying my MM was out of date, so I pulled the new docker image and now have the 2318 message also.
                  The top of my CHANGELOG.md reads “## [2.5.0] - 2018-10-01”
                  Though the “image date” as reported by Portainer is “Created 2019-01-01 15:08:22”
                  Do we need to wait for bastilimbach?
                  • idoodlerI Offline
                    @savona OK, you may have a corrupt git directory then. You may try to clone it again.
                      savona
                      I just blew away the docker image and did a new pull and it is fixed and on 2.6.0.
                      grep version package.json
                      “version”: “2.6.0”,
                      • T Offline
                        Thelonius
                        I was able to proceed past this error by using the command ‘git stash’. This worked for two Magic Mirrors.
                        • CyruS1337C Offline
                          CyruS1337 Project Sponsor
                          Hello everybody
                          I have three MagicMirrors in use. On two mirrors he shows me that I’m 2318 and 124 behind the master respectively.
                          If I enter git pull in the MagicMirror folder, error occurs
                          Aktualisiere 6db61b4..de57daa
                          error: Ihre lokalen Änderungen in den folgenden Dateien würden durch den Merge
                          überschrieben werden:
                                  package-lock.json
                                  vendor/package-lock.json
                          Bitte committen oder stashen Sie Ihre Änderungen, bevor sie mergen.
                          Abbruch
                          What do I have to do to bring the MagicMirror up to date?
                            you can erase those two files, then git pull again
                              @sdetweil said in 2318 commits behind...:
                              Ok, can you tell me how to delete and reload? Sorry, but unfortunately I do not understand so much of the matter :(
                                sdetweil @CyruS1337
                                @cyrus1337
                                rm package-lock.json
                                rm vendor/package-lock.json
                                then
                                git pull
                                as before
                                then probably reinstall npm modules
                                from MagicMirror folder
                                npm install
                                  Thank you for your quick help. Everything works :)
